April 05, 2025, 11:27:32 am *
Author Topic: Where is my signature?  (Read 38236 times)
« Reply #15 on: December 30, 2017, 04:28:41 pm »
Um ... but *that* is not going to remove your signature.
Maybe you posted in the wrong topic ?
« Reply #16 on: December 30, 2017, 08:17:28 pm »
Yes, changing only that one thing caused the signature to disappear when I hit the "post" button, both yesterday and today.
« Reply #17 on: December 31, 2017, 10:53:51 am »
Hi Brian - Are you saying that you changed the Nervous Rate in your signature from 100 to 1 ?
Sorry to be thick, but this was quite unexpected (regarding the other topic about the same thing in XXHighEnd).
« Reply #18 on: December 31, 2017, 10:57:13 am »
... So if you meant that in the first place, there's 1 in there at this moment and if I change that to 100 and then back to 1, all sticks.
I am lost. Happy
« Reply #19 on: December 31, 2017, 02:27:16 pm »
Yes, I changed the Nervous Rate 100 to 1 in my signature and that caused the signature to disappear both times. About 4 or 5 weeks ago, while trying to sort out my SQ issue, I believe that I changed my signature nervous rate setting from 1 to 100 while erroneously thinking that the 1 was a mistake.
« Reply #20 on: December 31, 2017, 04:26:23 pm »
But, on second thought, it now seems more likely that I've been using a nervous rate setting of 100 for a long time, given the nature of it since 2.06, and that's what my signature reflected. Only now, since something changed for the worse in my system over the last few months, changing nervous rate back to 1 (where it had been for years before 2.06) makes a very significant improvement in sound.  Happy
Sorry for being uncertain about this.
« Reply #21 on: December 31, 2017, 06:02:03 pm »
thankyou
« Reply #22 on: December 31, 2017, 06:09:54 pm »
Peter, today I'm trying to copy and paste my original signature from your post but again it is not possible. Maybe you can.
This is my original signature:
Audio Pc: Processor i7 970: 3200MHz (reduced to 1668MHz), 6+6 cores/ RAM Corsair DDR3, 24Gb, 1333MHz/ Mb Asus X58 Sabertooth/ OS and XXHE in Peter´s RAM-Disk / The CPU fan is the only one in the Audio Pc: NF-S12A (600rpm/6.7db)/ No graphic card/ Power supply: Seasonic SS-400FL2, fanless.
Configuration and Updates in HOW I´VE BUILT MY NEW PC...http://www.phasure.com/index.php?topic=1673.0
XXHighEnd: 2.09. Windows 10 Pro 64 bit build 14393.0 from RAM, music on LAN/ KS:Phasure NOS1 Out 4.0/ #4 Engine/ Adaptive Mode/ Q1=30 Q3=1, Q4=1, Q5=1, xQ1=40/ Dev.Buffer: 4096/ ClockRes: 15ms/ Straight Contiguous/ SFS: 8,00 (max 120)/ Not Invert/ Phase Alignment Off/ Allow format change/ Decode HDCD/ Playerprio: Low/ ThreadPrio: Real Time/ Scheme: Core 3-5/ UnAttended/ Not Switch during Playback Off/ Playback Drive none/ UnAttended/ Include Garbage Collect/ Copy to XX Drive by standard/ Always clear Proxy before Playback/ Stop Desktop Services/ Stop Remaining Services/ Stop All Services: Off/ Keep LAN Services: On - Persist: Off/ Use Remote Desktop/ Minimize OS/ XTweaks : Balanced Load 43/ Nervous Rate 100/ Cool when Idle -/ Provide Stable Power 0/ Utilize Cores always 1/ Time Performance Index: Optimal / Time Stability: Stable / Custom Filter: 705600 Low.
Music Server PC (W10) totally silent with OS (W10) in SSD and music inside in SSDs - RDC > Ethernet Gigabyte cable 3m > Audio Pc > 1m USB Lush cable directly from the USB3.0 in the motherboard > PHASURE NOS1a-75B-G3 (Driver v1.0.4) 8ms > Blaxius BNC interconnects > Genelec 1037B 3-Way Active speakers with BNC inputs
« Reply #23 on: January 01, 2018, 10:47:50 am »
OK, I saved the example. It is about the ´
So Peter´s won't work.
Peter's will.
I set your signature back now with this ' in it.
Edit : It's also in
How I´ve built ...
« Reply #24 on: January 01, 2018, 10:51:02 am »
Brian,
If you can still mimic your situation (and we must assume that) please do that once again and tell me the how to. So far I can't do it.
« Reply #25 on: January 01, 2018, 10:54:59 am »
Thanks Peter
« Reply #26 on: January 01, 2018, 03:06:09 pm »
Just made a change in my signature (SFS from 1 to .02) and it worked. Not sure what happened before. As always, used the "Forum Profile Information," button, under "Modify Profile" to make the change. Then hit save.
« Reply #27 on: January 03, 2018, 04:26:40 am »
OK, *now* it is solved ...
