« on: November 17, 2017, 12:48:17 pm » |
Hey Peter, I'm having a problem decoding MQA. I've only tried a couple of albums from Tidal, and both give the same error (below) just before playback commences.
If I switch off 'decode HDCD + MQA', then everything works fine.
Any ideas?
« Reply #1 on: November 17, 2017, 01:16:31 pm » |
I'm afraid you have a decoding issue. See below for how it is supposed to look and mind the "96" icon in the bottom right corner. If you see nothing of this anywhere in your Library Area then on that PC the decoding does not work. Btw, I take it that you use 2.09 for this (the Tidal-approaching PC !) ? because that *is* required ...
Regards, Peter
« Reply #2 on: November 17, 2017, 01:36:47 pm » |
The issue is identical on my Phasure audio PC too...
I think I've found the issue:
It seems to be a base rate problem (44.1 vs 48). MQA 44.1 rates work fine (see below), however 48 rates don't. The issue seems to stem from my music server. I get the error shown below when preparing streams.
« Reply #3 on: November 17, 2017, 01:55:17 pm » |
I selected another DAC in my music server, and everything seems to be working OK now.
Thanks.
« Reply #4 on: November 17, 2017, 01:59:49 pm » |
Hi again Mani, I get the error shown below when preparing streams. Well, that nicely testifies of what I was saying. I don't think anything works fine because any "96" album should show 96 for base rate and not 48. Your decoding just does not work and it *has* to work already on the PC where you Prepare things, or otherwise nothing works. I don't see you responding to my 2.09 remark, so I take it that you don't use that on the "Tidal" PC. Haha. Notice that it is best for you (at this moment) would be that you always retry all from the start. So throw out that Robert Plant, Search for it again - and that is sufficient to prove that it works or not, because as said, that 96 icon should appear in the Library Area('s Coverart) already. Peter
« Reply #5 on: November 17, 2017, 02:12:18 pm » |
Your decoding just does not work and it *has* to work already on the PC where you Prepare things, or otherwise nothing works. I don't see you responding to my 2.09 remark, so I take it that you don't use that on the "Tidal" PC. Haha. I upgraded to 2.09 on the music server ('Tidal' PC) before trying anything. I deleted and re-prepared the MQA albums. Everything works fine. Thanks. Mani.
« Reply #6 on: November 17, 2017, 04:06:33 pm » |
OK, thank you for bearing with me !
Regards, Peter
Rmalits
« Reply #7 on: December 04, 2017, 11:37:29 pm » |
I started to test MQA today and installed 2.09 on my music PC.
I have the same decoding problem with the same error message like above: "Something went wrong with FLAC decoding...". When I download MQA files nevertheless, all of them are decoded to 48 ones and will not play. I cannot solve this issue.
Kind regards Richard
briefremarks
« Reply #8 on: December 05, 2017, 06:42:20 am » |
Richard,
I had a problem that I was able to fix by making sure the setting for the sound device "Select the sample rate and bit depth when running in shared mode" to be 24/96. Other settings may work. The default Windows setting of 16/44.1 is a problem, as well as anything below 96.
May not help, but worth trying.
Ramesh
Rmalits
« Reply #9 on: December 05, 2017, 09:08:26 am » |
Ramesh,
thanks for this info. The problem probably is located here. But for the Realtec speaker, the sound device on my Microsoft Surface Pro, the max. values are 48/24. Therefore I am still limited to 48kHz.
Is there any idea how to solve that?
« Reply #10 on: December 05, 2017, 09:57:12 am » |
Richard, I had a similar issue. All I did was stick an old Audioquest Dragonfly that I had lying around into one of the USB ports of my server and select that as the sound device in XX. You may then have to do as Ramesh suggests too (I don't recall having to do this myself though).
Do you have an old 24/96-capable USB DAC hanging around? (It doesn't even have to be connected to an amp or anything.)
« Reply #11 on: December 05, 2017, 11:27:24 am » |
Richard ... or install the NOS1 driver and connect your NOS1(a/G3). If it is a Windows 10 then you will first need to shut off the Driver Siging (in XXHighEnd's settings).
Quite a useless remark : On a side note (or not) I myself am unsure about how the "48" setting in the Sound Device can be related. OK, surely you won't be able to play (88.2 or 96) but why the Decoding (or MQA detection at first) would fail on this ... But hard to try for me just the same.
Rmalits
« Reply #12 on: December 13, 2017, 06:46:17 pm » |
Hi there,
thanks a lot for all your advices. For some hours now I tried different DACs and settings for Microsoft Surface 3 Pro with Windows 8.1 running on it.
Now I plugged in my ifi iDSD DAC into the USB port installed the audio driver and finally got it to play my PCM files up to 192/24 with XXHE. The settings for the audio decive in shared mode are set to 192/32. What's still strange though, when playing in attanded mode, the time counter always shows 00:00, but music plays in ok quality.
But still XXHE doesn't decode MQA higher than 48/24. I don't know, what to do now to solve this problem. Are there any ideas?
« Reply #13 on: December 14, 2017, 06:19:40 am » |
Richard, I don't know what you all did or omitted, but notice that once you've got something running, you must throw out all MQA (so also the search results !), research it, prepare it and then retry. And if that still does not help, try another PC ... Sadly is it no different and it is not going to change either. Peter
« Reply #14 on: December 14, 2017, 08:35:56 am » |
And Richard, mind the "Hires Audio" tags to the (right) side of the MQA logo. If they are not there, the decoder does not work on the PC where you search Tidal. So tell me if you see them ...
