« Reply #15 on: April 30, 2018, 09:55:51 pm » |
I thought Peter might have been becoming a part-time priest  But good to know his Sundays will be taken up not servicing a congregation, but... well... us! Mani.
« Reply #16 on: May 01, 2018, 04:08:09 am » |
I am a full time priest. Just got up early to practice today's preaching. I better go to sleep again ...
Beauchamp Michel
« Reply #17 on: May 03, 2018, 01:25:45 am » |
Well Fred, congratulations. You will go into the books as the first. OK, not really because the one now (about) finished is for someone already but he gently forced me into this. Well, that someone is me.  Please let me introduce myself. My name is Michael, from Montreal in Canada. My first language is French so please be indulgent with my writing.  It’s the first time that I participate to a forum although I have been an avid reader of them for a long time. Audio reproduction has always been my main hobby. As many of you it all started when I was a teenager, quite a long time ago. See my signature for a summary of my current audio chain. Obviously, the weak link in this chain is the source (Mac mini and Chord Hugo). Although I pushed the Mini and the Hugo almost to their limits with the mods I made over the years I knew I was still short of what I was really looking for, musically speaking. The sound was good, sometimes very good (specifically during night time) but I felt something was missing. To make a long story short after a lot of reading I became convinced that a R2R NOS DAC would give me what I was looking for. So in February I contacted Peter and then started a long series of exchanges that lead me to order the NOS1a/G3 and the Stealth II PC with the Xeon 2640. However Peter quickly realized that the Xeon 26xx family had been recently put out of the market and replaced with a new generation of CPU, the Xeon 61xx family. This is how the Stealth III necessity appeared, out of a specific order for a Stealth II. Then began the long and sometimes painful R&D process for Peter. I won’t go in details on the hurdles he went thru during this journey but I’m sure very few people would have succeeded in putting together this new generation based on a genuine server platform and the unique specs of the Stealth requirements. Thanks Peter. Six weeks ago I received the NOS1a and connected it to the Mac mini with XXHighEnd 2.10. Well there is no comparison with the Hugo fed with the same Mini and HQP. The first minutes I heard it I knew I had made the right choice. And I know that everything will be multiplied a few fold when I receive the Stealth III which should arrive sometime next week. Although I don’t have any reference with the previous Stealth generations for comparison, I’ll post my comments after a few listening sessions. I think my amplifier and beloved speakers will be pushed in territories in which I’ve never heard them before. p.s.: thanks to the members of this forum who regularly post comments and questions (Manisandher, Nick, ACG, Arvind, Juanpmar, just to name a few). I’ve learned a lot in reading your posts on the Phasure site and others. You played a role in my decision making.
XXHighEnd Mach III Stealth LPS PC -> Xeon Scalable 16/32 core with Hyperthreading On (set to 10/20 cores) @~660MHz, 48GB, Windows 10 Pro 64 bit build 14393.0 from RAM, / Engine#4 Adaptive Mode / Q1/-/3/4/5 = 15/-/1/1/1/ Q1Factor = 20 / Dev.Buffer = 4096 / ClockRes = 15ms / Memory = Straight Contiguous / Include Garbage Collect / SFS = 0.69 (max 0.69) / not Invert / Phase Alignment Off / Playerprio = Low / ThreadPrio = Realtime / Scheme = Core 3-5 / Not Switch Processors during Playback = Off/ Playback Drive none (see OS from RAM) / Always Copy to XX Drive (see OS from RAM) / Stop Desktop, Remaining, WASAPI and W10 services / Use Remote Desktop / Keep LAN - Persist Yes / WallPaper Off / OSD Off (!) / Running Time Off / Minimize OS / XTweaks : Balanced Load = 35 / Nervous Rate = 10 / Cool when Idle = n.a / Provide Stable Power = 0 / Utilize Cores always = 1 / Time Performance Index = Optimal / Time Stability = Stable / *Arc Prediction Filtering (8x)* / Always Clear Proxy before Playback = On / USB3 port #4 -> Lush^2*A:B-W-Y-R, B:B-W-R* USB 1m00 -> Phisolator 24/768 Phasure NOS1a/G3 75B (BNC Out) async USB DAC, Driver v1.0.4b (16ms) -> B'ASS Current Amplifier -> *Blaxius^2 A:B-R, B:B-R* Interlink -> AVM SA8 -> LEEDH E2 Speakers + Blaxius -> LEEDH SUB 20.1 AC Power: 3 x Dedicated lines for: Amp., PC + DAC and Sub / 3 x Topaz Ultra Isolation transformers 1.8kva in Balanced mode (0.0005pf); Music Server: Mac mini 2011,; Music files on USB Stick; Mac connected to house Router/Hub with copper cable; Router/Hub: Ethernet cable to TP-Link MC200CM Fiber Media Converter to Stealth III PC Other: AC line filtering with Perfect Path Technologies The GATE, EMat+, ECards, Stop Its; MAD Scientist Black Discus NANO.
« Reply #18 on: May 03, 2018, 01:45:53 am » |
Hi Michael, yes, you start strong  . I'm sure you'll enjoy it a lot and I hope you'll share your new emotions soon.  Juan
Beauchamp Michel
« Reply #19 on: May 03, 2018, 02:01:19 am » |
Hi Juan - Of course I will.
Arjan
« Reply #20 on: May 03, 2018, 07:45:56 am » |
Hi Michael, Nice story and the best choice you could make! Now I understand that the CPU is from the gold serie and not the silver serie. So in therms of CPU it is really a step up from the 26-serie. Peter, am I right? Any thoughts on this decision? Regards Arjan
« Reply #21 on: May 03, 2018, 08:14:42 am » |
Hi Michael, welcome! Look forward to hearing your thoughts on the Mach III. I think all of us are very intrigued.
