November 22, 2024, 10:27:13 pm *
Author Topic: 2.10 "Crucial commands" status ?  (Read 7335 times)
Tore
« on: April 01, 2018, 07:50:08 pm »
how is it with 2.10 and "immediate response to crucial commands" ?
I had to skip this in a earlier version, i think it was problems with  the volume in UnAttended
Tore
« Reply #1 on: April 02, 2018, 09:22:50 am »
Hi Tore,
Nothing changed that I can remember. But there's also nothing really crucial for practice use. It is only that Pause does not work (well, it works, but resume will start all over with the track). Somehow this failed to be in the ToDo for 2.10 (and I let it be for an earlier version - so my bad). I put it in the ToDo for the next version now.
Assumd that my text above already was some answer, I don't know what you mean by that ...
Tore
« Reply #2 on: April 02, 2018, 11:16:04 am »
Thanks Peter, then i will test it again
Can you tell me how to get it back (don`t remember)
Tore
« Reply #3 on: April 02, 2018, 01:19:11 pm »
Tore,
how to get it back
Get what back ? Sorry but I don' understand. I already didn't and you didn't answer my question about it ... so now I am at a "total loss".  Happy
Ah ... wait ... you mean the VolumeForNoWallpaper.tst file ??
Rename back to VolumeForNoWallpaper.tss.
But I did not change anything about that !
So if you want no Wallpaper Coverart then you must leave things be as they are ...
Tore
« Reply #4 on: April 02, 2018, 01:36:29 pm »
Yes, this is what i meant
But i have VolumeForNoWallpaper.tst and VolumeForNoWallpaper.tss in my XX folder ?
Can i delete VolumeForNoWallpaper.tst to get back immediate response ?
Tore
« Reply #5 on: April 02, 2018, 01:53:58 pm »
Yes you can !
BUT you must activate the Showing of the Wallpaper (OSD is not necessary). Or else you won't get any repons at all. Wink
Hmm ... that's actually an anomaly of the UpgradePatch mechanism as we use it these days. It coincidentally is harmless but it sure is confusing as well.
So let the .tss file be (for maybe a next time).
