Network software driver settings make a big difference to sound quality. The context for trying the tweak that follows is an XX replay system that makes use of an ethernet network connection between a Music Server and Audio PC to pass music files and support remote desktop access to the Audio PC. Sound will change I think with XX software playing in Attended Mode or Non Attended Mode despite the network being turned off in non-attended mode.
The tweak is to force the ethernet connection speed between the two PC down from 1GB (which most systems will default to if left to auto negotiate ethernet speeds in control panel) to the lowest speed of 10Mb/s.
I set this up a few days ago with the thinking that the Network Adaptor and its software drivers on the Audio PC generate masses of hardware interrupts (that influence sound) and the adaptors software driver will register different resources and possibly it and the adaptors hardware process requests at different speeds depending on the ethernet speed that is set up.
The tweak is quite simple to try.
On the Music Server PC in Control Panel > Device Manager > Network Adaptors double click the network adaptor that is used to connect to your Audio Server. In the Advanced tab go to the Speed and Duplex property. It will probably be set to Auto Negotiate (in which case you are probably getting a 1Gb/s ethernet speed if both PC can support his). Change this to 10Mb/s Duplex (you can try 100Mb/s also) but 10MB is where the magic is here for sure.(I am running a few other network related Advanced settings which may also add to this but I think the link speed alone will make a difference).
Sound quality is best summed up:
CLARITY and fine detail ! (in very natural and good way), Pace and PRESENCE improvments. I am really quite shocked by the difference here. And it influences sound in both XX Attended and Non-Attended modes although to differing degrees.
Be prepared to wait for your music to transfer from your Music Server to your Audio PC (the link in theory just got upto 100 times slower) so it takes longer for music to start but here is massively worth a few extra seconds wait
It may be that others are already doing this and I missed it, but give this a try and let me know what you make of it.
One foot note, Bass may be ever so slightly softer or perhaps everything else go so much better, or maybe is not really changes cannot make up my mind yet.
