April 05, 2025, 09:43:56 pm *
Pages: 1 2 [3] 4 5 6 7 8 9 10 11 12 13  All
Author Topic: 2.09 sound quality  (Read 166212 times)
bodiebill
« Reply #30 on: November 13, 2017, 09:47:20 am »
I tried Peter's settings as far as possible on my 2-core i3 T6100:
Q1 x xQ1 = 30x40.
Q3,4,5, = 1,1,1.
SFS = 20.
ClockRes = 15ms.
Custom Filter = Highest for 705600.
no Appointment Scheme.
OSD Text = Off.
Wallpaper (front and back) On.
However apart from getting stutters, the Remote Desktop connections is killed immediately after hitting Play.
Any suggestion how I can tweak the above settings, get a bit of the advantage, without the stutters/disconnection?
Best, Dennis
Windows 10 Enterprise LTSB 1607 build 14393.0 (tentative settings, still experimenting)
HDPlex 100W Linear PSU / Streacom FC5 / HDPLEX 250W Hi-Fi DC-ATX PS converter / Supermicro X11SAE -> Intel i3-6100T with Hyperthreading Off (2 cores), C-States Off, ECC RAM 16GB / music on LAN / XXHighEnd on A: (3GB RAMDisk) / Engine#4 Adaptive Mode / Q1=14, Q3=1, Q4=1, Q5=1 / Q1Factor = 1 / Dev.Buffer = 2048 / ClockRes = 15ms / Memory = Straight Contiguous / Include Garbage Collect / SFS = 0,1 (max 60) / not Invert / Phase Alignment Off / PlayerPrio = Low / ThreadPrio = Realtime / Scheme = No Appointment / Not Switch Processors during Playback = Off/ Playback Drive B: (3GB RAMDisk) / UnAttended (Just Start) / Stop Desktop-, Remaining-, WASAPI-Services / Keep LAN - Not Persist / Don't do anything with WallPaper / Minimize OS / XTweaks : Balanced Load = 43 / Nervous Rate = 1 / Cool when Idle = n.a. / Provide Stable Power = 0 / Utilize Cores always = 1 / Time Performance Index = *Optimal* / Time Stability = *Stable* / Custom Filter *Low* 705600 / Upsampling ? / -> USB3 *from MoBo* -> Lampizator USB cable -> nas4free music server or local MS-EX SLC usb drive / HDPlex Linear PSU / Streacom FC5 PC i3-6100T 16GB RAM / Windows 10 Enterprise LTSB / XXHighEnd  with minimized OS / APlayer with foo_dsd_asio (optional: Audiophile Optimizer 2.20b5 / Fidelizer Pro ) or WTFplay (Linux) / SOtM tX-USBhubEX / Audiophilleo 1 + Pure Power + Audio Aéro Prestige Signature or Uptone Regen + Lampizator Lite 7 DSD256 / Lightspeed Attenuator / Cayin A-88T / Spendor SP100 + 2x REL T5 / Taket H2 + TR2; Hifiman HE-6
« Reply #31 on: November 13, 2017, 09:54:54 am »
Dennis,
However apart from getting stutters, de Remote Desktop connections is killed.
That won't be related to mentioned settings. Can be the "Use Remote Desktop" setting or possibly that you try this in Normal OS (W10 versions exist which do that but are OK in MinOS). Or the W10 version itself ...
If you have stuttering with these settings, then I'm afraid you'll need to back out a bit (try a lower xQ1 and see how far you can go with it, upwards). Or, try for your situation how the SFS relates (all works in combination with each other).
« Reply #32 on: November 13, 2017, 10:00:11 am »
Yes Peter, the sound with your latest settings is spectacular. The basses are bigger, not sure that they are also deeper, there's more detail and also the soundstage is wider and deeper. In moments I had the feeling that the upper bass invades a bit the low mids but I can not be sure, I comment it just in case it can give some clue to make an even better sound.
Anyway, I like these settings more than the ones I have until now. As I say, spectacular!
« Reply #33 on: November 13, 2017, 10:09:48 am »
Peter, have you listened to any ACDC with the new settings?  Wow..
Not particularly with these settings, but maybe two weeks ago 3 tracks from my Demo Gallery passed by and I wondered where the nastyness had gone (ADDC is not always the most friendly). But since I was just playing music from a larger playlist, I forgot to revisit it. So I guess I need to now !
I expect guitars with a lot of air in them and with a 2 fold more fundament and even punch. More slick too. Am I right ?
Dirty Deeds was the album and the guitars are just like you say...but the whole presentation is so profound and spectacular and the soundstage sooo very wide and crystal clear.
A while back I made some fancy vibration isolation stuff for the NOS1a G3 and it cleaned up the mids and highs tremendously without changing any software settings.  The change of sound was not subtle and I had to get rid of my cheap-arse speaker cable for something a bit more suitable to tame the presentation...which worked.  Anyway, these new settings combined with my anti-vibration stuff are just fabulous.
