November 23, 2024, 03:46:25 am *
Author Topic: Volume Setting not saved from RAM Disk  (Read 11691 times)
coliny
« on: December 21, 2017, 08:59:00 am »
Recently started using Volume setting other than 0 but volume setting goes back to 0 after reboot.
Colin
« Reply #1 on: December 21, 2017, 10:47:01 am »
Hi Colin,
The last time you came up with this, it was some kind of pilot error. Should be in the forum somewhere. And I did not change anything ...
One thing :
I think it is so that when you use XXHighEnd to reboot (rightclick on Stop) the settings from that very moment are not saved. I recall I said similar the last time (maybe 3 months ago).
coliny
« Reply #2 on: December 21, 2017, 11:33:21 am »
Hi Peter
Its not me I never make same mistake twice (well hardly ever) haha.
All other setting changes are being saved.
I normally shutdown via STOP, just tried closing XX & shutting down via Windows but Volume is still not saved.
REgards
Colin
« Reply #3 on: December 21, 2017, 01:15:06 pm »
Hi Colin,
Is it really only the Volume then ?
(hint : this is very hard to imagine)
« Reply #4 on: December 21, 2017, 01:25:47 pm »
I should add :
It is quite crucial for me to know whether it is the Volume only or "everything" (like Q1 and SFS to name two others) because either is a very different situation to look for.
I'd actually say that if this is the Volume only, this always has been so.
N.b.: It is difficult to test in practice these days, as I work from RAM as a whole (for the OS) and installing a RAM Disk on top of that is not a funny thing to do.
phantomax
« Reply #5 on: December 21, 2017, 02:42:28 pm »
Hello,
with the last XXHE version installation I probably made a mistake and I had the same problem. Well, the volume issue for sure. I tried several things and I don't remember exactly how I solved it but I think that was XXDATA folder location related ( or maybe Copy settings to...) Sorry for the vagueness ( I think I need more RAM lately  Shy ...). I hope it's a clue there.
Maxi
« Reply #6 on: December 21, 2017, 03:06:41 pm »
Thank you Maxi. The problem may very well reside in that area.
coliny
« Reply #7 on: December 21, 2017, 05:59:11 pm »
Just checked again & Q changes are still saved, just volume that is not changed.
At some time in past it must have worked otherwise it would be booting at default installation volume.
Regards
Colin
« Reply #8 on: December 21, 2017, 09:38:28 pm »
Same here ... everything comes back as saved except volume changes.
No matter how things are saved (manual, reboot, etc.).
No real issue but can be annoying if you do not want to set the volume to the desired volume each time after a reboot.
« Reply #9 on: December 22, 2017, 08:27:18 am »
OK, thank you all. I will look into it.
coliny
« Reply #10 on: December 23, 2017, 08:12:22 am »
Hi Peter
I think it is XXVL.dat  it is not saved from A:..... to C:.......
Thanks for all your work this year especially MQA which is sounding good now, I've gone back to adaptive by the way.
Hope TIDAL survives
Have a good Christmas
Colin
« Reply #11 on: December 23, 2017, 12:27:31 pm »
Colin, wow, your are GOOD !
I say this, especially because I wonder whether I would have have found this.
One secret : it will be XXVX.dat. But I will copy all three of them.
Thank you VERY MUCH.
Merry Christmas,
« Reply #12 on: December 23, 2017, 01:02:54 pm »
I forgot : This omission was introduced in 2.07.
