November 23, 2024, 01:05:26 am *
Author Topic: "new" win10 version  (Read 10465 times)
hvdh
« on: November 12, 2017, 04:27:55 pm »
While browsing the net, I stumbled onto this link:
http://www.majorgeeks.com/files/details/windows_10_home_no_bloatware_edition_64_bit.html
I wonder if this could be a good starting point for peter to build an even better sounding OS??
I never knew this kind of windows was available:)
Win10 14393.0 / music on LAN /  / Q1/-/3/4/5 = 30/-/1/1/1 / xQ1 = 40 / Dev.Buffer = 4096 / ClockRes = 15ms / Memory = Straight Contiguous / Not Include Garbage Collect / SFS = 20.19  (max 60) / not Invert / Phase Alignment Off / Playerprio = Low / ThreadPrio = Realtime / Scheme = Core 3-5 / Not Switch Processors during Playback = Off/  / UnAttended (Just Start) / Always Copy to XX Drive / Stop Desktop-Remaining-WASAPI-W10 Services / Keep LAN - Persist / WallPaper On / OSD On / Running Time Off / Minimize OS / XTweaks : Balanced Load = 42 / Nervous Rate = 100 / Cool when Idle = 1 / Provide Stable Power = 1 / Utilize Cores always = 1 / Time Performance Index = Optimal / Time Stability = Stable / Arc Predict -> Clairixa USB 0.80 meter -> 24/768 Phasure NOS1a DAC With B'ass and Phisolator -> BAlanced interlink -> Apogee Grand loudspeakers, using STAX dma-x2 (midrange ribbon) / Krell FPB600C (bass ribbon)
If it flies, Don't ground it!
« Reply #1 on: November 12, 2017, 04:41:11 pm »
Hey Henk,
Nah, this won't be of much help. But as said in there, you can create such a leaner version yourself (with a lot of work).
Keep in mind that you'll need the Pro version, assumed you want to use RDC to the OS.
Thank you Henk,