« Reply #34 on: November 13, 2017, 10:18:47 am »
Hey Juan,
As you know I use an "open baffle" speaker. OK. Now, at some stage it started to occur to me that the oompf is now happening in about all. It is a very natural "habit" of music, but also pleasent and possibly subjective to what I like. I am now not talking about a bass instrument, but how e.g. a kick drum shows this fundament. But much more. So, at fairly moderate levels (say ~ 87dBSPL or so) for some track I felt the energy in the room, felt my woofers which is easy for me because of the open baffle thing, and started to wonder whether the excursion now not exceeds what I planned with it all. Meaning : more than I ever felt at these levels, like maybe 5mm. Just on hits and giving this lovely pressured feeling (I probably talk BS but this is how it comes across).
With each day passing I get more curious how this can be. And if I were the only one, then fine. But it looks like it works out the same for every one.
Serious warning : I can thus see the level of vastly more energy which must be going into this, while nothing changed anywhere. Say that I'd play really loud and did not expect this, something might break or overheats ?
It reminds me of an XXHighEnd version very long ago (maybe 8 years) that exhibited 16dB of more bass. It won't be that much now, but it could be interesting to see the settings of back then. And I should be able to find the forum posts about it ...
« Reply #35 on: November 13, 2017, 10:21:10 am »
I don't know how we manage to do it, but the 3 tracks in my Demo I was talking about, are from that album.
Thank you, Anthony,
bodiebill
« Reply #36 on: November 13, 2017, 10:45:04 am »
Strangely enough, when I choose Q3,4,5, = 1,1,1 the RD connection is immediately killed after Play, but with Q3,4,5, = 0,0,0 (and the rest the same) the RD connection stays OK.
So there seems to be some relationship between the issue and the Q settings?
« Reply #37 on: November 13, 2017, 10:51:40 am »
Interesting, to say the least ...
Dennis, you will be using "a" Processor Core Appointment setting. The 2 numbers you have chosen represent logical cores (hyperthreaded cores included). Try to find a scheme for your processor which explicitly uses two completely physical others (example : 3-5 will always be on a different physical core than 1-2).
Please let me know the result.
« Reply #38 on: November 13, 2017, 11:03:12 am »
Thanks for the new settings! I have only listened to a few tracks but it makes me more confident to stay with v2.09
Since the upgrade from 2.07 I started to dislike the sound from my system which became rather stressed and even ugly.
Before v2.09 things were more balanced tonally and very pleasant to listen for a longer period. This came back with the new settings although a little towards the too relaxed end.
Could be that I was already used to the "stressed" situation though ...
« Reply #39 on: November 13, 2017, 11:46:15 am »
Hey Bert,
I can imagine your "too relaxed" idea, but it is my advice to give this some time and explicitly watch for detail which now is there from the upper regions (the highest) and how this interacts with the less stressed sound which came fro mthe highs. In other words, how real were those highs previously and :
that.
Otherwise it is really getting used to because the whole presentation is different as different can be. And if we talk about "right" or "wrong" then both situations (say 2.07 and 2.09) can not be right both (both wrong, yes Happy).
Maybe try to focus on what actually lacks. I mean, "too relaxed" could be too subjective as well. Only when it brings you a stuffed ears feeling, it will be explicitly wrong (and that too is related to what you're used to, but alas).
I'll happily receive your final verdict - or again different settings perhaps ?
bodiebill
« Reply #40 on: November 13, 2017, 01:37:52 pm »
I only have 2 cores (i3 6100T) and the only core assignments I can choose are 'No Appointment' or 'Core 1-2'. I chose the latter.
It now seems that the RD problem is related to the Q5 setting: Q5=0 no problem, and Q5=1 RD connection disappears.
And as to stuttering, this seems mostly related to the xQ1 setting. I can get no higher than xQ1=3 stutterless. So now the closest I can get to your settings is:
Q1 x xQ1 = 30x3.
Q3,4,5, = 1,1,0.
SFS = 20.
ClockRes = 15ms.
Appointment Scheme Core 1-2.
OSD Text = Off.
Best, Dennis
dsm
« Reply #41 on: November 13, 2017, 03:12:57 pm »
Hi Dennis,
You need to keep the "persist" button pressed to keep the LAN while unattended (your signature list otherwise). I also need to have  "stop W10 services" unchecked or else I run into troubles and lose connection.
Best,
David
bodiebill
« Reply #42 on: November 13, 2017, 04:58:05 pm »
Thanks David!
All my files are copied to WAV on a local usb drive first, so I never needed the LAN to persist. And I prefer not to, as it may have an effect on SQ.
I will try to uncheck the W10 services when I find the time...
Cheers, Dennis
bodiebill
« Reply #43 on: November 13, 2017, 09:09:36 pm »
update: Checking or unchecking WS 10 services does not make any difference for either problem: anything above xQ1=3 still stutters; and Q5=1 still hangs the RD connection, or even the PC. Tweaking continues.
« Reply #44 on: November 13, 2017, 09:51:02 pm »
Anthony, it would be great if you told us something more about your vibration isolation stuff. With those results, it's worth knowing. Please.
