phantomax
« Reply #150 on: February 18, 2018, 09:20:40 am » |
Tried 10.19 but back to 20.19.
Me too. Probably the tubes in the chain soften in some way the highs but with 10.19 I perceive less spark. Maxi
Audio PC -> AsRock Z79 intel i-3 4170 @~800MHz, 16GB, Windows 10 64 bit build 14393.0 from RAM, DIY Linear Power Supply. music on LAN / Engine#4 Special Mode/Q1/-/3/4/5=*30*/-/*1*/*1*/*1*/ Q1Factor = *5* / Dev.Buffer = 1024 /ClockRes = *15ms* /Memory = Straight Contiguous / Include Garbage Collect / SFS = *0,69* (max 0,69 / Phase Invert / Phase Alignment Off / Playerprio = Low / ThreadPrio = Realtime / Scheme = Core 1-3 / Not Switch Processors during Playback = Off/ Playback Drive none (see OS from RAM) / UnAttended (Just Start) / Always Copy to XX Drive (see OS from RAM) / Stop Desktop, Remaining, WASAPI and W10 services / Use Remote Desktop / Keep LAN - Not Persist / WallPaper On / *OSD Off* / Running Time Off / Minimize OS / XTweaks : Balanced Load = 35 / Nervous Rate = 10 / Cool when Idle = n.a / Provide Stable Power = 1 / Utilize Cores always = 1 / Time Performance Index = Not the best / Time Stability = not stable / *Custom Filtering low for 176400* / Always Clear Proxy before Playbck = On -> Modified Audiotrak Prodigy HD2 internal soundcard with analog tube buffer (Broskie cathode follower) -> Passive biamplification: Canary Audio CA-301 MkII for highs- mids and Counterpoint SA-100 for lows -> Audiovector M-3 Super / modified Musical Fidelity X-3 (6h6p tubes) -> Grado 1000 headphones.
« Reply #151 on: February 18, 2018, 10:57:17 am » |
And you too, thank you for your feedback, Maxi.
The less sparkle with SFS = 10.19 compared with 20.19 is undoubtedly so. Maybe I should let resurrect my ears more because I still think it is related to a cold I suffer from for ... I forgot. Many weeks.
Best regards, Peter
toddn
« Reply #152 on: February 18, 2018, 07:59:01 pm » |
I can’t go back from SFS 20.19 & Arc Predict on 2.09 it is just too good!! Crazy resolution and massively deep & wide soundstage with every performer thoroughly grounded in their own space. Truly intoxicating! I was, although, bothered by upper frequency harshness though, but for me it was solved by raising Q5 to 3! Now I have none of that harshness and the additional benefit of having more body and weight across the frequency range. Truly the best sound I have ever heard All my other settings are Peter’s current defaults. Cheers, Todd
W10-10074 XX HighEnd 2.03 PC -> i7 3930K AS Rock MB W/ Dexa Neutron Star & linear PS supply mod. For Processor Clock, Hyperthreading On (12 cores) @430MHz (!), 16GB, Windows 10 Pro 64 bit Insider Preview build 10074 Samsun SSD, XXHE on 2GB RAMDisk (IMDisk), music on LAN / Engine#4 Adaptive Mode / Q1/-/3/4/5 = 14/-/1/1/1 / Q1Factor = 1 / Dev.Buffer = 4096 / ClockRes = 1ms / Memory = Straight Contiguous / Include Garbage Collect / SFS W10 = .14(max 60) / not Invert / Phase Alignment Off / Playerprio = Low / ThreadPrio = Realtime / W8 Scheme = Core 3-5, W10 Scheme = Core 1-3 / Not Switch Processors during Playback = Off/ Playback Drive 2GB RAMDisk (IMDisk) / UnAttended (Just Start) / All Services Off / Keep LAN - *Not Persist* / WallPaper Off, W10 Running Time Off / Minimize OS / XTweaks : Balanced Load = *63* / Nervous Rate = 1 / Cool when Idle = 1 / Provide Stable Power = 1 / Utilize Cores always = 1 / Time Performance Index = Optimal / Time Stability = On / *Custom Filter Mid 705600* / -> USB3 (Silverstone W/Dexa Neutron Star Clock & Linear PS> *Clairixa USB* -> Uptone Regen w/ Dexa Neutron Star & linear PS -> 24/768 Phasure NOS1a 75B (BNC Out) async USB DAC, Driver v1.0.4b (*4ms*) -> Blaxius BNC interlink -> 8 channels of Hypex NCore 400's -> DYI BD Orphean Horns w/ qty-3 custom 15" open baffle bass drivers and qty-8 12" open baffle subwoofers per channel
« Reply #153 on: February 19, 2018, 12:45:59 pm » |
All my other settings are Peter’s current defaults. Hey Todd ! ... Yeah, well, um ... Scheme = Core 3-5 That's in my sig. But that was NOT was I was using. Somehow I was using 1-3. I don't know when or where that happened, but it must be for a long time already. Yesterday I tried SFS=20.19 again. Well, right from the start it sounded robotic, and it didn't last for a minute. Then I started thinking : what if I'd change completely different settings from usual. Let's try to change the Core Appointment. OK, I did so (from 1-3 to 3-5) and right away I wondered whether that 1-3 actually was "my setting". Only just now in my sig I found it apparently was not at all. Do I care much ? ... Right after the change yesterday, some weird things were happening. The most apparent was "drive". Soon later I thought that the PRaT was abnormal, suddenly. Then I discoverd for the next tracks that all what has been "so-so" but OK, suddenly was wildly good. I thought of having ended up in some trance, but couldn't recognize that for real. Meanwhile it must have been the best couple of hours ever. Really so ! Btw, still on SFS=10.19 but this is not important at this moment. That is, in the mean time I also applied something else which implies more "sparkle", but I won't tell what it is, yet. And Q5 to 3 eh ? ... ok ... will try that. Cheers, Peter
« Reply #154 on: February 19, 2018, 04:58:10 pm » |
Telstar - It is in this topic. Best is to use ctrl-f for search the page and then search for [space]0.9 Then you run into them. If that is what you meant ... Couldn't find anything. Which SFS do you use now? Is it 0.90 or something else, and why? Because of my limited memory I have to use VERY LOW SFS so this interests me particularly.
