November 22, 2024, 04:35:30 pm *
Author Topic: Crack Detect issues using normal Ram OS  (Read 24822 times)
Robert
« on: June 01, 2018, 11:15:57 pm »
Peter I have never had issues with this until now.
But odd tracks on albums throw this message up. They are from ripped CD's. I re ripped them but still Crack message. I see there is a Disable Crack button recommended for Engine 3,4. This does work when activated. Is this OK? I see you have been playing with Crack Detect in your latest Mach III post. I don't know anything about Crack Detect which is why I'm cautious.
Robert
Oppo 205 UDP Dac
JLAudio 12 Active Subs x 2
« Reply #1 on: June 02, 2018, 05:31:41 am »
Hi Robert,
No, it is not advised at all to disable Crack Detect; it is your protection to software failure and how otherwise static (the most loud noise) can emerge.
When you are sure it will be or the rip which is not 100% OK or when it is just "the music" (see below) you can switch it off for the occasion.
If Crack Detection trips on two different SFS settings, you can be ensured that it is just the rip or the music (and not software failure) and nothing will go wrong when it is switched off.
For your own "safety", don't forget to switch it back on after you played the album.
With the (internal) thershold setting in 2.10 it very occasionally trips on normal music although the music will be the most dynamic.
Indeed with bad rips and glitches in the resulting file, it will tip too.
Indeed it will be so that a next XXHighEnd version will allow more of "inordinate" dynamics hence it accepts more ("glitch") as normal music.
If not clear, please ask further.
Robert
« Reply #2 on: June 02, 2018, 05:53:32 am »
It did trip with same SFS settings. One track was from a Bob Marley remastered ripped CD Kaya. The other from Peter Green The Best of ripped CD not remastered. I didn't think either were that dynamic being older recordings. Anyway I have left Crack Detect on. Thanks
Robert
Oppo 205 UDP Dac
« Reply #3 on: June 02, 2018, 09:41:51 am »
Robert, to be clear ... if it trips with two different SFS settings, then it is OK and just the music (or the rip). Notice that both are harmless.
The software failure would be that e.g. 1 bit (out of a 16 bit audio word) is missed/skipped, which from there on would make a mess of the remainder (a softest bit will become the loudest etc.). This can theoretically be incurred for by the relatively complex "alignment" of the memory player vs the SFS controlling what you actually want in memory. I (XXHighEnd) can do something wrong there - Windows can do something wrong. However, this is highly unusual unless I introduce mistakes myself. This was so with IIRC 2.07 or 2.08. Then it started to happen to many people, but depending on the SFS setting ...
Rmalits
« Reply #4 on: June 21, 2018, 07:33:28 pm »
Peter, I had this kind of issues very rarely:
24 bit second stage crack dedect !  -> 34
playback has been stopped
But since yesterday it happend for 4 different tracks. I tried with different SFS setting and it still happens.
All these tracks play well with other players. Nothing strange to hear. I have downloaded these track from Tidal and Beatport, they are no rips (at least they shouldn't be).
Download from Tidal:
Artist: "KMLN", Album: "2015 - Alhambra"
The crack detect error occours for the first 3 tracks of this album.
What's maybe interesting: The first track "Alhambra (Original).flac" I also downloaded from Beatport in aiff format and then converted it to flac. Same thing: crack detect occours for both versions.
What to do about this?
Kind regards
Richard
« Reply #5 on: June 21, 2018, 08:04:06 pm »
Hi Richard,
What to do with this ?
- Wait for the next XXHighEnd version;
or
- Use Custom Filtering.
OK ?
Rmalits
« Reply #6 on: June 22, 2018, 10:19:20 am »
Ok, Peter,
I didn't know that it's related to AP filter.
Custom filter works well with these tracks.
Kind regards
Richard
« Reply #7 on: June 22, 2018, 12:26:12 pm »
Hi Richard,
It is not related to the AP filter - it is rather the other way around;
The Custom filter smears (relatively) so much, that the as illegal regarded transients are smoothed to "no problem".
The Arc Prediction filter is far more the reality.
So the Custom filter can act as a trick to avoid the issue.
Robert
« Reply #8 on: July 16, 2018, 12:05:46 am »
This has occured again on the weekend but hasn't been a problem since last noted here.
I stopped XX engine(blue button) and clicked out of XXhighend but kept Ram OS going. I restarted XX and everything has continued normally since.
So guess this has solved it until next time.
Robert
Oppo 205 UDP Dac
« Reply #9 on: July 16, 2018, 07:44:16 am »
Hi Robert,
Are you saying that when you restarted XXHighEnd, you played the very same track and then it didn't reoccur ?
Robert
« Reply #10 on: July 16, 2018, 10:04:37 am »
Yes thats correct.
Oppo 205 UDP Dac
« Reply #11 on: July 16, 2018, 01:53:11 pm »
Robert,
In that case, if all is right, you were really protected by the CrackDetect functionality. I mean, without that I think it would have been a lot of noise.
hvdh
« Reply #12 on: August 10, 2018, 11:12:19 am »
Yesterday, I had a small brainfart, I turned off my music PC while the audio PC was playing music.
Which shouldn't really be a problem I guess, but it is...
I lost RDP (obviously) so I turned off the audio PC (after the music had stopped playing) by pulling the plug. I didn't know how else.
The result is that I now always get:
24 bit Second Stage Crack Detect!-> 51
Playback has been stopped.
So I have no sound at all, even when I disable crack detect, It seems to play, but I still have no sound.
Any idea what I can do about this?
Win10 14393.0 / music on LAN /  / Q1/-/3/4/5 = 30/-/1/1/1 / xQ1 = 40 / Dev.Buffer = 4096 / ClockRes = 15ms / Memory = Straight Contiguous / Not Include Garbage Collect / SFS = 20.19  (max 60) / not Invert / Phase Alignment Off / Playerprio = Low / ThreadPrio = Realtime / Scheme = Core 3-5 / Not Switch Processors during Playback = Off/  / UnAttended (Just Start) / Always Copy to XX Drive / Stop Desktop-Remaining-WASAPI-W10 Services / Keep LAN - Persist / WallPaper On / OSD On / Running Time Off / Minimize OS / XTweaks : Balanced Load = 42 / Nervous Rate = 100 / Cool when Idle = 1 / Provide Stable Power = 1 / Utilize Cores always = 1 / Time Performance Index = Optimal / Time Stability = Stable / Arc Predict -> Clairixa USB 0.80 meter -> 24/768 Phasure NOS1a DAC With B'ass and Phisolator -> BAlanced interlink -> Apogee Grand loudspeakers, using STAX dma-x2 (midrange ribbon) / Krell FPB600C (bass ribbon)
If it flies, Don't ground it!
« Reply #13 on: August 10, 2018, 01:02:06 pm »
Hey Henk,
I suppose this requires Teamviewer surgery. Mind you, already because I think it is "interesting" as such. I really have no clue what causes this (but it is software anyway).
Robert
« Reply #14 on: August 12, 2018, 04:21:03 am »
This is one intermittent bug that's also come back to haunt me even on the old low SFS settings. Happens on quality rips and downloads. I've tried different SFS settings this doesn't stop it. No stress I just change the music or switch Crack detect off.
Robert
Oppo 205 UDP Dac
Page created in 0.12 seconds with 19 queries.
