Beauchamp Michel
« on: May 07, 2018, 05:37:58 pm » |
There is only one Ethernet port on the Mini. What is the best approach in this situation?
Thanks - Michael
XXHighEnd Mach III Stealth LPS PC -> Xeon Scalable 16/32 core with Hyperthreading On (set to 10/20 cores) @~660MHz, 48GB, Windows 10 Pro 64 bit build 14393.0 from RAM, / Engine#4 Adaptive Mode / Q1/-/3/4/5 = 15/-/1/1/1/ Q1Factor = 20 / Dev.Buffer = 4096 / ClockRes = 15ms / Memory = Straight Contiguous / Include Garbage Collect / SFS = 0.69 (max 0.69) / not Invert / Phase Alignment Off / Playerprio = Low / ThreadPrio = Realtime / Scheme = Core 3-5 / Not Switch Processors during Playback = Off/ Playback Drive none (see OS from RAM) / Always Copy to XX Drive (see OS from RAM) / Stop Desktop, Remaining, WASAPI and W10 services / Use Remote Desktop / Keep LAN - Persist Yes / WallPaper Off / OSD Off (!) / Running Time Off / Minimize OS / XTweaks : Balanced Load = 35 / Nervous Rate = 10 / Cool when Idle = n.a / Provide Stable Power = 0 / Utilize Cores always = 1 / Time Performance Index = Optimal / Time Stability = Stable / *Arc Prediction Filtering (8x)* / Always Clear Proxy before Playback = On / USB3 port #4 -> Lush^2*A:B-W-Y-R, B:B-W-R* USB 1m00 -> Phisolator 24/768 Phasure NOS1a/G3 75B (BNC Out) async USB DAC, Driver v1.0.4b (16ms) -> B'ASS Current Amplifier -> *Blaxius^2 A:B-R, B:B-R* Interlink -> AVM SA8 -> LEEDH E2 Speakers + Blaxius -> LEEDH SUB 20.1 AC Power: 3 x Dedicated lines for: Amp., PC + DAC and Sub / 3 x Topaz Ultra Isolation transformers 1.8kva in Balanced mode (0.0005pf); Music Server: Mac mini 2011,; Music files on USB Stick; Mac connected to house Router/Hub with copper cable; Router/Hub: Ethernet cable to TP-Link MC200CM Fiber Media Converter to Stealth III PC Other: AC line filtering with Perfect Path Technologies The GATE, EMat+, ECards, Stop Its; MAD Scientist Black Discus NANO.
« Reply #1 on: May 07, 2018, 05:41:10 pm » |
Hi Michel,
OK, clear. Doesn't the Mini have WiFi ?
Beauchamp Michel
« Reply #2 on: May 07, 2018, 06:18:26 pm » |
Of course the Mini has WiFi. So the chain could be:
Surface -> (RDC, WiFi) -> Mac Mini -> (RDC, cable) -> Stealth.
Thanks - Michael
« Reply #3 on: May 07, 2018, 07:07:16 pm » |
Yes Michael, great. When you got the hang of it we can expand to whatever you like best for any reason. Best regards, Peter PS: Yes, of course the PC takes a USB stick. But since (it will be worse for SQ and) you have the risk of it utilizing Drive letter D: which is not allowed, it is only challenging for additional problems. First get acquainted with (many) things.
Beauchamp Michel
« Reply #4 on: May 13, 2018, 03:17:56 am » |
Hi Peter, Well, I'm running in quite a few hurdles on the communications side. First my Mac mini doesn't have a Wi-Fi connection anymore. I haven't used it for the past 5 years and now that I need it, it doesn't work. I checked everything and it's negative. Maybe I disconnected it when I installed the SSD and modified the power supply in the past, I don't remember. I tried to connect the Mac to the Stealth directly but again it doesn't work despite the fact that I set all the authorizations on both PC's. The Mini is not seen on the Stealth. Then I tried to connect the Stealth to my home network but I couldn't get the connection going. There were no lights at all at the ethernet port of the Stealth. This cable connection always worked with the Mini. Then to make a test I moved the Stealth beside the router and connected both with a short ethernet cable, and...it worked. So maybe my long cable (~15 meters) is not good enough for the 1Gb speed. It's a Cat6, 550 MHz. While the Stealth was connected to the router I tried to connect to it via an RDC on the Surface Pro but I couldn't. When it fails I get the following message: ''This could be due to CredSSP encryption oracle remediation''. I use the good IP address with the Userid XXHE and the PW xx. Would you have a few hints to help me go through this sh*t. The good news is that for the main part it works. I can boot in RAM-OS and remove the SSD from the bay. And it plays music. However my special setup practically prevents me from using it because as you know all the electronics equipment is in the basement, underneath the living room where the speakers are located. I know that it will eventually work but for the time being it's kind of frustrating.  Thanks - Michael
« Reply #5 on: May 13, 2018, 07:53:15 am » |
Hey there Michael, Sorry for your frustration, but that's computers eh. And forums ... ''This could be due to CredSSP encryption oracle remediation'' So it is a kind of unwritten rule that you should follow the Phasure forum. Haha. Luckily you got that explicit message about CredSSP, although you are the most unlucky guy to run into this while it was introduced only the past week. CredSSP policy change - no RDP possible. So the least you are dealing with is that and otherwise it is a most normal RDP connection. But if one is not used to that, nothing is normal. Btw, if you use the Ethernet port with the green dot next to it ... that's the one I have been using over here on the very PC. And connect via IP addresses and not via PC names. All beginning is difficult, and when one hurdle has been taken, an other pops up ...  Heads up and let's get it going, Peter
« Reply #6 on: May 13, 2018, 08:10:22 am » |
Michael,
Something else is that you told me that you were able to boot from RAM. OK. But now knowing that you didn't arrange for the RDP connection, this is quite not what the install guide tells you for the sequence of matters. So it is quite possible that now you are in all of the wrong modes where nothing will install and nothing is persistent either (RAM).
