November 24, 2024, 09:46:14 am *
Author Topic: Speed of Library function  (Read 10819 times)
« on: February 25, 2008, 05:49:20 am »
Last night I saw the wait had more to do with waiting for my albums picture/selections to show up then it did explorer...(different folders with varying amounts of wavs would load faster/slower depending on how many albums where in folder/gallery).  My largest gallery only takes a few seconds to load... no biggy.  If I go to a folder with no wav folders... explorer window pops up quick.
Do you think that in the end it can be done a bit faster? Meaning the loading in from the albums? Or is this the max? Ik now it also takes a minute for the harddrive to speed up...
« Reply #1 on: February 25, 2008, 05:52:04 am »
Probably get faster as computers get faster... how longs it take for you?  Usually just a couple seconds for me.  My gallery is at about 2200 discs so far...
« Reply #2 on: February 25, 2008, 05:54:54 am »
Well it  takes a few seconds 5 or so.... ( 1400 cd's ) And can you uncheck that speeding up??... Meaning that it is actief the whole time.... Or is that not good for the drive itself?  dntknw
« Reply #3 on: February 25, 2008, 10:03:45 am »
You must be doing something wrong or possibly don't understand how it works ?
I have over 6000 albums in one "group" like Rock. When I access that for the first time, it indeed takes maybe 30 seconds to collect them. This is when nothing is in cache, so say the first time I do it after a reboot.
Now, no matter what, when I go in there a next time (XX shut down and restarted and all) it takes less than one second. Even after a reboot.
When I change to one of the others with, say, 400 albums in there, that again takes less than one second because it's so "few".
When I then pop back to the 6000, it may take 5 secons because all is in the PC's cache memory.
This is all from an IDE (PATA) drive (where I keep the Galeries), so it can be way faster when stored and used from a SATAII drive.
I really don't need more speed ...
What I can do though, is provide a checkbox that allows you not to count the number of albums in a folder. That makes it, say, 10 times faster ... (and you don't have the numbers) ...
« Reply #4 on: February 25, 2008, 10:21:47 am »
One other thing maybe ...
If you find yourself pressing the Search button, I think you do something wrong already. I mean, I *never* do it, because all works with "Active Search" (just kind of slowly typing in that area). The only thing is, sometimes it doesn't work properly, and then I back out a few characters, until I see "movement" in the Library Area again. And then type forwards again ...
« Reply #5 on: February 25, 2008, 12:17:54 pm »
Maybe  unhappy I will check.... But i am also meaning the spinning up from the drive.... Can i do someting with that?
Good idear!  Happy
« Reply #6 on: February 25, 2008, 06:41:25 pm »
Most probably, yes. Could be Energy Saving Options somewhere, but it highly depends on ... things ? swoon
I think software-wise I should be able to do all, but these things may be difficult to find and implement. I have it in mind anyway, like more tweaking with the Services and all. You know ...
Btw, my drives spin up in approx. 10 seconds, and fall asleep in 10-20 minutes or so.
Note that Vista Energy Settings have a high degree of instableness. I think most of that will be solved in SP1.
« Reply #7 on: February 25, 2008, 07:48:06 pm »
I think i will wait for SP1 than....  Happy
Page created in 0.15 seconds with 19 queries.
