November 22, 2024, 03:46:34 pm *
Pages: 1 2 3 4 5 [6] 7 8  All
Author Topic: MQA decoding issue  (Read 87739 times)
hudesigns
« Reply #75 on: April 03, 2018, 06:25:46 pm »
This may not be relevant at all. But I checked my Tidal related operations: Tidal is installed in music PC with all related folders in local HDD (local to music PC). All Tidal stream preparations are formed locally and all downloading, preparing and moving are performed one album by one album. My audio PC accesses all Tidal files from music PC via LAN. So in a sense my audio PC also serves a NAS.
ZH
« Reply #76 on: April 04, 2018, 08:37:08 am »
Thank you Zheng. And might it be important, I myself have it that way too.
« Reply #77 on: April 06, 2018, 07:16:46 am »
Have you been able to figure out what could be going wrong? I tried booting into Base OS too but that doesn’t work either.
« Reply #78 on: April 06, 2018, 08:06:59 am »
Hi Arvind,
I am out of ideas (already was). What remains is Teamviewer ...
Just give me access to your Music Server PC (the one which is used for Tidal *and* which has access to your Stealth (remote control) and I should be able to try a few things from there. This already was my idea 24 hour ago, but yesterday I managed to not find the time for it. sorry
See you in email ...
« Reply #79 on: April 06, 2018, 09:44:27 am »
Sure will set it up in about 3 to 4 hrs, once I’m back home & will email you. Thanks.
hudesigns
« Reply #80 on: April 07, 2018, 03:30:54 am »
Today I downloaded iFi newly release firmware 5.3 that enables MQA decoding upto 384kHz sources. But to my disappointment that I was not able to decode 192 MQA albums to its original sample rate. the best I could do via XXHE is upto 48kHz with MQA decoding off.
If I play directly from Tidal with MQA passthrough on, I got upto 48kHz and with passthrough off, upto 96kHz
Now I searched iFi company troubleshooting forum and found this answer from iFi technician:
Question: On TIDAL I play an MQA 192KHz file but it displays another sampling rate?
Answer: Typicall those albums are encoded as 48kHz MQA file. Meaning Tidal will perform the decoding to a 96kHz audio stream with the MQA renderer handling the further decoding which this has nothing to do with our products, this is how MQA & Tidal works.
To test that the actual audio stream in TIDAL is 48KHz please select "MQA passthrough", it is 96k if TIDAL decodes MQA, it is 48k on MQA pass-through.
Question: But I thought the file was 192KHz remastered?
Answer: Yes, meaning it was MQA encoded from a 192KHz remaster.
Our MQA implementation handles up to 384KHz MQA sources correctly according to MQA specifications.
I think I started to understand what Tidal is doing with MQA right now... I just want to get your opinion first. In the meantime I want to find a true 192 or up MQA encoded file to see if the iFi tech is not lying!
Best,
Zheng
hudesigns
« Reply #81 on: April 07, 2018, 04:15:21 am »
I did download a MQA encoded track "MAGNIFICAT 4. Et misericordia" from 2L but XXHE played it as 44.1 FLAC with either mqa decoding on or off. And the iFi MQA enabled DAC processes it as 44.1
I always set the volume at 0.0 to be bit-perfect.
ZH
« Reply #82 on: April 07, 2018, 08:56:16 am »
Haha, or maybe not ...
I see nothing wrong so far.
The file you'll receive from Tidal is 24/44.1 or 24/48. This is just how it should be. This is also how XXHighEnd should output it, so your MQA DAC can start from the beginning which is the decoding (AKA first unfold). From there it becomes 24/88.2 or 24/96 and assumed the Rendering part in your MQA DAC is also active, it will become 24/176.4 or 24/192 if the file was that natively.
Notice that files can be natively 44.1 or 48 or 88.2 or 96 ( or 352.8 ).
Understand a little ? Does it help ?
« Reply #83 on: April 07, 2018, 10:24:01 am »
Solved;
There was a bit of code left behind that eventually required the decoding on the Music Server PC after all.
In the download topic for 2.10 there's now (soon) a 2.10a patch at the very bottom. This will be required on the Music Server PC (only) and only for those who can/could not get the decoding going on the Music Server PC to begin with.
Watch out : The MQA albums of concern must be re-prepared in full for this to work. Thus, delete their folder structure, re-search them and Prepare them.
To be clear, the exhibit without 2.10a for some :
- Albums are Prepared on the Music Server PC (this PC accessing Tidal);
- On the Audio PC now MQA Decoding does not work, while the Audio PC is "modern" as such and contains a fresh install of Windows (say that W10 is always sufficiently modern).
The problem without 2.10a is that the Music Server PC (often running an older or upgraded Windows version) requires MQA decoding, while this is impossible. 2.10a solves this.
Arvind, thank you for holding on !
« Reply #84 on: April 07, 2018, 11:40:21 am »
The Eagles MQA 192 album that you prepared after upgrading to 2.10a still has 2 problems:
1) The input sampling rate shows 96 even though the cover art shows MQA 192.
2) Above [G] the FLAC logo shows.
I prepared another MQA96 album. Input sampling rate shows 96, however above [G] it still shows FLAC.
« Reply #85 on: April 07, 2018, 11:52:08 am »
attached are the images of both albums.
« Reply #86 on: April 07, 2018, 12:49:09 pm »
Arvind,
But it plays (at the right speed) ?
« Reply #87 on: April 07, 2018, 12:58:18 pm »
Oh yes it plays. Right speed too.
« Reply #88 on: April 07, 2018, 01:12:32 pm »
OK, thanks.
Working on it ...
« Reply #89 on: April 07, 2018, 03:44:28 pm »
Arvind - I found that problem. There will be a 2.10c soon for this.
The decoding is just fine, only that logo not.
