April 01, 2025, 01:08:04 am *
Pages: 1 2 3 4 [5]  All
Author Topic: Trying w10 on my old PC  (Read 66244 times)
hudesigns
« Reply #60 on: April 03, 2018, 06:44:37 pm »
“MemOrg error 02”.
Maybe this is not 100% exact ?
I can't find this particular error (text).
I remember I also got "MemOrg #2" message when I was still on 2.08d trying to use 5.19 and Straight Contiguous together. I could cured this issue by using 5.19 and "Mixed" or "Contiguous Mixed" combos. All this went away after installing 2.10. Happy
ZH
« Reply #61 on: April 03, 2018, 08:08:45 pm »
“MemOrg error 02”.
ZH
I was using SFS 2.19 mixed contiguous on v2.08, tried also 10.19 and never got that erro before.
It's definitely something related to memory physical AND virtual.
Have you changed your virtual memory (swap file) perhaps?
hudesigns
« Reply #62 on: April 03, 2018, 09:24:22 pm »
I don't use RAM-OS, so I don't think I deployed virtual memory, not that I know of anyway.
ZH
« Reply #63 on: April 03, 2018, 09:28:26 pm »
ZH
Your PC is more similar to mine than Peter's Wink
coliny
« Reply #64 on: April 04, 2018, 07:14:28 am »
You don't need Virtual memory although it won't do any harm except maybe to sound quality.
Maybe you have a faulty RAM card, do a memory test, might be an option in bios to do it.
Colin
« Reply #65 on: April 04, 2018, 08:41:36 am »
But no literal "error" text ?
I like to find this error message in the code ...
« Reply #66 on: April 04, 2018, 05:07:37 pm »
and I'd like to not see these OOM popups anymore.  Wink
Not even talking about what caused the screech.
tempo
« Reply #67 on: March 27, 2022, 04:16:48 pm »
Would someone be good enough to let me have a reliable link to a 64bit version of 14393? If this is still the one to have?
W10 14393.0 is still available from
https://getintopc.com/softwares/operating-systems/windows-10-pro-64-redstone-rs1-14393-july-2016-download-4309298/
as well as W10 10586.0
https://getintopc.com/softwares/operating-systems/windows-10-pro-build-10586-64-bit-iso-free-download-1295486/
~Joseph
XXHighEnd:
Audio System:
