November 22, 2024, 11:18:25 am *
Pages: 1 [2] 3 4  All
Author Topic: CredSSP policy change - no RDP possible  (Read 54226 times)
« Reply #15 on: May 12, 2018, 01:22:43 pm »
Juan, I think you change this setting in your music server PC, not your audio pc.
« Reply #16 on: May 12, 2018, 01:29:02 pm »
The image is from the Audio Pc, first I've try to do it in the Server Pc but the screen was the same
« Reply #17 on: May 12, 2018, 04:06:38 pm »
Are you sure its not there? I had to read the list 3 times before i finally saw it. You should post a picture from your music server pc if you still cannot find it.
Brian
« Reply #18 on: May 12, 2018, 06:27:42 pm »
Hi Brian, thanks for your help but no way to find "Encryption Oracle Remediation" in any of the computers. However I've found other solution that works perfectly: Allow Multiple Remote Desktop Sessions
Can find the way in this link:
https://m.youtube.com/watch?v=fi87Xe78YNY
Best regards
« Reply #19 on: May 13, 2018, 07:37:54 am »
Hi Juan,
Please notice that the RDPW program (YouTube) you linked to is not about Multiple Remote Desktop Sessions however, it does that too. But we should not be confused by this.
Btw, when I read your post yesterday, it occurred to me that the Policy entry wouldn't be there for "Home" OSes. Can that be so ? If yes, this is exactly the reason why RDPW will help (it was made for that). But not sure, because it would be about the receiving PC (like the Audio PC).
« Reply #20 on: May 13, 2018, 07:46:51 am »
Hi Peter, the video that I posted was not exactly the one I used because I used one that was in Spanish. The Winrar, however, it is the same and I used it only on the server computer. The Windows OS that I have in that Pc is the Pro version.
Best regards
« Reply #21 on: May 13, 2018, 07:57:24 am »
Juan,
I didn't look at the Policy screen(s) myself, but I know there are two main parts in there. One for "system" or something and one for "users" (or something). Are you sure you investigated both parts ? (not that I saw ths advised to you, but that's why I do it now Happy). Maybe I am not even right with it, but ... please investigate it.
« Reply #22 on: May 13, 2018, 07:58:48 am »
OK, I see that Anthony did point it out for sure. But the mistake on your side is made very easily because both main entries I refer to look mighty much similar.
« Reply #23 on: May 13, 2018, 08:10:54 am »
Ok Peter thanks I'll take a look later because now hay have to go away home. Anyway the rar file works perfectly and I'm using it only in the server. Couldn't it be better than make the Audio Pc vulnerable? Maybe it is the same, I don't know much about it.
« Reply #24 on: May 13, 2018, 08:12:49 am »
Juan, maybe the opposite;
If you engage that Multi User option (this is an option in there somewhere IIRC), then now people can log into your PC and you wouldn't even notice.
Quite smart eh, for vulnerability.
Ahum.
« Reply #25 on: May 13, 2018, 08:25:18 am »
Peter at the moment that is the only solution I found since I couldn't find out where the registry entry was, I will look later if it is possible to solve it as you said
Kind regards
« Reply #26 on: May 13, 2018, 08:32:23 am »
Juan,
Strange question : do you have the problem (can't make a connection any more) in the first place ?
I mean, I don't have that Group Policy setting either ... in 14393.0.
Now I don't know what you are referring to, but means applied via the Group Policy Editor usually (or most often) won't let apply themselves via Registry changes. Read : they are a combination of appliances (at the same time) with special rigths required. IOW, I don't recall many tweaks which usually require GPEdit that don't need special (API) functions and most often it is a lot of work to get them going.
N.b.: In a Home version we can't even perform GPEdit (it isn't there).
RDPW is such a (very smart) program and all it does it allow RDP where it normally is not allowed. It is in there but not allowed. We need to pay more first. Wink
« Reply #27 on: May 15, 2018, 10:03:38 am »
FYI :
This problem extends way further than RDP only and it affects all kind of authentication (log in) issues. This is what I get from my ERP life (customers not being able to connect to databases etc.).
I think I wil have more info soon and also more "solution".
« Reply #28 on: May 15, 2018, 10:35:04 am »
Well Juan, there is one after all.
HKLM\SOFTWARE\Microsoft\Windows\CurrentVersion\Policies\System\CredSSP\Parameters
"AllowEncryptionOracle"
The bold part may not be there yet, so create that yourself if necessary. The "AllowEncryptionOracle" is the Key to make. Give this the (DWord) value of 2.
Watch out : I noticed inconsistent behavior with a system which allows you to change the Group Policy Entry as denoted by Anthony (acg) while it does not work. So, when set to "Vulnerable", for systems where it does not help the Key receives a value of 0 (while 2 is the value which helps).
Notice : When you need to create/change this Registry Key in order to let RDP work again, *and* you first configured the "Oracle" Group Policy Value, it is best to set this Group Policy to "not configured" again, to avoid additional inconsistency; when you indeed had to apply the latter, be sure to again add the Registry Key because it will be gone now.
So the situation which seems to be consistent (for as long as it (Windows Updates) takes is :
1. Have the Group Policy "Oracle" value Not Configured.
2. Give mentioned Registry Key a value of 2.
This sustains after a reboot.
« Reply #29 on: May 15, 2018, 10:43:58 am »
Still struggling with this problem, yesterday the rar file stopped working
Page created in 0.131 seconds with 19 queries.
