November 23, 2024, 02:33:11 am *
Pages: 1 2 3 4 5 6 [7] 8 9 10 11 12 13  All
Author Topic: 2.09 sound quality  (Read 163241 times)
« Reply #90 on: November 29, 2017, 06:49:13 pm »
Do you guys actually TYPE the number ? So, backspace to erase all in the field, type 9, tab, done.
I have 9.00 in there right now. No problem at all.
Rmalits
« Reply #91 on: November 29, 2017, 06:59:34 pm »
Hi there,
The max SFS value is set high enough.
I now also tried to to change the SFS values with tab. Same thing: uneven digits before the "." are changed to the next lower even one.
What's interesting: When I do this during music playback, after pressing Alt X, uneven values are accepted, but will be rounded down to the next even afterwards.
Kind regards
Richard
Rmalits
« Reply #92 on: November 29, 2017, 07:09:59 pm »
Peter, I can enter 9 for SFS as you wrote. But, the next time XXHE will be started it will be set to 8.
Kind regards
Richard
« Reply #93 on: November 29, 2017, 08:00:13 pm »
when I enter for SFS 11 it's changed to 10
When I enter 11.7 it's changed to 10.7
Try 11.00 first and then smaller steps... this works.
« Reply #94 on: November 29, 2017, 08:11:01 pm »
Peter, Bert, I find it impossible to fix the odd numbers, I tried to do what you say but there is no way
« Reply #95 on: November 29, 2017, 08:13:09 pm »
EDIT: Nope, does not work (it does while playing though...)
« Reply #96 on: November 29, 2017, 08:57:59 pm »
Kind regards
Richard
Richard, you are completely correct. It does not stick after Unattended Playback ...
sorry
« Reply #97 on: November 29, 2017, 09:57:19 pm »
As I wasn't able to put odd numbers in the SFS I always thought that it was normal. On the other hand I don't remember if I have ever seen odd values, except 1.
Peter, can you take a look to my signature to see if there is something wrong, please?
Stanray
« Reply #98 on: November 30, 2017, 10:07:55 am »
Last night I tried SFS settings between 0 and 20.
<6: the sound is detailed, but also a bit "detached".
>14: it becomes too "mushy".
So I settled for SFS=10 and that seems balanced (in my system, for now and with the music I played).
A bit more finetuning:
I now have my SFS=8.80
and the second highest High Filter
Stanley
« Reply #99 on: November 30, 2017, 05:09:20 pm »
Stanley
Stanley, 8.80 seems to be a good value. I tried it with the Low Filter and here the sound is great. I'm also trying 8.0/Low F. that makes the sound a bit cleaner. Better for me here. I'm going to stay there for a while to see what happens. The sound in general is sweeter but I still have to see if some details darken
« Reply #100 on: November 30, 2017, 05:13:44 pm »
Hi Juan,
Looks all fine to me. Happy
« Reply #101 on: November 30, 2017, 05:31:13 pm »
Thanks Peter, I can not think of anything to put the odd numbers. Well, if at any time you find out, please tell me
« Reply #102 on: November 30, 2017, 06:55:58 pm »
Thanks Juan,
Still at 8.8 here but the Low filter makes it most acceptable for me... no more "overshoot" in the higher mid's.
« Reply #103 on: November 30, 2017, 09:10:21 pm »
Thanks Juan,
« Reply #104 on: December 01, 2017, 10:05:12 am »
Now that. smirk
Does anyone know how many freakin' combinations this program has ?
Careful, you ! hehe
