April 05, 2025, 10:49:58 pm *
Author Topic: Playback issues with MQA  (Read 16843 times)
« on: April 18, 2018, 10:40:25 am »
There are a few issues with MQA playback.
Firstly after hitting play actual playback takes 1 to 1.5 mins (Unattended). Is this normal?
Secondly quite often one or two tracks don’t play from the album & when I bring up XXHE I see that playback has stopped. Now these same tracks if played attended have no issue.
Thirdly I do hear ticks while playback, not in all tracks but randomly in some & inconsistent. My X Tweak settings are balance power 43/Nervous Rate 18. Rest of the settings are as per signature.
« Reply #1 on: April 18, 2018, 12:19:41 pm »
Hi Arvind,
Supposed that one track of that is e.g. 60 minutes, yes.
So that assumed apart from the ticks the remainder is explained as well because you won't have sufficient memory for that. Remember, this expands to Hires and although one track of 60 minutes (or a full album of that length) would fit normally, radically more than that will not.
If playback has been stopped and from there you quit XXHighEnd you could look at the free disk space to see whether something occupied space which you don't want/knew. I forgot the number but I think at least 2GB of free space should be there (on C:) and if not, that will be the problem.
This can be because now all don't need to fit in memory at the same time.
It won't be so that your Logging is (still) On, right ?
Otherwise I have no idea at this moment. All I can tell is that thiss is Hires and therefor requires a bit more and you may not be used to that. But, difficult to suggest this for real because your settings look fine and the PC you use should also be up to the task. Maybe try with the Balanced Load at 62 because I still don't know for sure what I have been using with that same PC and it very well can be 62 (now it is just a tad faster which is good for the (much) higher data rate which needs to be processed.
Let me know whether that helps.
hudesigns
« Reply #2 on: April 18, 2018, 08:08:59 pm »
I did notice that with NormalizeVolume on, it takes some time to load the first time you play an album. With MQA tracks on top of that, it does seem very long time. But this may not be Arvind's situation...
ZH
« Reply #3 on: April 19, 2018, 04:30:38 am »
I think it is. Very well noticed, Zheng !
And that also occupies extra (lot of) memory because always the whole album is Normalized - not only one track. Well, assumed the Normalization is not set to "per track" (which is possible but not advised).
« Reply #4 on: April 19, 2018, 07:01:50 am »
The MQA albums, which take long time to play, are all normally not more than 50mins with the longest track being not more than 10 mins. However it still takes 1 to 1.5 mins for playback to start, even after vol normalisation.
The free space available in C: drive is around 2.5GB.
The tick seems to have gone away after setting balance load to 52, however I still need to listen to more albums to confirm that.
Best regards
« Reply #5 on: April 19, 2018, 08:07:42 am »
Arvind, how long takes a normal FLAC of the same length (or a little longer) ?
« Reply #6 on: April 19, 2018, 08:11:52 am »
Maybe you don't have Boost at XXHighEnd Startup (something like that) active ? That would explain it ...
« Reply #7 on: April 19, 2018, 01:19:15 pm »
Similar FLAC album takes around 15/20 seconds to play. However at the start of first session even a FLAC album takes around 45/55 seconds.
“Boost at start” is active.
“Log activities” is off.
« Reply #8 on: April 19, 2018, 03:06:20 pm »
I am sorry Arvind - I was not asking for that. I asked the time it takes to start playback for a 10 minute or more (not less) normal FLAC track.
Thanks !
« Reply #9 on: April 19, 2018, 03:38:55 pm »
Thanks !
10 secs for a 17 min FLAC track.
« Reply #10 on: April 19, 2018, 06:47:57 pm »
OK.
I don't know whether that is consistent.
I assume that the whole album which loads in 15-20 seconds does not contain even one track of 17 minutes (which loads in 10 seconds as you say). Do notice that the longest track determines the load time, as long as you have 20 tracks or less. Same counts for MQA decoding (which I think can take 60 seconds for a 17 minute track).
So with the knowlegde of this "the longest track" etc., you kind of claim that with Attended this one track goes faster than when this same one track is started for Unattended (as the only one - make it the last in the Playlist Area for your comfort).
I know, you are not saying this, but it is my conclusion. So please test this, OK ?
« Reply #11 on: April 19, 2018, 08:14:11 pm »
The album (FLAC) is 36mins/6 tracks/longest track 17 mins. Last track is the 17min track.
Test 1: Unattended/Long track in last position.
Playback starts in 15 secs.
Test 2: Unattended/ long track in 2nd track position.
Test 3: Unattended/only long track in playlist
Playback starts in 13 secs.
Test 4: Attended/only long track in playlist
Playback starts in 10 secs.
« Reply #12 on: April 20, 2018, 06:35:03 am »
In addition to the above trials, I prepared streams of the same album in FLAC & MQA. Unfortunately they don’t seem to be from the same master as the track lengths are slightly different, but not by much. The longest track is just over 6 mins.
Playback with the FLAC started in 13 secs whereas the MQA took 78 secs.
« Reply #13 on: April 20, 2018, 07:50:32 am »
Arvind - Super !
I didn't want to put this burden on you. But, it is the easiest thing to try out now myself. So ...
Which album is that ?
Additionally, what is your Core Appointment setting, and what are the two Priority settings ? (something with player and thread).
And to be sure, the Balanced Load nr you use for this ?
« Reply #14 on: April 20, 2018, 08:57:19 am »
I think you mean the same album in FLAC & MQA, it’s Natalie Merchant/Tigerlily.
Core appointment is 3-5
Player priority is Low
Thread priority is Realtime.
Balanced Load is 52
Nervous Rate is 18
