April 08, 2025, 09:08:07 pm *
Author Topic: Object reference not set to an instance of an object  (Read 8107 times)
hwk
« on: May 16, 2018, 05:45:03 pm »
I get this message on my screen:
'Error during playlist preparation: Object reference not set to an instance of an object'
No sound of music whatsoever unhappy
Please HELP!!
best regards, HW
« Last Edit: May 17, 2018, 07:49:01 am by PeterSt » Logged
Music Dedicated PC, Power: Silverstone Nightjar 300, MB: ASRock H87M Pro4 + I5 4570T + 4GB, Internal Memory: 16Gb Kingston DDR3-1333,  500Gb Crucial MX500 SSD with W10 Build 14393.0, 2x 4Tb WD 40EZRZ HDD for Music only), Soundcard: Seriously Modified Prodigy HD2 PCI Card 24 Bit/192 KHz with Amplimo's (van GooiPC), W10 10586-11 Home Edition 64bit
XXHe 2.11: KS mode: Special, Device Buffersize: 1024; Processor scheme: CORE 3-4; Player Prio: Below Normal, Threadprio: Above Normal, Clock Res.: 10 msec; HDCD on; SFS: 105.19,  Mem.Org.: Mixed Cont.; Q's=13x10,0,0,0; PE: Off, Custom: On; Playing Mode: Min.OS; XTweaks= On Indicates: "OPTIMAL": Bal.Load=45, Nervous Rate=99, rest=1  -  Sound Gear: Meridian 502 PreAmp (upgraded), 588 CD, 2x 505 MainAmp (upgraded) (all balanced driven), Speakers: Magnepan 3.5 SE, extra: Aphex 204 Aural Exciter; Cables: CD>Pre: Siltech SQ88, PC>Pre & Pre>Dedicated Headphones Class A Amplifier: John van Gent Reference+, Amplifiers>Speakers: Discovery 4; Headphones: AKG K1000 & Ultrasone Pro550 + dedicated Class A amp; Music Dedicated Power Group (copper shielded main cables + Oyade plugs) with parallel noise filter for the main-amps and PS Audio Quintet for the front-end. Analog: Micro Seiki DD33 modified, Denon301
« Reply #1 on: May 17, 2018, 07:48:31 am »
Hi Henk-Willem,
If you can still normally start XXHighEnd :
In Settings, near the top, there's the "Load Settings Preset" text with the "..." button next to it. If you click that, you can get back the settings of your choice. Take the .XXSS file from two days ago when all was fine for sure. When you clicked Open in the Explorer instance, click the Load in XXHE's Settings.
But I don't think that is going to help. If not, delete these files from the XXData folder :
!CurrentlyPlaying.LBRY
!Played.PLXX
Delete this file from your XX folder :
Played.dat
Does this help ?
If not, I am here to respond right away.
PS: I changed the title of the topic so others may find it more easily when they run into a similar problem.
hwk
« Reply #2 on: May 17, 2018, 08:46:57 am »
thanks for your reply.
Happily I still can normally start XXHe.
I tried all your suggestions, but nothing did help so far (BTW: I couldn't find Played.dat in the XX folder...)
Best Regards, HW
« Reply #3 on: May 17, 2018, 09:52:22 am »
Ok Henk-Willem. Thanks.
What about starting XXHighEnd, press Clear and quit XXHighEnd.
Does it work now at a next restart ?
If not, please do this :
Go to Settings, switch on Logging (is close to the bottom), quit XXHighEnd, restart, let the error occur - let the error be on screen (!!) and then go to the TemporaryData sub folder and find the newest log file which starts with XX. Please attach that to your next post. From there I can at least see where all stops.
After you have done this, you can cross away the error message.
« Reply #4 on: May 17, 2018, 02:01:34 pm »
HW, Thank you for the log file.
Can you please do this :
- Check with an other album (maybe you already did that - let me know if you did).
- In settings, activate "Don't do anything with Coverart" and retry.
- Tell me whether you're using Tidal with XXHighEnd.
- Tell me what text you see in the Playlist Area after you pressed Clear.
scratching
hwk
« Reply #5 on: May 18, 2018, 04:23:42 pm »
I tried again all your suggestions, but the message still stays the same.
No, I don't use Tidal
After I pressed CLEAR (I can only do so after I clicked away the infamous message): the normal screen appears with the text  'XXHighend W10 14393.0  model 2.10c
 unhappy HW
« Reply #6 on: May 18, 2018, 05:08:04 pm »
All right Henk-Willem.
Can you set up a Teamviewer Connection to the PC you control your Audio PC with ? Then I can have a look and solve it for you.
Let me know the Teamviewer ID via email and notice that each time you restart it you must pass me the password again (because it changes).
OK ?
hwk
« Reply #7 on: May 18, 2018, 05:14:39 pm »
okay