« Reply #155 on: February 19, 2018, 05:30:20 pm » |
Because of my limited memory I have to use VERY LOW SFS so this interests me particularly. Hi Telstar, Yes, I can see that you are low on memory ... if the previous posts already have been shifted out ... Btw, an SFS of 0.08 or 20.0 really won't make a difference for your free memory. It both consumes about nothing (think 100MB for the 20.0). Regards, Peter
Robert
« Reply #156 on: February 20, 2018, 02:41:41 am » |
Well who would have thought, I tried Core 1-3 with SFS 10.19 and it does work. I also tried core 1-2, 3-4 and 3-5 but not as good as 1-3.
Tried Q5 from 1 to 3 didn't work for me, in fact didn't work with SFS 20.19, Core 3-4 my original. Q5 at 1 now.
Robert
« Reply #157 on: February 21, 2018, 10:08:17 pm » |
Hi I'm back to my original settings. Found Core 1-3 and sfs 10.19 bland.
Something about sfs 20.19 that is crisp and more life like. Prefer my core 3-4. Anyway back to listening.
« Reply #158 on: February 22, 2018, 04:39:40 pm » |
I think I found it, and also where is the two settings everybody is using But I'm gonna start with yours for the generic system first: Q1/-/3/4/5 = 14/-/1/1/1 / Q1Factor = 1 Memory = Straight Contiguous / Include Garbage Collect / SFS = 0.10 (max 60) then 10.19 (max 120) and then 20.19 and report my finding here. After the weekend.
« Reply #159 on: February 22, 2018, 05:22:53 pm » |
I was, although, bothered by upper frequency harshness though, but for me it was solved by raising Q5 to 3! Now I have none of that harshness and the additional benefit of having more body and weight across the frequency range. Truly the best sound I have ever heard Hmm ... for me the Q5 to 3 does not work out, or I must give myself more time to get used to the (over here) more Sllshh sound (too white in the highs). The Q3,4,5 to other than 1 for me is also a psychological thing because I know what it does (and it has to be for the better - haha). Regards, Peter
« Reply #160 on: March 03, 2018, 04:12:43 pm » |
Hey All,
I didn't tell it right away, but for more than a week now I have my SFS at 5.19 (the .19 fraction is by now the explicit left over from any first who dialed that in) and I'd have to say that from the start of this setting up to now it is the most "pleasing of everything" I ever had (for settings). All as snappy as can be, no harsness anywhere, no idea of wrong cymbal colours ... etc. All good. And the mid-detail is crazy. All flies around through all corners of the room in very holographic fashion ... not-normal.
For those who missed the general idea of the consistency of "crucial" to this sound settings :
SFS thus now at 5.19. Q3,4,5=1 ClockRes= 15 No OSD Text (Wallpaper Coverart is active) Core Appointment 3-5 (for any 6 core (hyperthreaded) processor this will be OK) And for those with a NOS1a/G3 : NOS1 Control Panel buffer size = 16ms.
Regards, Peter
« Reply #161 on: March 04, 2018, 02:02:28 pm » |
The only problem is, which has been discussed in the forum earlier, that after setting SFS to 5.19 & playing a track, the SFS, on its own, shifts to 4.19. Only even nos stay set, odd nos shift to the lower even no.
« Reply #162 on: March 04, 2018, 04:25:55 pm » |
The only problem is, which has been discussed in the forum earlier, that after setting SFS to 5.19 & playing a track, the SFS, on its own, shifts to 4.19. Oh, apologies !! I have this active in my own system for so long by now that I completely forgot it is not in 2.09 yet. Sorry for the unmeant teasing !! Best regards, Peter
« Reply #163 on: March 04, 2018, 07:06:28 pm » |
The only problem is, which has been discussed in the forum earlier, that after setting SFS to 5.19 & playing a track, the SFS, on its own, shifts to 4.19. Oh, apologies !! I have this active in my own system for so long by now that I completely forgot it is not in 2.09 yet. Sorry for the unmeant teasing !! Best regards, Peter By when will it be ready? I would like to test that 5.19 Regards Juan
Robert
« Reply #164 on: March 04, 2018, 10:26:19 pm » |
In terms of xxh 2.09, SFS 20.19 still rules in my system.