For my own part, I can't imagine how the sound could possibly improve over what I have here right now. I recorded my 8 year-old practising his piano the other day. Playing the digital files back on the system, it was like the piano had been transported into my listening room (apart from the obvious noise from the mic preamps).
But somehow the sound always seems to go up another level when Peter comes up with something.
Beauchamp Michel
« Reply #22 on: May 03, 2018, 01:12:22 pm » |
Arjan - I don't want to step too much on the technical ground, I'll let this to Peter. However regarding the CPU I think that I can safely say that this first Stealth III will bear a Xeon 6130 from the Gold Series. It's a 16/32 core processor.
Mani - The comments I will make on the SQ with the Stealth III will be based on my own experience. Unfortunately I won't be able to comment in relative terms compared to the Stealth II. I went pretty far with the Mac mini and the various software to minimize the PC influence on the SQ. On that side I found something interesting recently. Six months ago for the first time I tried a few Linux audio player software. To my surprise I found the Euphony player to sound better than HQP. The sound was more detailed and more musical. This came as a surprise to me given that Euphony doesn't do any upsampling and that there is no additional software to tweak the PC. With HQP running from RAMDisk there was upsampling at 352khz, Audiophile Optimizer, Fidelizer and Process Lasso software to minimize the PC noise. The OS was Windows Server 2016.
On another matter, is there anyone on this forum having experience with the LEEDH E2 speakers?
Regards - Michael.
« Reply #23 on: May 03, 2018, 06:27:06 pm » |
Hi there Michael. From me too a warm welcome here. And yes, you caused me quite a project here. But it will be worth while for the next 2-3 years. Minutes ago I performed the very last things to do, like making your RAM-OS Disk ready with the settings I like (SQ) best myself. High Resolution link XXHighEnd Mach III Audio PC 10So that's her - only yours. And with special application, as you can see. High Resolution link XXHighEnd Mach III Audio PC 11Thanks a lot, kind regards and never do this again please. Haha. Peter
Beauchamp Michel
« Reply #24 on: May 03, 2018, 07:06:51 pm » |
...never do this again please. Well, Peter forgive me but I involuntarily put you to test.  However I believe you accepted this challenge because it was just that...a challenge, with the potential of new ground breaking for an Audio PC. And now the baby is born, he's beautiful and full of promises. Nice picture. I Can't wait to see the UPS truck in the driveway next week. Thanks again - Michael
« Reply #25 on: May 04, 2018, 06:00:40 am » |
Hi Michael,
Warm welcome to the forum. I’m sure you’ll be very happy with the equipments/support provided by Peter & above all the high level of SQ you will be enjoying in the times to come.
fmanheck
« Reply #26 on: May 04, 2018, 01:13:16 pm » |
Hi Michael Welcome to the forum...even if you are really the first  Once I receive the Stealth MACH III I will be able to compare the SQ of both. I am also having a spare NOSI upgraded. I will probably let that burn in with a second system. My guess is it will take some time to break in as did my first G3 upgrade. It's nice to have options  I have not heard the LEEDH E2 speakers. From what I have read they are excellent and quite unique. Who knows, we are only 4 hours apart as I am in southern New Hampshire. I'll check my system description as I have made some changes. A bit more traditional but it sounds quite good. Looking forward to hearing your comments.
MACH lll PC 14/28 / RAM OS 10493/ 2.10 Phasure NOS1a G3 24/768 USB DAC KS mode -Adaptive/Device buffer -4096/DAC is 32bits 768khz/DAC needs -32bits/Phase Alignment - NO/Format Change - enable/ Decode HDCD ON/Processor Core Appointment 3-5/Player Prio LOW/Thread Prio Real Time/Clock Res 15ms/Xtweaks 64,1,1,0,1/ SFS 5.19 MAX 120/Include garbage collect ON/Copy to XXdrive by standard ON/Stop Desktop ON/Stop Remaining ON/Stop Wasapi ON/Keep LAN ON/Use remote desktop ON/Persist ON/OSD ON/Coverart show Wallpaper, show back, at attended, show mirror back/ Q1,3,4,5,xQ1-30,1,1,0,1/40/ Amp: Music Reference RM200 HC version / Speakers Omega HO Alnico Monitors with Audio Smile Super Tweeters Bass augmented by 2 GR Research OB subwoofers
briefremarks
« Reply #27 on: May 04, 2018, 07:17:16 pm » |
Michael,
Welcome to the forum. Curious to hear reviews from those presently using Stealth II on the improvements with Stealth III. Stealth II was definitely an improvement over the original XXHE PC, BUT so much else improved (NOS 1a upgrades, XXHE upgrades, Blaxius, Lush, etc.). What you will find is there is no other system of products out there that has this kind of continuous upgrade path built in.
Looked up the LEEDH E2 speakers. Seeing 81dB (or 83dB) efficiency made me a bit concerned. My experience is that speed, clarity, dynamics are hard to accomplish at these efficiency levels. Not sure there's anyplace to listen to them in San Francisco. The Orelos by the way are utterly fantastic!! You have to hear them.
Again welcome,
Ramesh
« Reply #28 on: May 04, 2018, 10:29:06 pm » |
maybe I missed the info:
RAM -OS still with W10 or ....?
« Reply #29 on: May 05, 2018, 08:47:35 am » |
RAM -OS still with W10 or ....? Hi Joachim, Definitely still with W10 and definitely all the very same (setup / configuration). But yes, I am guilty of making a usual first-post-chaos of matters which are so-called true (on April 1). At some stage I will revisit the first post and make a nice summ-up of all what is in there. But ask ahead anyway ! The Stealth III is really there. And seriously for the better, but I held a bit back of that so far. Maybe in a next post ... KInd regards, Peter
