November 23, 2024, 12:16:26 pm *
Author Topic: 2.09 stops suddenly  (Read 24599 times)
« Reply #15 on: December 14, 2017, 07:50:47 pm »
Hi Juan,
Seem much to me.
Count the total MB in that folder, multiply it by 2 (for ~classical) and compare with how much you have free on drive C:.
Tight ?
Short ?
« Reply #16 on: December 14, 2017, 09:58:07 pm »
Hi Juan,
Seem much to me.
Tight ?
Short ?
Drive C: Capacity :12.6Gb. Free: 1.48Gb
De-Forma Sonata :1.09Gb x 2= 2.18Gb  unhappy
Alyn Cosker : 1.65Gb x 2= 3.3Gb  unhappy unhappy
How can I free up some space in C:?
« Reply #17 on: December 15, 2017, 08:04:06 am »
Hi Juan,
You can't. You must take it into account ...
What you can do is expand the OS file, at the cost of internal memory. But this will be marginal ...
Just play half Hires albums at the time.
« Reply #18 on: December 19, 2017, 05:04:52 pm »
Hi Juan,
Hi Peter, with the amount of memory I have, 24Gb, I can load 3 maybe 4 flac albums. The problem is with the high resolution files with a size of more than 1Gb. Does it have to do with the current settings?
« Reply #19 on: December 19, 2017, 05:59:26 pm »
Hi Juan,
You may have 24GB, but your defined disk size won't be that. So it is about the DISK size, which resides in RAM ... (RAM OS Disk).
Understand ?
So just look at the size of your C: Drive. That's what you've got and that's what's too tight.
« Reply #20 on: December 19, 2017, 09:40:52 pm »
Now I'm writing from my phone to see if this way what I write remains in the post. Yesterday the W10 in my working laptop received automatically a major update, maybe that could be the reason of the erratic behavior
« Reply #21 on: December 19, 2017, 10:10:59 pm »
The update of W10 on my laptop could be the problem. Being an automatic update maybe others could also have problems
« Reply #22 on: December 19, 2017, 10:13:17 pm »
The update of W10 on my laptop could be the problem. Being an automatic update maybe others could also have problems. Not sure though because here with my phone I'm receiving also the same error messages
« Reply #23 on: December 20, 2017, 03:59:48 pm »
Hi Juan,
Understand ?
Hi Peter, Let's continue with the previous posts to see if everything works well now.
Regarding the lack of space on my virtual hard drive C: I do not remember how I did the distribution of the space between C: and the Ram, I think it was 50% 12Gb for each one. Do you think I could distribute the space in a better way?
Best regards
PS As I lost the signature I have adapted yours because it is almost the same
« Reply #24 on: December 20, 2017, 04:02:27 pm »
 It looks like it works again smile
« Reply #25 on: December 21, 2017, 03:12:42 pm »
Hi Juan,
Here is your old signature :
XXHighEnd v2.09, 24GB memory, 12 cores (6+6), Windows 10 Pro 64 bit build 14393.0 from RAM, music on LAN / Engine#4 Adaptive Mode / Q1/-/3/4/5 = 30/-/1/1/1/ Q1Factor = 40 / Dev.Buffer = 4096 / ClockRes = 15ms / Memory = Straight Contiguous / Include Garbage Collect / SFS = 8.98  (max 120) / not Invert / Phase Alignment Off / Playerprio = Low / ThreadPrio = Realtime / Scheme = Core 3-5 / Not Switch Processors during Playback = Off/ Playback Drive none (see OS from RAM) / UnAttended (Just Start) / Always Copy to XX Drive (see OS from RAM) / Stop Desktop, Remaining, WASAPI and W10 services / Use Remote Desktop / Keep LAN - Not Persist / WallPaper On / OSD Off / Running Time Off / Minimize OS / XTweaks : Balanced Load = 43 / Nervous Rate = 100 / Cool when Idle = n.a / Provide Stable Power = 0 / Utilize Cores always = 1 / Time Performance Index = Optimal / Time Stability = Stable / Custom Filtering Low for 705600 / Always Clear Proxy before Playbck = On -> USB3 from MoBo -> Lush USB 1m -> Phisolator 24/768 Phasure NOS1a/G3 75B (BNC Out) async USB DAC, Driver v1.0.4 (16ms) -> B'ASS Current Amplifier -> Blaxius Interlink -> Genelec 1037B 3-Way Active Speaker
But I don't think it is different anywhere ?
Edit : But this was grabbed at December 19, around 10pm (your time). Maybe you already re-entered it and we grabbed that version you already re-entered ?
« Reply #26 on: December 21, 2017, 03:23:11 pm »
Hi Peter, that's the signature I adapted from your signature. My old one is lost. No problem anyway, the old one was too long
« Reply #27 on: December 21, 2017, 03:25:28 pm »
Juan, you are right :
Audio Pc: Processor i7 970: 3200MHz (reduced to 1668MHz), 6+6 cores/ RAM Corsair DDR3, 24Gb, 1333MHz/ Mb Asus X58 Sabertooth/ OS and XXHE in Peter´s RAM-Disk / The CPU fan is the only one in the Audio Pc: NF-S12A (600rpm/6.7db)/ No graphic card/ Power supply: Seasonic SS-400FL2, fanless.
Configuration and Updates in HOW I´VE BUILT MY NEW PC...http://www.phasure.com/index.php?topic=1673.0
XXHighEnd: 2.09. Windows 10 Pro 64 bit build 14393.0 from RAM, music on LAN/ KS:Phasure NOS1 Out 4.0/ #4 Engine/ Adaptive Mode/ Q1=30 Q3=1, Q4=1, Q5=1, xQ1=40/ Dev.Buffer: 4096/ ClockRes: 15ms/ Straight Contiguous/ SFS: 8,00 (max 120)/ Not Invert/ Phase Alignment Off/ Allow format change/ Decode HDCD/ Playerprio: Low/ ThreadPrio: Real Time/ Scheme: Core 3-5/ UnAttended/ Not Switch during Playback Off/ Playback Drive none/ UnAttended/ Include Garbage Collect/ Copy to XX Drive by standard/ Always clear Proxy before Playback/ Stop Desktop Services/ Stop Remaining Services/ Stop All Services: Off/ Keep LAN Services: On - Persist: Off/ Use Remote Desktop/ Minimize OS/ XTweaks : Balanced Load 43/ Nervous Rate 100/ Cool when Idle -/ Provide Stable Power 0/ Utilize Cores always 1/ Time Performance Index: Optimal / Time Stability: Stable / Custom Filter: 705600 Low.
Music Server PC (W10) totally silent with OS (W10) in SSD and music inside in SSDs - RDC > Ethernet Gigabyte cable 3m > Audio Pc > 1m USB Lush cable directly from the USB3.0 in the motherboard > PHASURE NOS1a-75B-G3 (Driver v1.0.4) 8ms > Blaxius BNC interconnects > Genelec 1037B 3-Way Active speakers with BNC inputs
Too long. Happy
This is from Google cache.
« Reply #28 on: December 21, 2017, 04:30:29 pm »
 thankyou
