November 23, 2024, 04:19:02 pm *
Author Topic: xxHE with xxPC and Wyred 4 Sound DAC2 DSDse  (Read 21215 times)
« Reply #15 on: December 28, 2017, 11:02:15 am »
Hey Charlie,
When you run into that problem, did you just select the tracks for a first time, or was it a left over of a previous attempt (or playback which you stopped for other reasons) ?
I ask, because I feel this can make a difference.
What I now of myself is that I seldomly work with a selection of a previous playback because, well, I got fed up with it (but say that I did not stop playback without reason). So what I almost exclusively do is something you may not even be aware of :
Click the [ P ] from Playback Area (selection), which clears the selection completely.
BUT and ALSO :
I recall that you don't use a Tablet etc. for control. This will mean that you are the by now more rare occasion of NOT using the "Touch Facilities" (see Services and OSD section in Settings). And *now* suddenly we might have a good reason of
a. me never seeing this behavior;
b. it possibly being wrongly working just because of the normal mouse operation.
Ad b.
The "Touch Facilities" were developed maybe 3-4 years ago while one year ago the track selection received a complete overhaul. OK, this development was not done under the condition of "Touch Facilities", but as you can imagine, real life operation implies a h*ll of a lot more than stupid developer testing.
So what if you could try to work with the Touch Facilities to see whether that helps ? If so, I at least know where to start looking. Notice that this takes a bit of getting used to, like not using Ctrl-Click etc. because all adds autmatically to the selection (everywhere) and you thus now need the means to Unselect (like mentioned [ P ] button).
If you don't like to do this, then OK. But it could be helpful.
Thanks again,
charliemb
« Reply #16 on: December 28, 2017, 11:48:08 pm »
Hi Peter
Thanks.
And status:  last night's session had zero problems.  No changes whatsoever from the night before, which after about two hours I used that to start playing with different filters.  Still no problems as I said.  I'll try to run as I'm running until problems show up again, and then make changes at that point, well at least that's the plan if I can stick to it.
Always a fresh selection.   I agree that previous selections are not totally reliable.
BUT and ALSO :
Ad b.
The "Touch Facilities"  ...
Hey Peter you are right, I don't use Tablet control.  I'm under the presumption that I need a network to use a tablet for control.  No?   Remember, on purpose, I try to avoid the LAN or the Wifi  to quiet the system and avoid Windows OS updates and virus scans, mostly the OS related issues.  It is a true joy to not hassle with PC stuff; it just works like a toaster oven.
a. and b. above are very pragmatic.  Although it is hard to believe that all of your active users have gone to tablets for control.
Charlie
[Edit: Also, I have no means of running a LAN cable to my xxPC without creating a trip hazard via a very long LAN cable.]
July 2019:
charliemb
« Reply #17 on: December 30, 2017, 12:48:25 am »
Another hint:  The last two nights there were no problems.  What do the two night sessions have in common?  Answer: the xxPC was on all day playing Christmas music.
July 2019:
« Reply #18 on: December 30, 2017, 04:30:38 pm »
Hmm ... I am always glad when our second day of Christmas is over, so I can finally stop playing the Jingle Bells. Happy
But what do Christmas songs have in common, generally ? they are short.
charliemb
« Reply #19 on: December 31, 2017, 11:11:09 pm »
Hi Peter
All of the Christmas music was JRiver,  if that matters.   ...And without an xxHE invocation first.
Other updates:
1)  Starting with less than good news, even though Stop WASAPI was checked, I got the dreaded "This should not happen just restart xx" message.  So that negates a previous report that stopping wasapi solves this one.
2). Continuing with good news,  a third night without playback stopping after first track, or other stoppage in odd situations.   This is enough confidence now that I started playing with settings to improve SQ.   Now at 20,1,1,1, 3-5, system max for clock, e.g.
The only down side now besides the "should not happen , restart" message and hassle, is that I can't run WASAPI on my system.  Hopefully I can run it if I reboot.
I can run like this if you want,  or I can try to continue to help for others.
Charlie
July 2019:
« Reply #20 on: January 01, 2018, 10:56:58 am »
Hi Charlie,
That dreaded message is already out (for 2.10). So no worries about that.
You'd have to go to Normal OS, set it active in there and reboot to MinOS. Then it will work again.
Good that there's progress !
charliemb
« Reply #21 on: January 14, 2018, 06:29:48 pm »
Thanks Peter.  Thank you !
Also, ASIO appears to work with WASAPI turned off.  That helps me and this info could help others.
Charlie
P.S. Can you believe that I never turned off LAN?  I did that now after creating a new restore point and, wow , there's a big improvement for me.
July 2019:
« Reply #22 on: January 14, 2018, 08:10:31 pm »
Yes, it is unlrelated. Say similar to Kernel Streaming.
Page created in 0.081 seconds with 19 queries.
