« Reply #120 on: January 10, 2019, 02:36:03 pm » |
With these settings, I too find that the sound is not cohesive so I tried inverting phase & it brings the cohesiveness back.
Wonder what could be the reason?
No complaints as I’m enjoying the SQ. The low end is just super.
« Reply #121 on: January 12, 2019, 06:37:18 am » |
Hey Arvind, I changed my Custom filter settings to [low] which brings back body and character to the music. At high or Arc Prediction the sound is too "technical"... at least here on my system. Perhaps you'll like it more too? Cheers, Bert
Robert
« Reply #122 on: January 12, 2019, 07:19:40 am » |
Bert I tried your custom setting but went back to Arc Predict almost immediately. I was outvoted by 3 non HiFi people in the house. I did prefer Arc also. Good suggestion though.
I find custom filter seems to add something which masks the sound somewhat. I'd be wary of tweaking your speakers too soon. Guess you can always go back.
Robert
« Reply #123 on: January 12, 2019, 01:29:18 pm » |
Hi Bert,
I am using custom filter high since some time. Low is nice too. However I still need to invert phase otherwise something is amiss in the music.
« Reply #124 on: January 12, 2019, 01:48:10 pm » |
I have been playing with Peters new settings:
Q1 = 30 xQ1 = 5 SFS = 0.69 Q3,4,5 = 1,1,1 Core Appointment = 3-5 Nervous Rate = 10 Wallpaper On, no OSD feautures
Sound is pretty superb, but felt voices were lacking just a little prominence and dynamic, as a result emotion was not quite as strong as it can be.
Changing q1 to 10 and xq1 to 15 has really bought back the emotion and presence. Everything else remains very enjoyable. Mybe bass pitch resolution is a shade more smeared but overall these setting are nice. Might be worth a try.
« Reply #125 on: January 12, 2019, 04:15:26 pm » |
Q1 = 30 xQ1 = 5 Changing q1 to 10 and xq1 to 15 Hi Nick - I am sorry, but both end up at the result of 150, and I am not aware of any possible SQ influence by means of the individual settings of each. This is for Kernel Streaming. For WASAPI the story is different ... Best regards, Peter
« Reply #126 on: January 12, 2019, 06:29:43 pm » |
Hey Peter, I almost asked in the last post if it were possible for different values of q1 and xq1, that make the same product for example 150, to sound different. I have just spent some time a: b ing q1 X xq1 values that give a product of 150. I still think I can hear some slight differences BUT its more difficult to pick out than I had thought origionally. Perhaps I have a case of placebo going on  Either way sound quality is really sublime, your settings are great  Kind regards, Nick.
« Reply #127 on: January 13, 2019, 06:44:40 pm » |
« Reply #128 on: January 14, 2019, 04:40:33 am » |
I changed my Custom filter settings to [low] which brings back body and character to the music. At high or Arc Prediction the sound is too "technical"... at least here on my system. Bert, Yes, you can very well be right. I already forgot about your description but had in mind the advised Custom Filter-Low setting and yesterday from the first second it all came to me as more musical. Maybe this does not 100% cover what you are saying, although it could when thinking of the "too technical" you refer to. Along with it, I have the idea it is more pleasant to listen to, while I not readily noticed downsides. Maybe a tad less spoken bass ? Thanks ! Peter
« Reply #129 on: January 14, 2019, 07:31:07 pm » |
The bass is less "punchy" and "less clean/dry" with the [low] setting but the overall sound is more real and more pleasant to me. Arc Prediction is making me lower the volume because it gives an "annoying" pressure on my ears (playing loud trying to fill the missing something I guess...). Need more listening sessions though (flipping phase makes a big difference but not equally for all settings). If you try another setting than also try to invert or revert the phase with that setting... its result is not always better for all settings. Bert
numlog
« Reply #130 on: January 15, 2019, 04:59:51 pm » |
Anybody prefer not to use upsampling? (the question aimed more at DS DAC users) I have trouble deciding which I prefer, upsampling is revealing, clinical (in a good way) but.... unnatural? dead? basic terms to describe complex sound is a bit pointless.... there is catch to this, lower sampling rates means different,lower buffer and SFS settings are possible so its hard to fairly compare when there are possible variables to the ''best'' settings depending on rate. With Kernel streaming it only applies to buffer as lowest possible SFS works no matter what rate (so not a huge deal) but with WASAPI it is limited.. This is something that makes WASAPI special, and makes in my case special sound possible. with no upsampling 1.51 SFS is possible versus 12.26 with 8X, with KS the choice of SFS resulted in different sound rather than better or worse but with WASAPI I notice distinctive improvement to timbre with the lower SFS, there is also typical SFS differences, I think the higher SFS have more space and open sound, lower more dense presentation. This could all be imagination though
PC: Ryzen 1700(Nofan), 2133MHz 2x4GB, GPU, Gigabyte A320 OS drive: Optane 16GB M.2, OS: S2019 Core, modded PCIe SATA card + modded Juli@ XTE I2S output , Corsair Rm650x MoBo PSU, 12V CPU LPS .
« Reply #131 on: January 15, 2019, 07:48:10 pm » |
No imagination, I think. Btw, if possible for your DAC, try to use KS Special Mode. If it works without ticks or buffer errors, it is "the best" (sadly not possible for NOS1 users). Anyway, you are completely correct in your stance that the upsampling changes the buffer sizes inherently, etc. This is exactly why I created the NOS1 such that electrically this all does not matter (and the software cooperates  ). Also notice that most DAC's will let themselves "overrule" for the filtering, hence, an e.g. 88.2 will not engage filtering for 44.1 (read : will not roll off under 22.05). This means that "our filtering" will be effective in maximum fashion. But if the DAC does not understand this way of working, then the overruling merely becomes "messing with". And then you will have quite contradictionary filters on top of it all. This is why a DAC actually should be Non Oversampling; now we can guarantee that our filters will be applied for 100% (not messed with even the slightest). And oh, notice that each Q1 setting below zero, is a special application for the WASAPI engine. Maybe set xQ1 to 1 and Device Buffer Size to 1024 (I recall that ever back I made it for these settings and I forgot whether this is all taken into account). Minimum of Q1 for WASAPI is -4. Have fun ! Peter
« Reply #132 on: January 16, 2019, 10:10:58 am » |
like never possible? When fiddling with the settings and ignoring the ticks (for a short time) running in KS Special mode produced the best sound I ever had. I guess we have to enjoy superb yet imperfect sound forever.... regards, Coen
« Reply #133 on: January 16, 2019, 10:49:01 am » |
Coen, you tempt me ...
But many years ago I worked on it for as long as was needed to find out that this is about a deep down Windows driver bug. This, with the notice that KS Special Mode is highly illegal to begin with, so there really won't be anyone feeling compelled to solve that bug. And when the driver is used in normal fashion, this bug doesn't surface ...
« Reply #134 on: January 16, 2019, 12:26:57 pm » |
People shouldn't miss this.
