Rmalits
« Reply #45 on: April 26, 2018, 07:39:44 pm » |
on my audio PC Stealth Mach II (with XEON E5 processor) turbo boost looks like being on, because I see up to 3.3 GHz. When playing in unattended mode the speed goes down as it should: e.g. 0.86 MHz with Balanced Load set to 36. Is this ok like this? Or shall I try to disable turbo boost in the BIOS settings? (I never changed anything yet in the BIOS of this PC)
Kind regards Richard
« Reply #46 on: April 27, 2018, 09:12:26 am » |
Hello Richard,
Strange. But also the second time I run into this (was the first time mentioned on the forum, 3 weeks or so ago ? - maybe not).
So somehow this can happen and I saw it myself with a Stealth over here. I think this can happen with a strange (re)boot. Thus, if you'd be able to watch closely, the system boots, shuts off again (fans stop - not that you will have fans running in there anyway), and 3 seconds later boots again. That was the situation I saw that after that Turbo Boost was active. Saw it one time, but maybe it happens more often; normally I don't watch out for this.
Question : Is Turbo Boost still on after another reboot ? If it remains like that I'll guide you through the process of changing something in the BIOS. OK ?
Best regards, Peter
Rmalits
« Reply #47 on: April 27, 2018, 01:47:55 pm » |
after rebooting the max. speed is now 1.8GHz. Is this value ok?
When playing unattended is goes down as described above.
« Reply #48 on: April 27, 2018, 02:08:38 pm » |
after rebooting the max. speed is now 1.8GHz. Yes Richard, that is what it should be for your Stealth. All OK. Best regards, Peter
« Reply #49 on: April 28, 2018, 03:45:02 pm » |
Haha... 2.10 Bass is back  Just a quick update on my ealier post on 2.09 vs 2.10 base. I was sure I was hearing a large difference in 2.10 output and this was correct. However, 2.10 bass is fixed now and is sounding at least as good if not better the 2.09. I am REALLY pleased with the overall sound, now getting the supper sweet 2.10 mids and highs with epic dry powerfull bass the extends stongly down again in the low bass frequencies. The fix to get 2.10 bass back was two things: 1 Bios settings - needed to set spread spectrum to "on" in bios (x99 mobo). 2 NOS1 - needed to tighten up board connections in my NOS1. This was my fault and shoul not apply to other people. Overall now an sound is EPIC, low bass is back and now better than 2.09  Thank you all for comments and suggestions above in the post. Regards, Nick.
« Reply #50 on: April 28, 2018, 06:10:26 pm » |
rudolf
« Reply #51 on: May 29, 2018, 11:41:19 am » |
 Hi there, just wanted to leave a short message about how I'm pleased with version 2.10 and the sound quality I get, especially with MQA. I have been listening to vinyl quite a time but now I'm back and I'm really surprised, how things went further here: especially the possibility of playing tidal playlists 'on the fly' really means a lot of fun to me these days....and I begin to understand, what MQA is all about...so thanks a lot and keep on with xxhighend!!! ______________________________________________________________________ XXhigh 2.10 on Windows 8 PC (AMD A6-3650 APU 16 GB RAM) - Adaptive Mode / Q1/-/3/4/5 = 14/-/0/0/0/ Q1Factor = 1 / Dev.Buffer = 256 / ClockRes = 1ms / Memory = Mixed/ SFS = 60 (max 120 / Playerprio = Low / ThreadPrio = Realtime / Scheme = Core 2-3 / not Switch Processors during Playback = Off/ / UnAttended / /Stop all Services Off / Stop Desktop and Remaining Services ON/ Keep LAN =off/ Not Persist / WallPaper Off/ Minimize OS / XTweaks : off Advance xi-75 Amp with build in asyncronous DAC - ProAc Studio 130 Speakers
« Reply #52 on: May 29, 2018, 12:22:05 pm » |
Nice to hear from you (like this), Rudolf.
