April 01, 2025, 12:20:23 am *
Pages: 1 2 3 4 5 6 7 [8] 9  All
Author Topic: Phasure Mach III Audio PC with Linear Power Supply  (Read 194262 times)
« Reply #105 on: March 12, 2019, 02:32:53 pm »
Does this mean that those who have the 14/28 Mach III should attempt setting the cores to 12/24 & see if it’s better than their existing core settings?
Best Regards,
« Reply #106 on: March 12, 2019, 09:33:05 pm »
Hi Arvind,
No. Or at least I don't know because I never tried that (but you can Happy).
Btw, notice that the 12/24 explicitly sounds "bad" when it is set at its full "core power" (12/24). Set to 10/20, it sounds superb to these ears.
Robert
« Reply #107 on: August 16, 2021, 09:27:18 am »
Should I be alarmed my Mach III since latest Xx settings is running temperature wise at 63 to 65c at idle no music. I have 2nd switch down anyway but now on occasions emergency bright light comes on. CPU can take up to 76c I guess continuous. We are in winter with house heating. Should I have 1st switch down also? I normally leave it on 24/7.
Robert
Oppo 205 UDP Dac
JLAudio 12 Active Subs x 2
« Reply #108 on: August 16, 2021, 09:44:35 am »
Hi Robert,
Not necessary to be alarmed because it will keep it under control. Btw notice that the means you use to observe the temperatures will let rise the temperatures just the same.
Point is : with the extra fan power (2nd switch) the sound may deteriorate a little. Will that be noticeable - maybe not. I have it down as well.
If you "mangled" with the other settings (set to 1 and set to 0) and you recognize it is since then, then I would restore those to how it was (they have fairly high impact).
See my settings below which are good to go.
The main culprit could be the Balanced Load set too high (see mine at 62), but notice that when you bring up XXHighEnd after playback, the normally cooling feature - never mind playing - will not be active. Thus, you may test all with XXHighEnd crossed away again (then cooling is again active) and leave it like that when not playing.
This way you can't see temperatures, but you might see the light not coming on now.
I have that light always in sight and I think it is a good habit.
Robert
« Reply #109 on: August 24, 2021, 02:46:43 am »
Hi Peter I'm running your photo of settings didn't make any difference in temp. Anyway here's what I have observed:
Overnight (Idle) temp runs at 56c to 60c with Xx up but not playing with 2nd switch down.
Both switches down temp is 40c no music.
Sound quality is worse with 1st (emergency) switch down during playback but ok with 2nd switch down only.
Temp with Xx playing music 64 to 67c with 2nd switch down.
Tj is 87c according to Temp App.
Is temps of 60 to 67c bad long term for CPU/listening?
Robert
Oppo 205 UDP Dac
« Reply #110 on: August 24, 2021, 10:46:34 am »
Hi Robert,
I assume you know that this is the maximum temperature before the processor will throttle down. If all is right, it should never reach that.
Not at all. It is made to be like that.
What you noticed about the first switch is correct; that is (indeed) for emergency, like being in the BIOS for a long time (that implies running at max) or just having all cool when you are not playing (theoretically it is better for the longevity). Using the switch (down) almost explicitly implies bad sound because of (electrical) oscillation of fans.
Robert
« Reply #111 on: August 25, 2021, 04:08:01 am »
Thanks Peter.
Actually after taking the lid off today and giving all inside a good dust off especially normal fan which was covered plus cooler fins, all is running cooler now by about 10 degrees. It has been a year since new and we had a hot dusty summer.
Robert
Oppo 205 UDP Dac
« Reply #112 on: August 25, 2021, 04:21:57 am »
Yes, this surely (and obviously) makes a difference.
Very well found !
Robert
« Reply #113 on: August 27, 2021, 09:14:52 am »
Have to say running Xx with only 2nd fan switch down temp runs at 46c to 50c. This is 17c lower now.
There is one thing I did which was a number of case holes on the top side were powder coated over. I cleaned these out. I think this has made the difference. These case holes are over the top of the CPU cooler. I actually can't believe the difference in temp now. I mean the dust wasn't that bad inside.
I'm trying the 2nd switch at up now.
Robert
Oppo 205 UDP Dac
« Reply #114 on: August 27, 2021, 02:32:55 pm »
Seriously ?!
Wow, I don't think we ever payed attention to that. But we will from of now !
Thank you, Robert.
Robert
« Reply #115 on: August 29, 2021, 01:02:56 am »
I tried 2nd fan switch up and running temps as recorded 54c to 58c. About 10 degrees hotter than down.
In comparing audio quality between these fan settings very little in it.
I will leave it down as our ambient room temp grows with summer.
This is with an average room temp of 22 degrees C.
I'd recommend anyone with a Mach computer/or other similar should remove dust at least twice a year and check all ventilation case holes are clear.
Robert
Oppo 205 UDP Dac
Muni
« Reply #116 on: September 23, 2021, 01:00:24 pm »
Has anyone experienced in unattended mode with shortcut keys when pressed Alt-N to get to the next song - that it starts playing a few seconds - then stops and starts again....
May be something in the settings that might avoid that - also sometimes it does not go to the next song but the one after it...
Thank you
Muni
Robert
« Reply #117 on: September 23, 2021, 11:00:28 pm »
I find the shortcut keys quite sensitive to touch. Short and sharp strokes otherwise it can jump to next track or stop then start.
Oppo 205 UDP Dac
Stanray
« Reply #118 on: September 23, 2021, 11:11:43 pm »
Yes, I experience the same, ever since model 2.11 I think.
It doesn't really bother me, but if it can be avoided, it would be nice.
Stanley
Muni
« Reply #119 on: September 24, 2021, 09:50:00 am »
I don't use an Ipad - in so far shouldn't happen with the mouse....or?
