November 22, 2024, 11:49:51 pm *
Author Topic: Can't get Tidal URL - 2.09  (Read 6171 times)
coliny
« on: November 09, 2017, 04:41:32 pm »
Tried right click - streams - copy url to clipboard
but got error message:- No URL found.........
Colin
« Reply #1 on: November 09, 2017, 08:48:46 pm »
Colin, is the below the message you're receiving ?
Anywaym I can't understand this one. But maybe I don't know my own software. Just saying ...
coliny
« Reply #2 on: November 10, 2017, 08:03:48 am »
Yes that's the message.
I see now it happens when you try it from the Tidal Temp folder.
It works ok for albums moved to the music root folder.
Colin
« Reply #3 on: November 10, 2017, 04:41:31 pm »
Aha ... clever finding !!
But
I now see that I made a Copy URL to Clipboard on the Item in the Library Area. I think that option is "incomplete" so to speak, because I forgot it is there. If you press Load on the Item and perform rightclick on the coverart in the left pane, it will work.
Thank you Colin,
