April 01, 2025, 12:43:34 am *
Author Topic: How to save and open a playlist  (Read 11215 times)
Stanray
« on: November 09, 2017, 11:46:18 pm »
When I create a playlist consisting of separate tracks from various albums, I would like to save it and retrieve it at a later moment.
But I can’t find a way to do this.  scratching
Is it possible anyway and if so, how?
Thanks.
Stanley
« Reply #1 on: November 10, 2017, 12:13:54 pm »
 Pick the tracks you want and put them in the playlist area you can move them up and down into a particular order. Then in the lower right-hand corner where it says playlist there is a box, in there  type the name of the playlisan click on the save button.  it will save the playlist in your data folder
Stanray
« Reply #2 on: November 10, 2017, 03:00:37 pm »
Ahhhhhh, thank you Brian.
The box in the righthand pane was hidden on my iPad.
I have to shrink the left pane to make the box in the righthand pane visible.
Clear now.
Stanley