Kind regards, Peter
Robert
« Reply #53 on: July 16, 2018, 12:23:48 am » |
Generally this version operates with the least problems for me with the settings I'm currently using. I have not reversed settings as it all sounds great.
Has anyone tried new settings?
Robert
« Reply #54 on: July 16, 2018, 07:56:48 am » |
Has anyone tried new settings? Even if "they" do, they prefer to remain silent. Must be the weather.  Anyway, I have, but I may not be the most representative by now (Stealth III and such) : SFS=140.19 (don't ask about the .19) and Q1 x xQ1=30 x 11. All other still the same. If possible this brings even more "mid" detail again with the notice I am using the 10-20 core Stealth III version. Maybe you can try it too and maybe it brings you a similar change ? Small warning : I do not recognize anything of this mid or highs etc. special detail from even the Mach II, so posssibly for you there is no change at all, except for what we were used to (and then for Mach II similar to any PC as far as I can/could tell). Still curious though ... Thank you for asking, Robert - by now I feel a bit reluctant in expressing these matters as they could be useless to you all. And still ...  Peter
Robert
« Reply #55 on: July 20, 2018, 03:39:34 am » |
I'm trying these new settings and yes I can hear a difference and so far prefer it. I will run with it for a few days and go back.
Particularly noticeable on minimal good recordings like Jennifer Warnes - Famous Blue Raincoat "Let it be your Will" and Melody Gardot - Live in Europe "Our Love is Easy". The voice/guitar has more depth not as bright, so volume can go up more. Stage bigger, easier to listen.
I have yet to get my guitar/singer wife to give her opinion.
I concur with Fred on his listening reply re the MachIII to these settings. You don't need a MachIII to hear the difference.
Robert
fmanheck
« Reply #56 on: July 21, 2018, 01:44:25 pm » |
When I read Robert's post I had to try the new settings with those exact songs. We have similar tastes Robert, as I love Jennifer and while pretty new to Melody I like her very much. After that I went into some Leonard Cohen himself followed by a few covers of Halleluiah. Sound on all sounded great on the new settings. It was not until I went back that I really could hear the difference. I just could not keep the old settings for very long. It's not that the sound was bad... far from it. It's just my ears got used to something better. Kind of like every time Peter makes an improvement on hardware. Now it' settings. keep experimenting Peter. I am along for the ride
MACH lll PC 14/28 / RAM OS 10493/ 2.10 Phasure NOS1a G3 24/768 USB DAC KS mode -Adaptive/Device buffer -4096/DAC is 32bits 768khz/DAC needs -32bits/Phase Alignment - NO/Format Change - enable/ Decode HDCD ON/Processor Core Appointment 3-5/Player Prio LOW/Thread Prio Real Time/Clock Res 15ms/Xtweaks 64,1,1,0,1/ SFS 5.19 MAX 120/Include garbage collect ON/Copy to XXdrive by standard ON/Stop Desktop ON/Stop Remaining ON/Stop Wasapi ON/Keep LAN ON/Use remote desktop ON/Persist ON/OSD ON/Coverart show Wallpaper, show back, at attended, show mirror back/ Q1,3,4,5,xQ1-30,1,1,0,1/40/ Amp: Music Reference RM200 HC version / Speakers Omega HO Alnico Monitors with Audio Smile Super Tweeters Bass augmented by 2 GR Research OB subwoofers
« Reply #57 on: July 21, 2018, 01:55:14 pm » |
Thank you guys. And Robert, good to know you perceive a similar (or same) kind of sound change.
Enjoy the weekend, Peter
Robert
« Reply #58 on: July 27, 2018, 11:11:39 pm » |
I've run into problems with this setting. Data not arriving in time. I've reduced SFS to 20. I found I preferred Q1 x xQ1 = 30 x 40.
Music was stopping midway through an album.
It has prompted me to try different settings.
Robert
« Reply #59 on: July 28, 2018, 05:15:15 am » |
I've run into problems with this setting. Hi Robert, FWIW, this is also related to a too low Balanced Load setting (in combination with the other settings). Regards, Peter
