November 22, 2024, 09:34:56 pm *
Author Topic: Placement of the speakers with v.2.08  (Read 4082 times)
« on: November 04, 2017, 06:20:49 pm »
If there is something that requires a special meticulousness and that is fundamental for all regardless of the equipment that each one has, it is the correct placement of the speakers. Personally I have always acted starting from a more or less intuitive first position and then modifying this position with small changes and using the ear. We all probably know different methods and recommendations such as the ones from Cardas* and others. Following the latest versions of XXHE, especially from v. 2.08, I have found much difficulty in finding a placement that I like. What I would like to know is if someone, including naturally Peter who commented something about it, has any idea that helps in this regard. Have some of you found the need to move the speakers to get a satisfactory sound with v.2.08 or v.2,09? In such a case, what have you done to get a correct placement?
*http://www.cardas.com/room_setup_main.php
Page created in 0.108 seconds with 19 queries.
