April 06, 2025, 01:45:50 am *
Pages: 1 2 [3]  All
Author Topic: Running downgraded Xxhighend with W10 updated OS  (Read 36021 times)
« Reply #30 on: May 28, 2018, 11:54:44 am »
And allow me, because I think it can be relevant :
Below is what George received initially (!!) from his XXHighEnd install. The remainder - very similar of not the same as Robert experiences - happened after "resetting" the XXHighEnd install data (RightClick on Save As etc.).
Also see the attached .txt file which is the content of the error after clicking the "Details" button.
This error in itself I recognize, but I can't tell what incurs for it in this situation. I'm contemplating an error message to put forward about No Sound Device found or something similar (without XXHighEnd showing actively because this is about the Install (I think !)). The bringing forward of the message now fails with the error presented (below). This situation can be called a bug in XXHighEnd and it can only be solved when I can mimic it over here.
All 'n all it is a bit of a complex situation.
* UnhandledException.txt (6.55 KB - downloaded 749 times.)
nik.d
« Reply #31 on: May 28, 2018, 12:45:48 pm »
I'll be back home probably tomorrow and will do what Peter nicely summed up in his previous post: boot into normal OS and start uninstalling one by one 'App' until I get stuck with subject error. And report here of course. Last time solution to problem was simple: fresh W10 installation Happy
Since I've got new 14393.0 ISO file ('N' variance this time) I'm really planning to format disk and start all over again with it. Have enough cold white wine for light, Summer 'spritzer'  smile
Btw, here is small download tool that will help download any M$oft Windows ISO image you wish: https://www.heidoc.net/joomla/technology-science/microsoft/67-microsoft-windows-iso-download-tool
Robert
« Reply #32 on: May 29, 2018, 05:57:58 am »
        I will say the W10 in this disc is standard but I have turned off unwanted Win Apps in the Win settings window only as per normal user. Also the UAC slider is set to lowest I have not turned it off. The W10 was cloned from another disc but has worked perfectly since. Should I do a fresh installation?
Robert
Oppo 205 UDP Dac
JLAudio 12 Active Subs x 2
« Reply #33 on: May 29, 2018, 08:46:18 am »
Hi Robert,
Well, if you like to do that, it would be the fastest. And then without changing anything really, try XXHighEnd.
Or wait for whether Gerorge maybe finds the culprit after all.
Or, if you intend a reinstall anyway, first try to restore the current install to the oldest Restore Point you can find and see whether that maybe helps.
nik.d
« Reply #34 on: May 30, 2018, 02:42:00 pm »
Here's a short report of my playing with 'AudioPC' trying to replicate subject error: No success. XXHE starts normally.
I've uninstalled all unneeded Apps that came with W10 14393.0 using Settings + PowerShell + CleanMyPC sw and tried starting XXHE after each uninstalled app. Always normal start.
Did not touch Defender, think it is disabled by XXHE?
« Reply #35 on: May 30, 2018, 03:22:21 pm »
No.
Where Defender runs (and even keeps on running in MinOS) is a complete mistery to me. I never had to disable it but this sure does not count for everyone.
Thanks for trying !
Robert
« Reply #36 on: June 03, 2018, 07:44:34 am »
       Fresh W10 installation has worked with XXhighend at last. I'd almost swear I have better sound with Netflix and Spotify. Getting Microsoft network to work was a pain to see Music file server. Anyway guess I will register so I can get the most out of it in reduced mode. Have to say Ram Os 2.10 is sounding amazing in contrast we have a long weekend for the Queens birthday. Listening to unplayed files since 2.10 upgrade and settings. Thanks.
Robert
Oppo 205 UDP Dac
« Reply #37 on: June 03, 2018, 10:31:39 am »
Hi Robert, - great that is.
The Queen's (ever lasting) birthday, however, seems to be June 9. Well, the celebration of it (I think she's 92 or so long gone). Good to be prepared of course but don't make it too wild over there. Plus, Charles won't like that. If only Diana would still be among us ...
Pages: 1 2 [3]  All