Boot into Normal OS, BASE. If you are in MinOS RAM right now : - Boot into the BASE version. - Boot into Normal OS. Now you are in normal OS BASE.
« Reply #7 on: May 13, 2018, 09:58:55 am » |
Then to make a test I moved the Stealth beside the router and connected both with a short ethernet cable, and...it worked. And ... Your 14393.0 could be upgraded to whatever you don't want. Does XXHighEnd still show 14393.0 in the main screen after pressing Clear ? You-do-not-want to connect the Audio PC to the internet. But I think you just did.
Beauchamp Michel
« Reply #8 on: May 13, 2018, 12:56:25 pm » |
Hi Peter, My RDC now works, thanks to Anthony. clapping: A few days ago I saw this thread 'CredSSP policy change - no RDP possible' but didn't pay enough attention to it and yesterday I didn't make the connection between the error message I was getting and this thread. I followed Anthony's recipe and voilà. And by the way RDC works with the IP address and the PC name. Now regarding the OS when I wrote my previous email the Stealth was running from the Base not from RAM. In this email I just wanted to say that I had confirmed that the PC was able to boot from RAM. But for all the tests the Stealth runs from the Base. The OS version shown on the upper left corner of XXHighEnd is 'D:\MyW10-14393.vhd'. So I don't think that the OS has been updated with Internet. Regarding Internet, there are a few ways to disable it on a PC. Which one would you recommend? And I'm still thinking about a way to get the Mac mini to be used as a music server with only one built-in Ethernet port (the WiFi is dead). However I have a means to add a 2nd Ethernet port with a Thunderbolt to Ethernet adaptor that I have on hand. I tried it and it works. However there needs to be a bridge setup between both ports so that a RDC to the Mini could also reach the Stealth. This will be my next step. In the mean time I just want to be able to establish a RDC directly with the Stealth so that I can begin to listen to music.  To do so unfortunately the PC must be directly connected to the router but I don't want internet to reach into it. Thanks - Michael
« Reply #9 on: May 13, 2018, 02:22:56 pm » |
OK, first things first now. Does XXHighEnd still show 14393.0 in the main screen after pressing Clear ? ? Peter
Beauchamp Michel
« Reply #10 on: May 13, 2018, 03:56:16 pm » |
As mentioned in my previous email ''The OS version shown on the upper left corner of XXHighEnd is 'D:\MyW10-14393.vhd'. So I don't think that the OS has been updated with Internet.''
Michael
« Reply #11 on: May 13, 2018, 05:00:07 pm » |
« Reply #12 on: May 13, 2018, 05:31:21 pm » |
Hi Michael,
Peter wants you to know the OS in the XXHE playlist screen. Image no 12 attached.
Also to stop W10 updating, right click on the stop button in XXHE & choose the option to stop updating. Image 13 attached.
« Reply #13 on: May 13, 2018, 08:57:49 pm » |
Thank you very much Arvind. OK Michael, I am afraid that by the time you're back behind the keyboard, we didn't communicate much today. So in case you still have 14393.0 running for real (and by my means of observing please), this topic could help you : A secure way to prevent Windows 10 , updates on the audio PC. Please keep in mind that this is only one of them / the possibilities and it is not exactly your situation, but it may give you some pointers. I think it is also a good idea to read the sequence of things to do once more (Install Guide "addendum") plus my today's first post. All is quite exact untill you blindly know what to do - it just is so for the moment.  We just don't want to mess up (which is relatively easy). Kind regards, Peter PS: That link I gave is not to leave you be with it but to leave you with something for the day.
Beauchamp Michel
« Reply #14 on: May 14, 2018, 04:44:33 pm » |
Hi Arvind - Thanks for the information. I confirm that the OS version is 14393.0. Also regarding the W10 update, the right clic on the stop button shows ''Clic to Allow W10 Updates'' not ''Clic to Stop W10 Updates''. The version of XXHighEnd is 2.10c and I never clicked on this one so I presume that when XXHE is installed the default state is that the W10 Updates is blocked. Peter can you confirm?
Right now my main objective is to have the Stealth to communcate on my LAN. It's a bit strange that the 2 Cat6 cables (15 meters ea.) between the router and where the electronics equipment is located can carry the communication to the Mac mini but not with the Stealth. There is not even a LED on, on the Stealth LAN port. When I move the Stealth close to the router and connect it with a short cable it works. I think I will get another cable.
Michael
