April 01, 2025, 12:56:54 am *
Pages: 1 2 3 [4] 5  All
Author Topic: Trying w10 on my old PC  (Read 66241 times)
« Reply #45 on: April 01, 2018, 06:40:21 pm »
Hey Telstar,
I feel that something else could be (or should be) the matter. But mind you please, it still is so that few will have the experience with so few memory these days. Anyway :
Is the version you use (still) 14393.0 ?
See a cleared Playlist Area for the version.
What is the resolution you are using while on the remote ?
Bit depth ? (implying you can set that lower)
Yes, I believe it’s acting strangely. With 11% used memory I shouldn’t be getting this, and there are a few more errors, i list later.
Today, 3 albums loaded in playlist. At the middle of the first I got “engine3 didn’t start in time” and sound stopped. This happened 3 times, even without RDC.
W10 14393.0
Dac is 24 bit/384. At >16 bit requires 24bit
I use software attenuation from 20 to 40db, depending on album.
AP 4x. I play either redbook upsampled 24/176 or highres 24/96 upped at 24/192. The type of track seems to not matter, nor its format (flac or mp3).
Core appointment 1-2 (got only 2, new cpu will take 1 month to arrive from Japan).
I’m keeping log active, in case you want to see it.
Other bug: i finish one album, alone in playlist. I wanna play again one track, i select it, hit play and no sound. Have to close xxhe and re-launch it. It happens all the times with RDC.
Oom errors seem confined to RDC playback. No: also without rdc. Just got two at track 4/20 of a flac album.
« Reply #46 on: April 02, 2018, 09:32:50 am »
Hi Telstar,
Maybe it is good to remind you that XXHighEnd is made for Unattended Playback and that is not what you are using, as it seems. From there (Attended) it really requires knowledge of your system and what it can take to play Attendedly (thus with GUI) in sustained fashion.
I can do it (still with requred knowledge) by my system is not slow anywhere except for the CPU cycles (500 MHz). This is crucial.
But maybe I observe wrong in the first place ?
This tells nothing. And it especially tells nothing when you use either of the "Contiguous" memory modes.
Now go and read the 1000+ pages books on Windows memory organisation and Garbage Collection. Eh, for each OS (eh, version).
It could be well so that the most "errors" happen because of your own idea about how Windows operates and next state to yourself that it should work and make yourself crazy with it.
Did you know that your mentioned error actually can spring only from "disk full" situations ?
« Reply #47 on: April 02, 2018, 04:28:02 pm »
Well my goal was to get "normal" playback rock solid first (like it was with 09-4.1 on W7), but it seems it was the wrong move. Back onto the drawing board.
So I did two things:
1) Activated windows and then shut off internet again. No update was installed. I suspect this was creating some background activity. Created a restore point.
2) Used minimized OS. Can live with it as long as CTL+ALT+DEL still works Wink
NB: I'm still using mixed contiguous.
I'm testing today without RDC and I will report any error I may encounter.
The OS disk has plenty of space, it's a 128GB SSD.
But... the library disk is a 5400rpm spinning disc suspended with rubber bands. This one could be a little full, I have to check.
No, and this rings a big bell!
My next move is to replace the library disk with a 2TB MLC SSD (Crucial still makes one that is reliable). I dont feel it sluggish, but I can hear when it is accessed and/or the software writes on it -3m from the PC.
Another thing I can do is to put the old 32GB SSD which hosted W7 as a XXE drive.
As alternative I could make a 2-3GB ramdrive.
What do you think would be best (for smooth playback, SQ comes next)?
« Reply #48 on: April 02, 2018, 05:00:48 pm »
Disk checked: I have 400GB free, so that's definitely not the cause.
So far no errors today....
Peter let me know your opinion on the two options I'm considering for playback (small ramdrive or dedicated ssd).
Third option: usung straight contiguous instead (if i can).
« Reply #49 on: April 02, 2018, 05:21:00 pm »
Telstar, my only option would be to have it 100% error free first and then see further (it will also determine possibilities).
On a side note : that out of memory can virtually only come from the OS Disk.
Do you have your Virtual Memory on for Drive C: (OS Disk) ?
"We guys" mostly have it Off but we also have 16GB or 32GB of memory. You should really have it On (RightClick MyPC, Properties, Advanced, Advanced tab, Settings in the first section.
« Reply #50 on: April 02, 2018, 05:29:02 pm »
Agreed!
So RDC stable playback as first goal.
Going to check. I think I put 4GB, as I usually keep it same size as RAM. Yes, it was 4GB.
Changed to 16GB and restarting.
« Reply #51 on: April 02, 2018, 05:33:59 pm »
cr*p, it just gave me a “MemOrg error 02”.
I’m going to shut down and restart the pc now. Also I’ll clean the playlist and load a new one.
« Reply #52 on: April 02, 2018, 05:40:20 pm »
Twice the internal memory size is "normal".
I thought you had more than 4GB of memory by now ?
« Reply #53 on: April 02, 2018, 05:43:51 pm »
Yes, I have 8GB now, but virtual memory was left at 4GB.
With 16GB virtual memory I cannot use garbage collect anymore it seems.
Restarted, new album and same error.
What should I do? Try 8 GB or go without GC?
« Reply #54 on: April 02, 2018, 06:12:13 pm »
“MemOrg error 02”.
Maybe this is not 100% exact ?
I can't find this particular error (text).
« Reply #55 on: April 02, 2018, 06:51:01 pm »
I must have copied wrong. Was dealing with my cat at the same time.
Anyway, the window error also said to disable garbage collection if that happened again. It happened twice in a riw, so I did.
Now, i put gc on again and the error didn’t reappear, but I got this (photo attached)
« Reply #56 on: April 02, 2018, 06:52:03 pm »
https://s18.postimg.org/927w17yhl/3_BA8_AC04-_F2_A4-4246-86_D8-_D42_C23_B3_FDDB.jpg
« Reply #57 on: April 02, 2018, 07:58:44 pm »
I better don't tell what happened next. My ears still hurt.  scare
« Reply #58 on: April 03, 2018, 09:15:21 am »
But can I incur for that too ? How ?
I promise I will put my amps off. Happy
« Reply #59 on: April 03, 2018, 05:19:11 pm »
After that error, i got a similar one, then closed xxhe and decided to restart the PC. I didn't turn my amps off nor change dac input, because I have been trouble free for very long time.
Not yesterday. It emitted a screeching sound until i could switchoff the DAC. It hurt my ears and my cats' for 2 hours. Luckily the speakers weren't damaged.
Moreover, after such restart it was impossible to login from the local PC, got a black screen with mouse pointer. Powered off a minute and back on, same thing. It somehow corrupted something in Windows.
I could log with RDC, so I did and removed minOS from there. At reboot I could log from the PC locally, but (another bug for ya) Windows was deactivated.
I could restore my own point which was just before the one created by xxhe, and everything seems back as it was, including OOM errors (attended, 8GB+16GB virtual memory). Garbage collect off to prevent some sh*t like that from happening again.
Conclusion: I'm not going to try minOS anymore. I was quite happy with it until that happened.
And the OOM errors happens only with normal OS at attended. So, I'm asking you to test that. Locally or RDC is the same thing, RDC being worse. I think that the amount of memory of your PC doesn't make a difference, the cores dunno.
PS: the big virtual memory could be related to the strange error before the screech, and/or with garbage collecting so I think you should setup virtual memory = 2x physical RAM too.
