November 23, 2024, 01:42:45 pm *
Author Topic: New XXHE Install: Specified module could not be found  (Read 16539 times)
« Reply #15 on: November 27, 2017, 05:14:08 am »
I will go ahead with activation, and I should be set.
Hi Ramesh. That is what I meant with my "do you really care ?".
After that (Activation) we can try to find out whether the low level is normal or not, for that laptop. But by now I could point you to the system volume which maybe could attenuate the sound. I don't think it can, but ... (a lot of things might have changed since this was all developed).
Good luck now and thanks for holding on !
