April 01, 2025, 12:23:01 am *
Author Topic: New BIOS setting (XXHighEnd PC Mach II)  (Read 24666 times)
Tore
« Reply #15 on: March 30, 2018, 09:41:13 am »
Last time i entered Bios i was in MinOS
Is that OK ?
Tore
« Reply #16 on: March 30, 2018, 11:14:52 am »
Tore, the BIOS doesn't know about MinOS as such.
So no, that does not matter. Happy
Arjan
« Reply #17 on: March 30, 2018, 11:27:06 am »
With the CPU ratio on default Auto the base CPU speed seems higher. Is that true? If so 43 will result in a higher CPU speed then before. Or is that a wrong assumption?
regards
March, 2024 (2.11)
« Reply #18 on: March 30, 2018, 02:22:34 pm »
Hi Arjan,
Yes, that is what I would assume too. But I don't see that happening. But careful : for net result when playing with XTweaks acative.
So yes, the by XXHighEnd "boosted" speed is higher (when XXHighEnd is up) but this is only comfortable.
And if you don't use XTweaks at all, it also matters.
One more thing to be careful about : For me this has been an ad-hoc change possibly not 100% all the way thought over. So I most certainly won't be the know-it-all here. So keep 'm coming ...
Tore
« Reply #19 on: March 30, 2018, 08:10:12 pm »
i have done pkt 1-5 and it looks OK
Still on 18, processor speed 1800
Tore
« Reply #20 on: March 31, 2018, 09:22:26 am »
OK Tore. So that was false alarm, right ?
Tore
« Reply #21 on: March 31, 2018, 09:37:21 am »
All Core showed 24, i don`t know why
Tore
« Reply #22 on: March 31, 2018, 10:50:13 am »
Can you even enter that ? I recall that if I put the "native" speed in there, it will jump to Auto by itself. But maybe that is in my imagination.
Interesting point is that I started working on this myself (see first post in this topic) because of such a thing. I just noticed that Turbo Boost was on (in the live environment (OS booted up)) which can't be, officially. So the MoBo apperently was capable of booting into that mode, no matter Turno Boost should be off *because* the Ratio was not set to Auto. Understand ?
I also saw exactly what happened in that one situation (I saw it happening only once) : I rebooted, system went normally off, went on, went off again and went on again. And then Turbo Boost was on. Normally this goes unnoticed, but I was working on a problem with that PC and so I saw it happening.
So Tore, what you observed may or may not have come from loading that XX01 but I feel that even without this loading (while it already was loaded of course) this can happen. But I never saw it before (which once again : is coincidental to observe to begin with).
I wouldn't pay attention to it. But if you suddenly see your white led being On while at other times that never happens, then you can bet that Turbo Boost is On "unsolicitedly".
Thank you for the feedback !
