November 22, 2024, 04:00:50 pm *
Pages: 1 2 3 4 [5] 6 7 8  All
Author Topic: MQA decoding issue  (Read 87740 times)
« Reply #60 on: April 02, 2018, 02:00:44 pm »
Look below.
That is mine. Freshly searched for and Prepared. Also Volume Normalized and even still in the Intermediate structure, just like yours. Same version of the album. Both XXHighEnd 2.10.
Same XXHighEnd PC and same OS software if all is right.
Still mine works and yours does not.
Before I do what you asked, I wanted to point out that the image I sent you was from the Audio PC, not the Music Server laptop (where I prepare the streams). Secondly I had already moved the prepared stream to the Streaming folder. I do have XXHE 2.10 in the Music Server too. Thirdly I started playback from the Audio PC via streaming folder.
« Reply #61 on: April 02, 2018, 03:00:39 pm »
Arvind, OK. What I tested tells only that there is no difference between playing from the Intermediate structure vs playing from the Streams structure. So never mind that part. Best though is for now to do exactly what I said because I just tested that path over here. So we should be able to end up with the same result when we both do the same.
« Reply #62 on: April 02, 2018, 03:01:59 pm »
Attached is the image (3) from the Music Server during playback of one track. Vol Norm remains same as -13.5dB. However a window pops up.
This is with fresh prepared stream.
MQA/HDCD decoding is active.
Attached is an image (4) of the Audio PC, after moving the stream to the Streaming folder & playing back from the Audio PC. However this time in the taskbar i saw a window mentioning 2.xx\QA2.dll but then it disappeared very quickly & playback started.
« Reply #63 on: April 02, 2018, 03:38:00 pm »
Hi Arvind,
We're in a loop now and we already talked through that no playback is required (nor often possible) on the Music Server.
So most probably this is how it's done that things get arranged for wrongly (so to speak).
Please do all again but now with the notice :
- Prepare is ONLY to be done on the Music Server PC.
- Audio Playback is ONLY to be done on the Audio PC.
OK ?
hudesigns
« Reply #64 on: April 02, 2018, 04:16:27 pm »
Hi Peter and Arvind,
I don't want to be rude but this happened to me few times - a seemingly well prepared MQA album is played back at 48kHz as Flac. But everytime I resolved the issue simply by rebooting the audio PC (right-click "Stop" and select "Reboot"). For some reason it has stopped occurring now.
Best,
Zheng
« Reply #65 on: April 02, 2018, 04:33:35 pm »
Unfortunately the same status again. Image is attached which tells the whole story.
Thanks Zheng, will try that too after Peter looks at this.
« Reply #66 on: April 02, 2018, 05:09:09 pm »
Hello Arvind,
Yes, that you now have one track in there which is not what I showed. So again it looks like Preparation for one track only ... (looks, not guaranteed at all).
You know about RightClick on the Library Item (in the Music Server PC !) - Streams - Prepare Streams, do you ? (see below screenshot).
Otherwise please don't hesitate to do what Zheng proposes. I don't know anything about it, but who knows ...
« Reply #67 on: April 02, 2018, 05:41:45 pm »
No Peter I prepared the entire album. I just played one track & removed the rest from the playlist.
Yes preparing streams is the same way as you mentioned. Nothing different between MQA & non MQA.
Rebooting doesn’t help either.
« Reply #68 on: April 02, 2018, 05:55:40 pm »
All right Arvind, then I am at a loss what is going on with your Audio PC.
Can you imagine anything not being "original" from when you received it at first ? I mean, you can have been swapping RAM-OS Disks, for example.
So with all your efforts as of now, I am in a stage of "this can not be".
Hmm ... What if your first MQA-Decode attempt requires Normal OS ? ... If that is so then it resembles a kind of what Zheng experienced (I did not witness that - he just told about it today afaik).
Btw, there's logging about this too. So if you engage that and press Play (can just be Attended) and grab the XX log file of that and attach it to a post here, I may be able to at least prove that your decoding does not work.
But please try Normal OS first because when it requires some install I am not aware of, then it's that.
Sorry for your troubles !
hudesigns
« Reply #69 on: April 02, 2018, 06:10:24 pm »
I will report here once I get one of these glitches. I don't remember the reboot requires a trip to Normal OS state and back. Just want to be of some help.  Happy
ZH
« Reply #70 on: April 02, 2018, 06:17:45 pm »
Yes, and this is VERY much appreciated !!
Thank you Zheng,
« Reply #71 on: April 02, 2018, 06:21:59 pm »
Attached is an image of a window popping up in the taskbar as soon as I hit play. Also attached is the XX log files.
Normal OS is of no help either.
And nothing changed in my Audio PC. Neither swapping of the RAM-OS Disk.
* XX-20180402-213738.log (13.5 KB - downloaded 452 times.)
« Reply #72 on: April 02, 2018, 06:34:40 pm »
Arvind - that popup is fine and not related (well, it is good that it is there).
How was that again with your NAS and Coverart not showing (I really already forgot). Can't this be a similar issue ?
So notice that you can't test by moving around the data (structure etc.). You could, however, change the Intermediate File Folder as well as the Tidal Folder to something which is not-NAS.
Remember, the MQA determination which previously (2.09) happend per MQA decoding itself on the Music Server PC, now changes to looking in the FLAC header ...
The MQA decoding just seems to be OK (log file). But the "detection" as per FLAC header seems not ... (I am not really experienced in debugging that, as it is brand new).
Btw, I call it a day now. You should too. Happy Happy
« Reply #73 on: April 03, 2018, 06:25:02 am »
It can't be the same issue as coverart on NAS as in this case, I have Tidal database on a HDD.
« Reply #74 on: April 03, 2018, 09:11:57 am »
scratching
