April 19, 2025, 06:04:07 am *
Author Topic: Model 0.7h play button not able to start  (Read 10057 times)
hal3101
« on: June 04, 2007, 01:56:34 pm »
Downloaded the 0.7h version and is not able to press play button. The button is grey all the time. I load a track but nothing is happening. The previous version is ok.
Home build pc, Intel Dual core 4300 1.8 GHz , Vista Business, 2 GB RAM, one 500 GB harddisk, Q1 -3 with checked invert, appoint processor cores checked, Engine 3 checked, Double and upsamp NOT checked -> USB DDDAC -> TVC -> 300B -> Oris 200
« Reply #1 on: June 04, 2007, 03:47:40 pm »
Hmm ... I'm not aware of this !
Do you load the tracks via the Library button, or by means of dragging from Explorer ?
« Reply #2 on: June 04, 2007, 04:45:36 pm »
I've tried it on my PC both ways and I can play...and using all Engines too.
No problem.
hal3101
« Reply #3 on: June 04, 2007, 05:04:59 pm »
Strange. Dragging from Explorer seems ok but when i use the library button it is not ok.
TorH
« Reply #4 on: June 04, 2007, 05:44:00 pm »
You're right. It doesn't work with me either ...  unhappy
« Reply #5 on: June 04, 2007, 06:00:44 pm »
It does work after loading the first track by dragging the file. With an empty play area the libary functin does not work here either...
« Reply #6 on: June 04, 2007, 06:31:10 pm »
Solved.
http://www.phasure.com/index.php?topic=41.0
