April 05, 2025, 05:22:09 am *
Author Topic: Track stops randomly  (Read 6577 times)
Shreekant Somany
« on: June 22, 2018, 04:00:06 pm »
Dear Peter,
I have a problem, while playing an album a track in random stops playing and only ticking sound is heard. The following messages are flashed, this naver happened in the past.
The settings are as per the 14393 / 2.10 version.
Can you please help.
Shreekant
shreekant
« Reply #1 on: June 22, 2018, 05:01:08 pm »
Hi Shreekant,
It is just a hunch, so not sure at all ...
See the below screenshot.
The other day I found the contents of that "Temp" folder to comprise of over 4GB of pictures. I am not even sure how it can get there because it is a. XXHighEnd related (but I don't do it) and b. it can only get to your RAM environment when it first has been on permanent storage.
In the end this consumes your "disk" (= RAM) space and you may get sudden errors like you showed. IOW :
Can you look whether this contains a significant amount of data (like more than 1GB). Thus, I mean this Temp folder. If so, boot into the BASE OS and now delete the contents of the Temp folder fully (it wil be on Drive C: again). Now boot back into RAM and see whether the problem is solved.
Please let me know the result !
Shreekant Somany
« Reply #2 on: June 22, 2018, 05:45:37 pm »
Dear Peter,
I did exactly what you have suggested. All temp folds have been cleared. I will test it tomorrow and give you a fed back.
shreekant
