Robert
« on: March 23, 2018, 11:44:53 pm » |
Yes 5.19 sfs is better than 20.19 in this latest XXh version. All running perfectly.
« Reply #1 on: March 24, 2018, 12:52:58 am » |
Hi Peter, the first impression is that the sound with v2.10 is excellent. Can you tell me please if you have your signature updated? With SFS 5.19 are you using Custom Filter (which one?) or Arc Prediction?
Best regards, Juan
Robert
« Reply #2 on: March 25, 2018, 12:21:20 am » |
2.10 is sounding very nice. My settings in signature are current. I prefer Arc prediction over custom filters. I've switched garbage collection back on and it sure does improve the sound. Nice work Peter, thanks.
« Reply #3 on: March 25, 2018, 04:13:01 am » |
Nevermind, i got it. Will upgrade to 2.10 tomorrow
« Reply #4 on: March 25, 2018, 10:44:29 am » |
Can you tell me please if you have your signature updated? With SFS 5.19 are you using Custom Filter (which one?) or Arc Prediction? Hi Juan, I now updated my signature. The items surrounded by * are the changed ones since last time. Among them the Balanced Load of 42 which I just found like that minutes ago and I must be using that for many weeks by now, although I can't really remember the merits of it. It is so anyway and I like the sound very much (in consistency with the other settings), so I let it be. Filtering is just Arc Prediction again and I am quite confident that the lower 5.19 allows for this "permanently" (sound is more smooth because of it and with Arc Prediction it gets the necessary snap again). Best regards, Peter
hudesigns
« Reply #5 on: March 25, 2018, 03:58:36 pm » |
Hi Peter, I remember you mentioned once that when playing MQA albums, xxhe volume needs to stay at -0dB. Is it still true under 2.10? Best, Zheng
XXHighEnd PC -> I5-4460 (4 cores), @800Mhz, 24GB, Windows 10 Pro 64 bit build 10586.0 - Windows system, XXHE and XXHEdata on M.2 SSD on MoBo - Other temp folders on 2.5" internal SSD / XXHighEnd 2.10c, music on LAN / Engine#4 Adaptive Mode / Buffer = 1024 / Q1/-/3/4/5 = 11/-/1/1/1 / Q1Factor = 1 / ClockRes = 1ms / SFS = 12.19 (max 12.19) / Memory = Straight Contiguous / Include Garbage Collect / not Invert / Phase Alignment Off / Playerprio = Low / ThreadPrio = Realtime / Scheme = Core 1-3 / UnAttended / Stop Desktop, Remaining, WASAPI and W10 services / Keep LAN - Not Persist / WallPaper Off / OSD Off / Running Time Off / Minimize OS / XTweaks : Balanced Load = 49 / Nervous Rate = 10 / Cool when Idle = 1 / Provide Stable Power = 1 / Utilize Cores always = 1 / Custom Filter second High 705600-> USB3 from MoBo -> Modified USB3 "Y" cable -> 32/384 async USB DAC iFi iDAC2 (in bit-perfect NOS mode) powered by battery--->
Stanray
« Reply #6 on: March 25, 2018, 05:20:01 pm » |
Hi Peter, When I set the Balanced Load (just trying settings), the result is (-). All other settings can be set, except "42". I left it at at "43" and that's OK, but I'm curious why "42" can't be set. Regards, Stanley
« Reply #7 on: March 25, 2018, 07:40:00 pm » |
Among them the Balanced Load of 42 which I just found like that minutes ago and I must be using that for many weeks by now, although I can't really remember the merits of it. No ! I am wrong here !! By now I can't even tell how and where I looked, but I have it at 52. I suppose looking after 3 hours of sleep and a party last night, isn't the best idea. But I caught up sleep a bit and now I thus see 52.  When I set the Balanced Load (just trying settings), the result is (-). Thank you Stanley ! (although I just noticed myself while working on an other PC and then checked by own). Btw, I am sure I was also influenced by the fact that since 14393.0 we also can go *under* the 42 with effect. So I recall that in some XXHighEnd version I had to exclude 42 from the "application" because else we couldn't dial in the normal situation. For those who like it - you must dial somewhat further down to see additional effect. I recall 35. But careful because when set too low, your PC will barely run and become too unresponsive. Als always activate "Boost at XXHighEnd Startup". Thanks and regards, Peter
« Reply #8 on: March 25, 2018, 07:43:04 pm » |
Wow, just wow. SFS 5,19 is a big improvement.
