« Reply #15 on: March 27, 2018, 09:48:28 am » |
Thank you all for the feedback so far ! I myself, lately, find myself to be in the middle of a new phenomenon : complaints about too loud playing. Not in absolute sense, but to the -in the end logical- sense that people who try to listen through headphones to Games, YouTubes or other, now have difficulty in not hearing "my music" louder. But it will be true ... It now regularly happens that I play 4.5-6dB louder than (I think) prior to the SFS = 5.19 setting, just because it all can have it. It goes more effortless and there seems to be no reason not to put up the volume (says the audio idiot). I also think that "we" may put our volume to limits quite always, where the limits are determined by what's still justified by good sound. And not so much by loud sound. All 'n all we have the odd situation that still nobody complaints when the music is (say 6dB) louder than other times just because there's nothing to complain really (no hurting ears), while at the same time it *is* louder and overvoices anything coming from headphones which or can't be louder or can't be put louder becaus then *that* hurting.  . Strange problem and hard to solve (says again the audio idiot). Peter
« Reply #16 on: March 27, 2018, 10:02:17 am » |
These are settings I've not played with ever. Sound is amazing but I said that 2 years ago, it just keeps improving. Hi Robert, Did I read something about "distortion" which I can't find back any more, or wasn't it you writing this, or did I perhaps dream ? No problem to put it back, if it was you in the first place ! Regards, Peter
« Reply #17 on: March 28, 2018, 11:41:00 am » |
Yes, same, although not as pronounced as in your system. It is an indicator of less distortion IME.
« Reply #18 on: March 29, 2018, 05:12:55 pm » |
In order not to repeat the same adjectives that others, I will say that once again I keep with the new settings. Just point out that I agree that there seems to be a better dynamic and sometimes I have the strange feeling like that the sound is going faster. With respect to leaving the Turbo Boost inactive, I dare not touch anything on the Bios of my Asus mb since I don't have the Stealh Pc, so if someone in my same case experiments with it I would like to know their opinion. Good job Peter!
Best regards, Juan
« Reply #19 on: March 29, 2018, 11:10:32 pm » |
FWIW my first impression:
I think that the SQ with 2.10 with Peter’s settings is quite a boost up from what I was able to archieve with 2.09. This is genuinly the best sound I’ve ever had from my system. Everything seems to be in it’s right place.
As we all know this is ‘the early’ days and who know’s what more is hidden in the settings. BIOS has not been touched.
I do want not dare compare it to pre 2.09 versions since I’ve been working on the PC-DAC setup a lot and SQ benefitted significantly from that.
Regards, Coen
« Reply #20 on: March 30, 2018, 11:51:42 am » |
Every day more happy thanks to the last settings. What a full sound plenty of details!
phantomax
« Reply #21 on: March 31, 2018, 09:00:43 am » |
In my case better with Custom filters than ArcPrediction.
I must rectify: Better with Peter's settings!  Maxi
Audio PC -> AsRock Z79 intel i-3 4170 @~800MHz, 16GB, Windows 10 64 bit build 14393.0 from RAM, DIY Linear Power Supply. music on LAN / Engine#4 Special Mode/Q1/-/3/4/5=*30*/-/*1*/*1*/*1*/ Q1Factor = *5* / Dev.Buffer = 1024 /ClockRes = *15ms* /Memory = Straight Contiguous / Include Garbage Collect / SFS = *0,69* (max 0,69 / Phase Invert / Phase Alignment Off / Playerprio = Low / ThreadPrio = Realtime / Scheme = Core 1-3 / Not Switch Processors during Playback = Off/ Playback Drive none (see OS from RAM) / UnAttended (Just Start) / Always Copy to XX Drive (see OS from RAM) / Stop Desktop, Remaining, WASAPI and W10 services / Use Remote Desktop / Keep LAN - Not Persist / WallPaper On / *OSD Off* / Running Time Off / Minimize OS / XTweaks : Balanced Load = 35 / Nervous Rate = 10 / Cool when Idle = n.a / Provide Stable Power = 1 / Utilize Cores always = 1 / Time Performance Index = Not the best / Time Stability = not stable / *Custom Filtering low for 176400* / Always Clear Proxy before Playbck = On -> Modified Audiotrak Prodigy HD2 internal soundcard with analog tube buffer (Broskie cathode follower) -> Passive biamplification: Canary Audio CA-301 MkII for highs- mids and Counterpoint SA-100 for lows -> Audiovector M-3 Super / modified Musical Fidelity X-3 (6h6p tubes) -> Grado 1000 headphones.
« Reply #22 on: March 31, 2018, 09:25:23 am » |
Arjan
« Reply #23 on: April 02, 2018, 04:35:01 pm » |
Hi All,
Yes, 2.10 is really nice. Just played a bit around with settings, started off from the settings of Peter. But ended with: clock resolution=0.5ms, nervous rate=1 and Q3=0 (again). Very nice low drive and good clearance.
regards
« Reply #24 on: April 07, 2018, 05:43:25 pm » |
Wow, what a difference in sound to 2.09! Here are my thoughts, for what they're worth:
Supreme clarity. Almost holographic now.
HF seems more prominent now. Lots of 'sparkle'. Can be a tad problematic with sibilance on some vocals.
Bottom end doesn't seem to have as much weight as 2.09. It sounds tighter and more tuneful though.
I was never convinced of high Q1 settings and an SFS>1.00 before - the sound always seemed a bit muffled. But with Peter's settings, the sound of 2.10 is anything but muffled.
Overall, I prefer 2.10 to 2.09. A bit more weight low-down would be nice though.
« Reply #25 on: April 07, 2018, 05:48:53 pm » |
A bit more weight low-down would be nice though. For some reason I have more bass than ever. Haha.  Regards, Peter
« Reply #26 on: April 07, 2018, 05:58:35 pm » |
For some reason I have more bass than ever. Well, a bit more would't hurt, would it? Anyway, I should revise my 'sibilance' statement earlier. I don't think there's any issue with sibilance actually. I think it's just the extreme clarity that was a bit of a shock to me. I simply cannot fault the mids and highs I'm now getting. The lows are excellent in quality - I just need a bit more quantity. Mani.
Robert
« Reply #27 on: April 07, 2018, 08:29:25 pm » |
I have more bass as well. I had to reduce output to subs on active crossover which also improved the sound.
« Reply #28 on: April 07, 2018, 08:44:55 pm » |
I also have more bass but above all I would say that the sound is fuller maybe because the bass is better integrated.
« Reply #29 on: April 08, 2018, 10:34:38 am » |
I stayed up late last night listening to all sorts of music. 2.10 with Peter's XX settings is just crazily good sound. Is it down to 2.10 or the new settings? Who knows?
For me, it's the sheer detail that's coming through now that's a bit of a shock. And it's 'real' detail and not fake 'sheen' or anything like that.
I listened to loads of old jazz recordings. The tape hiss is very prominent at the beginning, but as soon as the music starts, it's as though XX is now extracting details below the level of the hiss.
This is a milestone in XX playback IMO.
(Oh, and all my 2.10 listening has been on an old Altmann 16-bit DAC (long story) with spdif input - no USB anywhere. I'll switch back to the NOS1 at some point of course, but am currently really enjoying this sound.)
