November 23, 2024, 03:38:56 am *
Author Topic: Music stops playing  (Read 20817 times)
« on: February 23, 2018, 04:32:17 am »
Since a week or so I’m finding that randomly the music stops playing between a track. Hitting Alt+X shows that the play button is still active. Looks like the engine just stops.
I activated log files, however I couldn’t get any data. Is it possible that activity logging is possible only in OS base & not in RAM?
« Reply #1 on: February 23, 2018, 07:34:27 am »
Hi Arvind,
Logging works everywhere. Just look in
c:\XXHighEnd\2.xx\TemporaryData\
of your Stealth PC.
And no idea of course what suddenly could be in order. "Disk full" could be an obvious one, but then from data which is kept somewhere but shouldn't.
How much free space do you have on c: right after boot-up from RAM ?
« Reply #2 on: February 23, 2018, 12:46:06 pm »
Free space in Drive C: is 3.75GB.
I am attaching herewith the X3 & X3PB files.
* X3PB-20180212-123337.log (0.05 KB - downloaded 502 times.)
* X3-20180211-143208.log (0.29 KB - downloaded 427 times.)
« Reply #3 on: February 23, 2018, 01:29:08 pm »
Attaching another set of X3 & X3PB files, right after the music stopped.
* X3-20180212-132001.log (21.93 KB - downloaded 440 times.)
* X3PB-20180212-132001.log (5.63 KB - downloaded 435 times.)
« Reply #4 on: February 23, 2018, 01:45:56 pm »
Arvind - Thank you.
Unless I'm mistaken, where the X3PB ends, the X3 starts (the ones from your last post). IOW, they don't belong to each other.
Possibly you must kill Engine3 (blue led in the right border) after the happening so both log files will be compete(d). Or there is a situation at hand whcih we don't understand (which is likely in this case).
« Reply #5 on: February 23, 2018, 02:14:45 pm »
Attached are the X3 & X3PB files after the music stopped & after killing Engine#3.
I believe that initially the X3 files are created & then the X3PB files, though i may be wrong.
* X3-20180212-140855.log (20.95 KB - downloaded 464 times.)
* X3PB-20180212-140855.log (27.75 KB - downloaded 423 times.)
« Reply #6 on: February 23, 2018, 03:51:17 pm »
Arvind,
Can you give me the XX- logfile of this happening as well ?
If you're not sure which one it is (could be more than one) then it should contain log file entry times between ~14:08:56 and ~14:30:32.
It could be easier for you to zip the whole Temporarydata folder and email that to me (it won't be very large, unless you always have Logging switched on Happy).
« Reply #7 on: February 23, 2018, 07:15:06 pm »
I dont keep logging on at all. I had it on now just to capture the files due to the problem on hand.
I am attaching 2 XX log files. Hope they serve your purpose.
* XX-20180212-141315.log (5.17 KB - downloaded 453 times.)
* XX-20180212-140739.log (31.26 KB - downloaded 429 times.)
« Reply #8 on: February 24, 2018, 05:38:06 am »
Another problem has cropped up. I rebooted into RAM OS & now I am unable to start XXHE program.
« Reply #9 on: February 24, 2018, 09:20:32 am »
Hi Arvind,
Yesterday I had the hunch of something not being right with the priority settings, but internally, *or* there is a bug somewhere in XXHighEnd and you changed something regarding the priorities as well. And ... while writing this, what about you changed the Core Appointment settings ? I can't see it in the log (it is not registered) but it could be a "logical" thing you have done, regarding the latest remarks about it ...
Did you ?
So what happens ?
« Reply #10 on: February 24, 2018, 09:35:38 am »
No priorities or core appointment changed.
Now if I try to start XXHE from the desktop(double click on XXHE icon), XXHE screen does not open.
If I try to open File Explorer also, I get a blank screen.
« Reply #11 on: February 24, 2018, 10:26:58 am »
Booting into the BASE OS gives the same result ?
And if so, what happens when you boot into BAS 10586.0 ?
« Reply #12 on: February 24, 2018, 10:30:17 am »
Under the present situation, I don’t know how to access the OS boot menu since the XXHE screen does not open. Is there another way of doing it?
« Reply #13 on: February 24, 2018, 10:46:05 am »
I booted the Audio PC, RAM OS is the only option at present & now I have File Explorer open(don’t ask me how it opened now & not a few hrs back). Do you suggest that I delete XXHE 2.09, go back to 2.07 then apply 2.08 upgrade patch, then apply 2.09 upgrade patch & try to start XXHE?
« Reply #14 on: February 24, 2018, 10:54:33 am »
Yes, I just was thinking that myself. unhappy
Not sure whether you did that already, but when you have a monitor attached, you will see the normal Windows boot menu passing by. If you, when that is about to appear, keep on pressing downarrow, you will interrupt the boot menu (without touching anything it stays there for 2 seconds).
In there you can select the OS again, with the notice that your choice won't stick for a next reboot (so if that is necessary in the process, repeat this procedure with the DownArrow).
Notice that I think that now all the OSes fit in that menu, but with Down-/Uparrow you can scroll through them.
No, not at all;
Something else is wrong but it is hard to tell what, as of yet.
If you can imply normal behavior in 10586.0 then 14393.0 became corrupt somehow. If in 10586.0 you see similar problems, it is worse ...
