« on: March 27, 2018, 09:16:36 am » |
To all owners of the Mach II XXHighEnd PC :
Because I am struggeling with one of the PCs a little, by sheer accident I found a setting which made me think "wait ...".
Under Advanced, in the CPU tab, we normally adjust the Ratio. That is, we over here do that for you new owners. I did this (already with the old XXHighEnd PC) so the speed of the processor becomes "fixated" to something which will not engage Turbo Boost. Then I had this problem with one of the PCs and that PC told me that Turbo Boost could engage anyway. Huh ? By also accident I learned the other day that Turbo Boost can also be disengaged explicitly. OK, this is in another motherboard, but with that knowledge I started looking for that in this PC. Well, easy to find because it is there all in the wide open (a few lines below the Ratio). So I set that to "Disabled" and for this PC it helped.
Because Turbo Boost officially can't be engaged with the Ratio is set to other than "Auto" I got the idea that maybe it always does something, or tries to do something (this latter could even be worse). I mean, also in my own Stealth, and of course yours. And who knows we could improve SQ by means of now explicitly turn it off.
Well, I don't know about you, but for me it is a whole of another world again. I am not sure it is for the better in the end, but I feel it inherently is and if it isn't (apears not to be) for net result, it is something else which requires attention now.
So I feel that this imlpies a next dimension of tuning for the again better SQ.
« Reply #1 on: March 27, 2018, 09:18:41 am » |
PS: Might you have the idea of having messed up in the BIOS, there's a save version for everbody under the "XX01" name. You can chose it as "Restore from disk" or something like that (you will easily find it when it is needed).
Regards, Peter
Tore
« Reply #2 on: March 27, 2018, 01:28:15 pm » |
when i disable Turbo Boost in Bios CPU Ratio goes from All to Auto. It is posible to turn CPU Ratio back to All, Save and Exit But if you go back to Bios Turbo Boost is back to Enabled ?
Tore
Phasure Mach III, 12/24 core (Win 14393.0 on RAM-OS / controlled by RDC, / connected directly to music server / XXHighEnd 2.11 / Minimize OS / Engine#4 Adaptive / DB=4096 / Q1=10 / xQ1=15 / Q3,4,5=1 / SFS=0.69 max=140,19 /XTweaks = 35, 10, 0, 0, 0 / Straight Contiguous / Clock Resolution = 15ms / Scheme 3-5 (low/realtime) / Unattended) mobo USB3 port -> Lush^3 -> Phasure NOS1a B75 G3 -> Blaxius^2.5 , Crazy A monoblocs, Avantgarde Duo Omega
« Reply #3 on: March 27, 2018, 06:12:44 pm » |
Hi Tore,
Yes, that is what I noticed too, but the net result after booting and "XXHighEnd interference" is the same as with the Ratio set.
I don't know yet where the difference is, but with my own Stealth I can set both the Ratio and disable Turbo Boost at the same time. I can't imagine that the MoBo matters, but of course mine is two years old by now and yours is only a couple of months old (similar to the other PC which behaves like you describe).
Best regards and thank you for sharing, Peter
Tore
« Reply #4 on: March 27, 2018, 07:49:42 pm » |
This time Turbo Boost stayed at Disable :-)
Will test it now
Tore
« Reply #5 on: March 28, 2018, 08:36:02 am » |
Tore,
What did you do for that ?
Thanks, Peter
Tore
« Reply #6 on: March 28, 2018, 10:47:07 am » |
1. Turbo Boost : Disable 2. CPU Ratio : back to All Core 3. CPU Cache Ratio : 18 4. BCLK frequency : 96 (lowest possible)
Does it look OK ?
I think it was not done anything with the CPU speed when i got my PC (nothing under "XX01" )
Tore
« Reply #7 on: March 28, 2018, 02:43:25 pm » |
(nothing under "XX01" ) What ? ... OK, that implies we forgot that. This is possible. So you mean that you can't find any XX01 to load back, while you sure found were to be for that ? (like Save to Disk is also an option) ? I think it was not done anything with the CPU speed when i got my PC This is already less plausible because I test this all myself. Still can happen, but now it would mean two subsequent errors. Normally we make none ! haha Really ? 1. Turbo Boost : Disable 2. CPU Ratio : back to All Core 3. CPU Cache Ratio : 18 4. BCLK frequency : 96 (lowest possible) For the answer to my question "how ?" The crucial part seems to be missing - how do you end up with Turbo Boost disabled and the ration not to 100. But also : you talk about "Cache" Ratio, and that is not right ... Regards, Peter
Tore
« Reply #8 on: March 28, 2018, 05:40:36 pm » |
I did pkt 1-4 , after that Turbo Boost stayed at Disable
Now i have loaded XX01 in Bios. Then CPU Cache Ratio and BCLK frequency is back to Auto. (this is why i tought it was not done anything with CPU speed)
After that i have only changed Turbo Boost to Disable and CPU Ratio back to All Core.
When i enter Bios Turbo Boost is still Disable
Tore
« Reply #9 on: March 28, 2018, 05:52:40 pm » |
Hi Tore, All I asked (or told about) was setting TurboBoost to Disable. Of course you can drag in a 200 other settings in the game (you again mentioned something else) but this is nit what I wanted anyone to do. For now (if you want to play with this setting at all) : 1. Load back XX01; 2. Disable Turbo Boost; 3. Save and reboot. Then you have the same as I do (if you leave all other settings alone  ). Best regards, Peter
Tore
« Reply #10 on: March 28, 2018, 06:07:18 pm » |
Yes, that is done
The other things i did was because it looked like Turbo Boost was going back to Enable
But not now :-)
Arjan
« Reply #11 on: March 28, 2018, 08:09:09 pm » |
Just to be sure:
Only disable Turbo Boost and CPU Ratio will reset to Auto? or Disable Turbo Boost and CPU Ratio back on All Core and All Core on 18.
regards, Arjan
« Reply #12 on: March 29, 2018, 06:59:12 pm » |
Hey Arjan, Disable Turbo Boost and CPU Ratio back on All Core and All Core on 18. If all is "normal" (?) that doesn't work. This one does and is fine (as far as I myself can see) : Only disable Turbo Boost and CPU Ratio will reset to Auto? Regards, Peter
Tore
« Reply #13 on: March 29, 2018, 07:18:33 pm » |
All Core was goling from 18 to 24 after the last XX01 load
Is this normal ?
Tore
« Reply #14 on: March 30, 2018, 09:04:46 am » |
Hi Tore, No, not normal. But you said similar in the beginning (of this topic) but then I couldn't understand (or believe). Maybe I still can't believe it.  Try this please (and nothing else) : 1. Set to 18 again. 2. Save the settings (normals Save BIOS procedure). If it implies a restart that's OK but go into the BIOS again. 3. Use the "Save" function and now enter a name like XX02. Enter saves it (also see instructions in the right hand side). Do NOT overwrite XX01 ever. 4. Restart and go into the BIOS again. Do you still see the 18 ? (but also notice the speed the processor runs at - this shows in the top. It will not be 2400 if all is rright. 5. Load back the XX02. And now you sort of say that the 18 has disappeared and has changed to Auto again ? Restart to make whatever it is effective. Go into the BIOS again. You should be in the state of which you claim it happens after loading back XX01. ... Which I don't believe. So now you have done this : 6. Load back XX01. Restart to be sure what's in there for sure. ... And I say that all is fine and it shows 18. But is it ?  You can leave the XX02 be. But if XX01 does not work for you, then XX02 does for the future. Best regards, Peter
