March 31, 2025, 11:53:49 pm *
Author Topic: 02c | A message "Attempts: 11 Current CPU% level ..." occurs  (Read 6670 times)
« on: February 25, 2018, 12:45:20 pm »
It may happen that at the start of Playback, a message like this one pops up :
Attempts: 11 Current CPU% level of process 4.89341. Continue ?”
If this message appears (quite) consistently at the start of Playback, either your system is "generally slow" (read : not on par) or the Mixed memory type is selected in XXHighEnd Settings (in the Memory section).
Set that to either Mixed Contiguous or Straight Contiguous and it should help avoid the message.
Notice that what ever is being done in Normal OS Mode (which is the normal Operating System mode as presented by Windows) is inherently way more slow than when having booted into Minimized OS.
If the message won't go away, consider the deactivate (blue) the "Include Garbage Collect" setting. This will not be optimal for the best SQ, but it thus will avoid the "situation" hence message.
Page created in 0.154 seconds with 20 queries.
