November 23, 2024, 02:31:14 am *
Author Topic: No text after playing in Minimized OS unattended, only visuals  (Read 8123 times)
bodiebill
« on: November 11, 2017, 05:57:34 pm »
After using XXHE for some time under Windows Server 2016 (with some quirks), I recently installed Windows 10 build 15063. So far so good: the sound is almost as good, and I did not try changing any SQ-related settings yet.
However, after playing in Minimized OS unattended, when the screen comes back up after pressing Alt-X, I see only non-textual elements of XXHE, and also of other programs. Almost all text (including button text) has disappeared. See screenshot.
Is this a known problem for build 15063? Any way to solve this?
Windows 10 Enterprise LTSB 1607 build 14393.0 (tentative settings, still experimenting)
HDPlex 100W Linear PSU / Streacom FC5 / HDPLEX 250W Hi-Fi DC-ATX PS converter / Supermicro X11SAE -> Intel i3-6100T with Hyperthreading Off (2 cores), C-States Off, ECC RAM 16GB / music on LAN / XXHighEnd on A: (3GB RAMDisk) / Engine#4 Adaptive Mode / Q1=14, Q3=1, Q4=1, Q5=1 / Q1Factor = 1 / Dev.Buffer = 2048 / ClockRes = 15ms / Memory = Straight Contiguous / Include Garbage Collect / SFS = 0,1 (max 60) / not Invert / Phase Alignment Off / PlayerPrio = Low / ThreadPrio = Realtime / Scheme = No Appointment / Not Switch Processors during Playback = Off/ Playback Drive B: (3GB RAMDisk) / UnAttended (Just Start) / Stop Desktop-, Remaining-, WASAPI-Services / Keep LAN - Not Persist / Don't do anything with WallPaper / Minimize OS / XTweaks : Balanced Load = 43 / Nervous Rate = 1 / Cool when Idle = n.a. / Provide Stable Power = 0 / Utilize Cores always = 1 / Time Performance Index = *Optimal* / Time Stability = *Stable* / Custom Filter *Low* 705600 / Upsampling ? / -> USB3 *from MoBo* -> Lampizator USB cable -> nas4free music server or local MS-EX SLC usb drive / HDPlex Linear PSU / Streacom FC5 PC i3-6100T 16GB RAM / Windows 10 Enterprise LTSB / XXHighEnd  with minimized OS / APlayer with foo_dsd_asio (optional: Audiophile Optimizer 2.20b5 / Fidelizer Pro ) or WTFplay (Linux) / SOtM tX-USBhubEX / Audiophilleo 1 + Pure Power + Audio Aéro Prestige Signature or Uptone Regen + Lampizator Lite 7 DSD256 / Lightspeed Attenuator / Cayin A-88T / Spendor SP100 + 2x REL T5 / Taket H2 + TR2; Hifiman HE-6
« Reply #1 on: November 11, 2017, 06:17:32 pm »
Hi Dennis,
Well ... that seems bad luck for you then. Maybe you don't really need the text ? swoon
Is this in Normal OS already ? (if so, you can always try MinOS and cross a few fingers)
But maybe it was not a wise thing to do. There is no official support beyond 14393.0. I do have 15063.0 all right (for many months by now) but can't find the time to do something with it. Besides, the prospect is not good SQ wise (too much overhead in that build, of what I read on the Net).
bodiebill
« Reply #2 on: November 11, 2017, 06:27:04 pm »
Thanks, Peter, I already thought so much. When I find the time (and the build) I will try again with 14393... Cheers, Dennis
bodiebill
« Reply #3 on: November 11, 2017, 06:34:57 pm »
oh and Peter, I may still have a Windows 10 build 14393 Education edition lying around. Would that work? It may have extra functionalities, but also lacks some, which could be a good thing. For instance, no Cortana on the Education version, I believe.
Best, Dennis
« Reply #4 on: November 11, 2017, 07:05:24 pm »
Dennis, if that Education version is 14393.0 then it should be fine. However, take care that it can do RDC or otherwise you have no remote ...
hvdh
« Reply #5 on: November 11, 2017, 07:38:19 pm »
I downloaded 14393 from here a few weeks ago. works like a charm , installed over my old win10 10586, which previously replaced a win7 ultimate activated version...
http://windowsiso.net/windows-10-iso/windows-10-anniversary-update-1607-download-build-14393-0/
Win10 14393.0 / music on LAN /  / Q1/-/3/4/5 = 30/-/1/1/1 / xQ1 = 40 / Dev.Buffer = 4096 / ClockRes = 15ms / Memory = Straight Contiguous / Not Include Garbage Collect / SFS = 20.19  (max 60) / not Invert / Phase Alignment Off / Playerprio = Low / ThreadPrio = Realtime / Scheme = Core 3-5 / Not Switch Processors during Playback = Off/  / UnAttended (Just Start) / Always Copy to XX Drive / Stop Desktop-Remaining-WASAPI-W10 Services / Keep LAN - Persist / WallPaper On / OSD On / Running Time Off / Minimize OS / XTweaks : Balanced Load = 42 / Nervous Rate = 100 / Cool when Idle = 1 / Provide Stable Power = 1 / Utilize Cores always = 1 / Time Performance Index = Optimal / Time Stability = Stable / Arc Predict -> Clairixa USB 0.80 meter -> 24/768 Phasure NOS1a DAC With B'ass and Phisolator -> BAlanced interlink -> Apogee Grand loudspeakers, using STAX dma-x2 (midrange ribbon) / Krell FPB600C (bass ribbon)
If it flies, Don't ground it!
« Reply #6 on: November 12, 2017, 10:18:57 am »
Thank you Henk.
I have a native 14393.0 (ISO) available for those who want it.
