Hi Johan,
I’ve red somewhere in your suggesties that 4GB is the minimum.
Yeah, you read that from my post today, but possibly you misread that. I said : I recall that 4GB ever back was the minimum and probably this was with Vista or even XP.
It is by no means valid today.
I just don't know.
Another difference I have seen more crashes/stops during a playback session in 14393.
Can you please qualify that ?
I mean, I don't know about "stops" as such without any error message. I also don't know about crashes which go without error message. And all I actually do know is that I use the same OS install(s) as you do (RAM-OS Disk) and that the really only reason for playback to stop is the "Crack Detect" tripping, which is too tight for 2.09 (will be wider in 2.10).
... But I use another PC ... Important ? to some extent of course Yes, but it would only be of real importance if a 100 people would jump in and tell they have the same issue.
Something else - and I suggested that recently - is that the Core Appointment can do wonders. What is required in which environment is beyond me though (I just am not able to know it).
Anyway ... by no means this is a message of "it is you and you must be doing something wrong". The contrary; I only try to indicate that all can be fine as it is, but with which settings it goes "off" I can't tell. Again, if a few more people would be able to confirm this, it would be far more easy to look in "a" direction. And I am here to work things out ...
PS: To be complete, what I do know from the RAM-OS Disk is that the W8 install is not stable really. 10074 is also "so-so" by now, but doable. From the others I see no issues myself, nor do I hear from them.
