April 04, 2025, 07:27:46 am *
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 [13]  All
Author Topic: 2.09 sound quality  (Read 166122 times)
« Reply #180 on: March 25, 2018, 04:22:38 am »
Btw, an SFS of 0.08 or 20.0 really won't make a difference for your free memory. It both consumes about nothing (think 100MB for the 20.0).
I finally understand what did you mean here!
My OOM errors are quite random (and harmless most of the times): the sfs doesn’t matter almost at all.
I could be using 20,19 if i wished. When I did xxhe process was using 120MB.
The real problem is that I cannot use straight contiguous unhappy
Hopefully that will be fixed going to 8gb.
Then v2.10 and the new gold standard of 5,19 will be for me too Happy
Stanray
« Reply #181 on: May 07, 2018, 01:09:22 pm »
A while back I made some fancy vibration isolation stuff for the NOS1a G3 and it cleaned up the mids and highs tremendously without changing any software settings.  The change of sound was not subtle and I had to get rid of my cheap-arse speaker cable for something a bit more suitable to tame the presentation...which worked.  Anyway, these new settings combined with my anti-vibration stuff are just fabulous.
Hi Anthony,
Did you ever found the time to finish your anti-vibration project and/or reported about this?
Stanley
« Last Edit: May 09, 2018, 12:08:01 pm by Stanray » Logged
