April 01, 2025, 01:09:08 am *
Pages: 1 2 3 4 5 6 7 [8] 9  All
Author Topic: The greatest invention in/for Audio (Lush^2)  (Read 146126 times)
badgerline
« Reply #105 on: August 05, 2019, 06:33:27 pm »
Interesting …
I would never do it during playing, because chances are very fair that this is about ground loops ("somewhere") and that these are not broken when music plays (current is flowing through the signal cables). Then you stop playing, the groundloop changes (or just emerges because of that !) and next you press Play and it will sound different than prior to pressing stop a minute ago.
This can be so. And this I wouldn't do it.
Ah, that would explain why I heard a difference after stopping and starting. Intriguing, indeed.
« Reply #106 on: August 06, 2019, 07:11:42 pm »
Really so ? And not *after* I told my little story ?
badgerline
« Reply #107 on: September 17, 2019, 09:19:06 pm »
Really so - my impression is that it takes a while for the character of the configuration to 'settle in'. I +think+ it takes several minutes, though changes might be perceptible before then. Of course, this protraction might be psychological rather than electrical in nature.
Robert
« Reply #108 on: September 23, 2019, 02:24:28 am »
I've bit the bullet and bought the Lush 2. After two weeks at configuration it arrives with A: B-W-Y-R, B: B-W-R which certainly improved over the two weeks from new. I went back to original Lush cable and surprisingly its signature is similar but Lush 2 has more music information. I wouldn't call this change huge but none the less is there.
I have now changed to this setting from The Audiophile Style, General Forum, Lush^2 topic: TANF (A: xWYxxx, B: xWYRxx).
This certainly also needs some running in and has improved after a week. I listen to Spotify to find new music and it most certainly has improved the sound from this lofi source quite remarkably making it listenable for longer.
Anyway more listening to be done. Some of you may not be aware of this new configuration but worth trying. Has anyone else tried this and how did you find the sound?
I can't go back to original Lush, Lush ^2 is certainly a worthwhile improvement. Now where is XX 2.11?
Robert
Oppo 205 UDP Dac
JLAudio 12 Active Subs x 2
« Reply #109 on: September 25, 2019, 11:37:57 am »
Hi Robert,
For me this implied a too much balance towards the highs. However, I lasted for 6 weeks or so with it. In the end I found myself too much tweaking with other things (including 2.11 - sorry :-)) and ended up annoyed too much.
Thank you very much for sharing !
Robert
« Reply #110 on: September 25, 2019, 11:49:04 am »
Yes hard for me to say in this short time. Have you gone back to A: B-W-Y-R, B: B-W-R?
Certainly bass seemed restricted using TANF, highs extended though with XXhighend but on Spotify bass is almost too much.
Robert
Oppo 205 UDP Dac
Robert
« Reply #111 on: September 26, 2019, 01:24:27 am »
Just made a discovery I did not have TANF jumper connections correct at all. I didn't realise jumpers are in fact connected internally.
Currently trying this A:xWYRxx B:xWYRxx per Larry's suggestion AS site. Is this Cubed JSSG 360?
This certainly works for way better sound but have not compared to shipped config. I had no bass with incorrect TANF compared to now.
Can you clarify A: BWYR, B: BWR as shipped please.
From photo on supplied sheet A: BWYRxx, B: BWRxxx. Where x has no connections for A. But B: BWR(xx)x, two bracket x's are joined and last is not?
None of pictorial pictures show this shipped connection I believe? Photo a little hazy to my eyes of "B" jumpers.
Robert
Oppo 205 UDP Dac
« Reply #112 on: September 29, 2019, 12:20:41 am »
Hi Robert,
I will try to make something of this tomorrow.
« Reply #113 on: September 29, 2019, 11:51:40 am »
Robert,
For me (so mind you, for me) the jumpers don't do anything, until I can confirm myself that they do. I really have no time to sort it out, because it just takes too many days to carefully listen and I have more important things to listen for (like 2.11 new stuff).
The jumpers are there for protection only, and what ever picture you may run into from my hand, the jumpers could be on it randomly or even lacking.
Additionally you can not make any obtrusive connections with the jumpers.
You can bridge pins with them (free pins assumed, depending on the wire config applied), or you may just put on a jumper side ways, you may leave the pin(s) blank because no jumper covers them … it may all make a difference for SQ. But it is for you guys to find out, with "The Attorney" in the lead (as it appears).
As I said over there, everything and all may act as antenna with includes blank pins, or covered by jumper which immediately extends the antenna. The logic in it is that all is about antenna working in the first place and the shields which prevent it (more or less depending on the configuration), or just allow it (same). What happens for real we can't tell, unless someone measures it (I don't think I can with absolute measure).
Robert
« Reply #114 on: September 29, 2019, 12:07:50 pm »
Peter I just need to clarify the connections for the config you sent with the cable. Perhaps a new photo. Nothing more. Robert
Oppo 205 UDP Dac
« Reply #115 on: September 29, 2019, 12:26:22 pm »
Here you go :
Robert
« Reply #116 on: September 30, 2019, 01:47:10 am »
Thanks Peter it has come clear for me now as simple as it was, I think I thought it was not simple. Anyway current setting sounding excellent.
Robert
Oppo 205 UDP Dac
mtcs
« Reply #117 on: April 11, 2020, 07:52:45 pm »
I purchased a Lush^2 last year. I originally had a lot of trouble getting it to work in my system, connecting an utraRendu to an IsoRegen/Auralic Vega DAC. Alex from Uptone suggested that I change the order to uR/IsoRegen=>Lush^2=>Auralic. It worked immediately and I had many months of listening pleasure.
A few weeks ago I had to disconnect everything to re-position some components. I have not been able to get it working again. The uR simply doesn't "see" the DAC. I've tried everything I can think of such as powering down/ up components, different place of the cable, etc. Nothing works. Does anyone have any ideas? TIA.
« Reply #118 on: April 12, 2020, 06:44:18 am »
Let me think about this a little ... I have had similar, gave up on it, while only later it sprung to my mind what might have happened. But right now I forgot what that was !
A normal USB cable still works with that same chain ?
mtcs
« Reply #119 on: April 12, 2020, 06:47:36 pm »
Yes, the system works with other USB cables. I'm currently using a Nordost with and without the Isoregen.
Page created in 0.014 seconds with 19 queries.
