November 23, 2024, 03:57:32 am *
Author Topic: Problems with XXHE Forum Search  (Read 6410 times)
tempo
« on: December 20, 2017, 08:52:45 pm »
Hi, Peter,
For the past few days, whenever I tried to search the XXHE forums from the Search page, this message appeared:
8: Undefined variable: db_connection
File: /var/www/html/phasure/Sources/Security.php
Line: 843
I tried searching for topics on two different PC's that have different OS's and the same thing happened with both. Curiously, when I searched for a term that does not appear in the XXHE Forum, then the usual page came up showing "0" results. Does anyone else have this problem?
As a control, I also searched other online forums and normal results by topic or thread were returned as expected.
Thanks!
Joseph
XXHighEnd:
Audio System:
nik.d
« Reply #1 on: December 20, 2017, 09:50:39 pm »
Same with me. Tried with Opera-Firefox-Brave browsers.
George
« Reply #2 on: December 20, 2017, 10:03:49 pm »
Hey guys, I think I saw the same.
To be solved !
« Reply #3 on: December 22, 2017, 03:05:26 pm »
I forgot to tell that this was solved yesterday.