« Reply #9 on: March 25, 2018, 08:11:44 pm » |
Oh, I just noticed that I have my Nervous Rate at 10. So yes, I did this since it was possible to save it to other than 100 anyway (see 2.10 Release Notes). I hope my Sig is up to date now.  Peter
Robert
« Reply #10 on: March 26, 2018, 08:27:12 am » |
Well 52 and 10 sure make a difference in sound quality. Gosh when I swapped over much more bass, had to turn the active crossover down. These are settings I've not played with ever. Sound is amazing but I said that 2 years ago, it just keeps improving.
I've been on this forum for 7 years gosh time flys.
« Last Edit: March 26, 2018, 10:34:27 pm by Robert »
« Reply #11 on: March 26, 2018, 10:27:05 pm » |
Sound is amazing but I said that 2 years ago.
You are still a freshman then!
briefremarks
« Reply #12 on: March 27, 2018, 01:46:23 am » |
First:
THERE IS NO ONE ELSE in audio delivering the kind of continuous improvement that Peter provides. It is really staggering and unique.
Like everyone else here, just when it seems that SQ could not be any better, the bar is raised, and it absolutely has been raised with 2.10 and the new settings.
Some observations (playing familiar albums): - Extreme clarity of instruments; separate yet coherent, without sharpness of any kind. Accurate timbre (piano, horns, drums) - Tremendous dynamics - Fantastic resolution without any "etched" sound - More 3D sound-stage
I'm not sure exactly what the balanced load or nervous rate settings do, or how much of the improvement in SQ is the SFS vs these parameters.
Amazing!!
Listening to "The Astounding Eyes of Rita" Anouar Brehem
hudesigns
« Reply #13 on: March 27, 2018, 03:40:34 am » |
Totally agreed!
2.10 has kept me in seat finishing whole albums, definitely a good sign. It is hard to describe this very addictive sound but let me try:
Gentle yet assertive, wide sound stage yet focused, smooth with an attitude, rich with powerful crescendo.
Natalie Merchant Natalie Merchant album sounds mesmerizing...
Thanks, Peter
phantomax
« Reply #14 on: March 27, 2018, 08:37:15 am » |
Others have already said it better than I could have said: better than ever. The finesse of which I spoke in my previous post is even greater. And this bearing in mind that I am still struggling with Xtweaks and timers in my spurious RAM OS. In my case better with Custom filters than ArcPrediction. Thank you, Peter.  Maxi
Audio PC -> AsRock Z79 intel i-3 4170 @~800MHz, 16GB, Windows 10 64 bit build 14393.0 from RAM, DIY Linear Power Supply. music on LAN / Engine#4 Special Mode/Q1/-/3/4/5=*30*/-/*1*/*1*/*1*/ Q1Factor = *5* / Dev.Buffer = 1024 /ClockRes = *15ms* /Memory = Straight Contiguous / Include Garbage Collect / SFS = *0,69* (max 0,69 / Phase Invert / Phase Alignment Off / Playerprio = Low / ThreadPrio = Realtime / Scheme = Core 1-3 / Not Switch Processors during Playback = Off/ Playback Drive none (see OS from RAM) / UnAttended (Just Start) / Always Copy to XX Drive (see OS from RAM) / Stop Desktop, Remaining, WASAPI and W10 services / Use Remote Desktop / Keep LAN - Not Persist / WallPaper On / *OSD Off* / Running Time Off / Minimize OS / XTweaks : Balanced Load = 35 / Nervous Rate = 10 / Cool when Idle = n.a / Provide Stable Power = 1 / Utilize Cores always = 1 / Time Performance Index = Not the best / Time Stability = not stable / *Custom Filtering low for 176400* / Always Clear Proxy before Playbck = On -> Modified Audiotrak Prodigy HD2 internal soundcard with analog tube buffer (Broskie cathode follower) -> Passive biamplification: Canary Audio CA-301 MkII for highs- mids and Counterpoint SA-100 for lows -> Audiovector M-3 Super / modified Musical Fidelity X-3 (6h6p tubes) -> Grado 1000 headphones.
