November 23, 2024, 01:06:09 pm *
Author Topic: MQA album playback skips second half of tracks  (Read 16211 times)
Arjan
« on: November 25, 2017, 04:48:12 pm »
Maybe just a setting, but when I play MQA albums the tracks are ended to soon. They are halfway when new track starts.
With single tracks no issues.
As far as I know I use the currently best suggested settings.
By the way I like the SQ of MQA, fuller and rounder sound. Not harsh at all!
Regards
March, 2024 (2.11)
« Reply #1 on: November 25, 2017, 07:01:32 pm »
Hi Arjan,
Can you show me a screenshot of an in the Playlist Area loaded MQA album, the left pane visible including the Coverart and Sampling Rates etc. ?
Arjan
« Reply #2 on: November 26, 2017, 10:42:32 am »
Attached the screens. The Endless River of Pink Floyd I tried it a couple of times and every time the tracks ended to soon. Example track 2 ends after 3 or so minutes.
I also tried Ghost Stories of Coldplay and that album gave no issues.
regards
March, 2024 (2.11)
« Reply #3 on: November 26, 2017, 05:24:53 pm »
Hi Arjan,
I think this is a combination of having all fine on the Audio PC, but not having the MQA decoder working on the "Tidal" PC. The Coldplay works (but doesn't) because it is 44.1. The MQA decoder works when you see the sampling rate next to the MQA icon. See below for the (right hand) Cold Play one.
Also, for an e.g. 96 the input sampling rate must be 96, not 48 as your screenshot shows. Of course you can only see what it should be once you have that icon on it.
For next attempts, throw first all what's MQA out again. So you need to re-Prepare. In the Library Area you will see the sampling rate icons already from the Search Result.
It requires 2.09 on that Tidal PC. Can that be the culprit ?
Arjan
« Reply #4 on: November 26, 2017, 08:49:39 pm »
The Tidal PC is a Windows 8 laptop with XXHE 2.09 on it.
I get the attached error when downloading the MQA files.
But it is only about the Sample Rate logo....although.
For test I have unpacked the dll's from the 208VCRT-x64.rar. But that did not change anyting...
Maybe I have the reinstall XXHE on the laptop?
regards
March, 2024 (2.11)
« Reply #5 on: November 26, 2017, 11:15:28 pm »
Arjan, can you try a random other PC ?
I have talked about this earlier on. Once happening like this, no solution is known.
Arjan
« Reply #6 on: November 26, 2017, 11:36:28 pm »
No problem, will do.
But what am I listening to now? Placebo.....?
Regards
March, 2024 (2.11)
briefremarks
« Reply #7 on: November 27, 2017, 09:13:52 am »
I get the same message as Arjan when I try to prepare an MQA files (The Eagles - The Eagles again), and end up with a 24/48 file. It appears that the MQA unfolding is not happening.  Will try on another machine.  Is there some way to keep the activation from previous machine?
XXHE version 2.11.
« Reply #8 on: November 27, 2017, 09:44:03 am »
No, I'm sorry.
This is a really nasty problem which can't be solved once it is occurring; it is the combination of a Microsoft problem which can emerge once the OS is upgraded at some stage plus the "code base" as used by MQA which does not allow an "easier version". I had a hard time finding a PC which does not work myself, eventually found one (W8.1) and with all the patches and MS updates of the world, I could not get it going.
But in the end there is something else ... Look at the message (from Arjan) you refer to. I tink that was my intention to happen (never mind, it's only a logo). But it seems that this got its own life and now decoding won't happen on a PC which actually can do it (Arjan's example). This is a bit daft ... and already put in my todo. But don't hold your breath for it, OK ?
briefremarks
« Reply #9 on: November 27, 2017, 09:59:33 am »
It's interesting I was able to fix the problem, and get MQA icon with the 192 on it, and prepare a 24/96 file.  The only change I made was in the configuration of the Sound Device.  Set "sample rate and bit depth when running in shared mode" to 24/96."  At least this worked with the default sound device on my laptop.
Ramesh
XXHE version 2.11.
« Reply #10 on: November 27, 2017, 10:06:42 am »
WHAT ?!
And prior to this it was what ?
briefremarks
« Reply #11 on: November 27, 2017, 10:31:44 am »
Before this it was 24/48 which is the default Windows 10 setup!
Anyway all is working.  I am able to prepare MQA files on the Tidal laptop, move the USB drive to the music server and everything works!!  Great.  Listening now to some actually decoded MQA to see how it sounds. So far sounding very good.
Ramesh
XXHE version 2.11.
Arjan
« Reply #12 on: November 27, 2017, 11:26:10 pm »
Tried the music server first, but same issue. This is an from windows8 upgraded pc.
Next the work laptop (real windows10) and that works fine.
Saw that for the first MQA download two extra installs were done.
No time to listen now, will do that another evening this week.
regards
March, 2024 (2.11)
« Reply #13 on: November 28, 2017, 05:04:14 am »
Hi Arjan,
Do you mean that Ramesh' solution works fine for that laptop ?
Or that is all just worked out of the box for this laptop ?
Arjan
« Reply #14 on: November 28, 2017, 10:55:44 am »
Out of the box.
I missed Ramesh solution. Will try it on the others laptop.
Regards
March, 2024 (2.11)
Page created in 0.127 seconds with 19 queries.
