November 22, 2024, 05:24:21 pm *
Author Topic: Message " Straight Contiguous Memory Allocation error 3-Lower SFS..."  (Read 18547 times)
« on: December 11, 2017, 03:56:12 pm »
After 2 or 3 days of using XXHE (never switch the computer off) I get after a play-command the following message "Straight Contiguous Memory Allocation error 3-Lower SFS, reboot or choose another type (0:1450 Total result= 251658240). Music don't start to play. Lowering SFS from 10 to 1 has no effect. After the reboot all is working ok for a few days.
Any suggestions?
Best regards Johan
« Reply #1 on: December 11, 2017, 06:49:26 pm »
Hi Johan,
What is your Max SFS set to ?
« Reply #2 on: December 11, 2017, 07:15:33 pm »
Max sfs=120
« Reply #3 on: December 11, 2017, 07:40:42 pm »
same here
with
 Max sfs=120
 Min= 10,00
« Reply #4 on: December 11, 2017, 08:05:39 pm »
Johan, Joachim, this is VERY strange.
May it help ... my Audio PC runs for weeks and weeks without reboot and is used every day with (on estimate) 10 starts of Playback.
Do more people suffer from this ?
« Reply #5 on: December 11, 2017, 08:52:21 pm »
Caused by Underclocking?
« Reply #6 on: December 12, 2017, 08:17:06 am »
I think I have at least one very good reason : You leave the Audio PC in a state of XXEngine3.exe not running (this one keeps the memory allocated). So for example, when you receive an error because of sample rate mismatch ("Device can't play" and the like) and then think "oh well, let's call it a day", then tomorrow the contiguous memory required will have been eaten.
More situations of this may exist, like you killing Engine3 yourself (the Blue Led) or ... change the SFS. This latter is quite harmless because when playback starts XXEngine3 is killed and right after that (0.1 sec) restarted, but when you are low on memory right in between it can be eaten.
Btw, after the new Crack Detect procedure Engine3 is also killed.
People must know that it is the Max SFS which is rejected at some stage. Not the SFS itself. So the Max SFS reserves the memory ...
« Reply #7 on: January 01, 2018, 10:46:25 pm »
First: Best wishes for this new year.
I do not quite understand what you are trying to explain. Is there a solution for this Memory Allocation Error? I still have it every 2 days. I can only play further with the mixed contiguous memory setting. What other parameter can I change to solve this?
Best regards Johan
« Reply #8 on: January 01, 2018, 11:28:33 pm »
I've tried to free memory with the Garbage Collect button. After a week all seems to work ok, but in the afternoon the Memory Message again.  Old Another thing I have noticed with this Garbage Collect ON every time after a PLAY command I get a Free Memory Message "Attempts: 11 Current CPU%........Continue?  YES/NO
see also http://www.phasure.com/index.php?topic=3706.msg39515#msg39515
When I switched Garbage Collect OFF, No Free Memory message again, but within 2 days the Straight Contiguous is back again.
« Reply #9 on: January 02, 2018, 08:59:29 am »
Hi Johan,
I can't tell what you suffer from.
What I implied to say in my previous post is that you should lower the Max SFS. So if you use ~20 for your SFS, set Max SFS to the maximum you will allow yourself toying with. So if that is 30 for the forseable (boot) future, set Max SFS to 30.
Now you have at least quite a lot more memory available.
I am pretty sure you cause the system to have too few memory available, and then have XXEngine3.exe be killed by one or the other reason (can be something which goes wrong, with for example the Crack Detect being tripped - you will always get some sort of message). If now the system is eager for memory, it will right away occupy the contiguous space XXEngine3.exe *had* allocated, and then you're done.
Does lowering the Max SFS help ?
« Reply #10 on: January 19, 2018, 04:45:15 pm »
I changed The max sfs to 30. Until yesterday all was werking ok. Today I had this straight contiguous memory allocation errormessage again.
During this period i have every day this Free memory message direct after a play command when Garbage collectie button is active.
Regards Johan
« Reply #11 on: January 19, 2018, 05:51:11 pm »
Hi Johan,
So indeed it must be related to something which keeps your PC busy and eats the memory.
The question could now be : does this bother so much to bother you ?  Happy
« Reply #12 on: January 19, 2018, 07:25:04 pm »
No, only every 20 day’s a reboot of the system. It takes a few minutes inclusieve placing and removing the harddisk. I like it more when i don’t have to do that.
Is there a solution for the garbage collect button?
Regards
Johan
« Reply #13 on: January 20, 2018, 05:16:24 am »
Activate it again ... haha.
Maybe it can work now because of your lower Max SFS ?
I don't think it is about 20 days or such; it will be - after an amount of time (x days ?) - that you do something that makes the sound engine disappear (stop) and *then* the memory wil be eaten right away because it was pushing already (too few of it because of the for us unknown reason).
Did you consider to "reinstall" the OS by means of such a "Copy" file ? Backup / Restore
It only takes the work of the copying, after knowing jow to access it (which means boot into one of the other OSes first). Then we can also see whether this is right from the start now, after aplying 2.09 to it. And of course write down your important settings before doing it all.
I am not saying that you *have to* do this, but we may learn something from it.
« Reply #14 on: March 04, 2018, 11:55:36 am »
Small update.
After Your suggesties to reinstall the OS, I switched back to W10-10586.0. So far all is werking ok, except “ garbage collect” still that message every time after a play command. Soundwise I prefere the latest OS W10-14393.0. Another difference I have seen more crashes/stops during a playback session in 14393. In 10586 I’ve seen less then 5 times stops during a playback in this period. But never that message “Straight Contiguous Memory Allocation error 3-Lower SFS, reboot or choose another type (0:1450 Total result= 251658240)”
Soon I will reinstall 14393 to test it again.
The XXHE PC uses 32 GB om RAM. I’ve red somewhere in your suggesties that 4GB is the minimum. To slow? I’m using a i7 4770K Hyperthreading On (8 cores)
Johan
