November 23, 2024, 02:55:13 am *
Pages: 1 2 3 4 5 6 7 8 9 [10] 11 12 13  All
Author Topic: 2.09 sound quality  (Read 163247 times)
Arjan
« Reply #135 on: January 08, 2018, 11:41:34 am »
Thanks for trying Arc Prediction. I tried all the custom filters and for a long time I loved Low. But after more listening I must say the Mid might be the best for me.
But then I tried Arc Prediction again and for me this sounded really honest. That is how I would call the SQ, the most honest I have ever heard. You could call it dry, but it is o so real.
The only area I am not sure about is the bass. It is sometimes, depending on the type of music, a bit overwhelming. But on the other hand in todays music that is sometimes the case. So maybe it is in the mix.
regards
March, 2024 (2.11)
« Reply #136 on: January 08, 2018, 12:53:09 pm »
Arjan, dry (and short) are positives for me. It allows all to play more in its own space.
In itself this is not new (to XXHighEnd settings) but it relates to the Custom filters which inherently "blend" more. I don't think this will be noticed when going from Arc Prediction to Custom, but the other way around it sure will. It also implies for the more spacious sound, which always occurs to me when switching back to Arc Prediction. I guess this is how I liked the first hour very much, including all the crazy new (background) sounds.
The downside seems to be in the "metallic" reverberation of which I could not find the source, unless emerging in mid-air. So there's something in me that's telling that with Arc Prediction and further new behaviour and settings, there's a razor sharp delimiting of individual frequencies which collide and interact in mid air.
While this is probably some kind of whishful thinking, the other 50% of my thinking goes to audible aliasing (imaging). That this is now audible should be for the same reason, although this is also a technical (filtering thing. Still I can not detect it like being (additional) technical flaw. And a fact that it would be an acoustical thing is only good because apparently we made something audible again, that wasn't. It only should not be the wrong thing.
Btw, throughout it reminded my at my ever back "statement" that a steeldrum became very profound, with a response of Stanley (Stanray) that he always uses that instrument to test SQ. So the music seems to exhibit these kind of sounds now, as a flavour. And that would not be good. And then again, yesterday it alreasy slipped my mind that it actually was so goo all 'n all, that this steepdrum thing would be something for me to solve (somehow).
OK, if nobody recognizes this, it is/was just me.
« Reply #137 on: January 09, 2018, 01:14:35 am »
In my opinion with Arc Prediction the sound is presented with much more detail and in an almost holographic way. My understanding of Peter's concepts of dry and short goes in the direction of clarity and precision in placement in the sound scene. In the long run that clarity becomes fatiguing and may appear as with a metallic personality. For me this sound is almost perfect. However, I’d say that there is some kind of distortion of the harmonics or perhaps a lesser presence of some of them. I’d say that there is a preponderance of the harmonics that give a more harsh character to the sound and a lesser presence of the harmonics that give a rounder or warmer character to the sound.
« Reply #138 on: January 09, 2018, 07:42:14 am »
Thank you for sharing Juan.
I myself am not sure by now, except for that I am sure my hearing is off. Possibly that Australian flu going around ...
So if it gets quiet in here, you know what happened. swoon
« Reply #139 on: January 09, 2018, 08:42:47 am »
Hey Peter, take care of yourself, we need your ears almost more than ours. Take a lot of orange juice and rest. Get well,
« Reply #140 on: January 09, 2018, 10:21:06 am »
I've settled on the following:
non-MQA: Custom Low
MQA: Arc Prediction
If I forget to change to AP with MQA, I realise within a few seconds of the music playing that something sounds 'off'.
Robert
« Reply #141 on: January 23, 2018, 09:13:03 pm »
Well I havn't commented here for a while. I now have the Lush and after a month much prefer it over the Clairixa, difference not being as large as perhaps some felt between the two but definitely more music.
I've played with all settings suggested and currently enjoy settings per my signature. I do prefer Arc filter over custom even changing from Low 705600 to Mid 705600 as per Peter's suggestion. Arc has a clarity over the custom filter settings. Anyway still listening. Running SFS at 20.19 has mean't no problems with running certain Hi Res files.
Music has never sounded better in my hot summer weather.
Spring is coming for those in the North!!!!
Robert
Oppo 205 UDP Dac
JLAudio 12 Active Subs x 2
« Reply #142 on: February 14, 2018, 09:13:49 am »
Hi all,
3 days ago I set back my SFS from 20.19 to 10.19. It took me a month or so but eventually I couldn't stand the, say, sharpness of 20.19. It just was too much of it.
Receiving complaints from the family now and then as well, in the end did it.
« Reply #143 on: February 14, 2018, 06:36:53 pm »
- SPL seems louder at same volume settings; even at -36dB I can fill a pretty large room.
This i generally a BAD thing IME.
But I'm still reading the long thread, maybe some other setting improved it.
« Reply #144 on: February 15, 2018, 02:03:11 am »
How did you and to 0.90 from there? I'm still missing a step or two...
« Reply #145 on: February 15, 2018, 08:23:19 am »
Telstar - It is in this topic. Best is to use ctrl-f for search the page and then search for [space]0.9
Then you run into them.
If that is what you meant ... Happy
Robert
« Reply #146 on: February 16, 2018, 02:17:06 am »
Tried 10.19 but back to 20.19. 10.19 feels less detailed, less bass impact for me. I may be deafer to sharpness from industrial noise over the years. Once again depends on recording. Melody Gardot's latest live release in 24/48 is excellent.
Oppo 205 UDP Dac
« Reply #147 on: February 16, 2018, 06:00:39 pm »
Thank you for the feedback, Robert.
« Reply #148 on: February 17, 2018, 11:36:36 am »
It is difficult to choose between the two SFS settings (10.19 / 20.19), but with some of my references to check the quality of highs and lows such as Bach's Tocata and fugue in d minor by Marie Claire Alain, it's perceived clearly that the highs have some aggressiveness with 20.19. In addition there seems to be more depth of the sound scene with SFS 10.19. This does not mean that with other less extreme recordings the preference would be 20.19
https://www.discogs.com/es/Bach-Marie-Claire-Alain-Toccata-Fugue-En-R%C3%A9-Mineur-Chorals-Sch%C3%BCbler-Passacaglia-Fugue/release/9420156
« Reply #149 on: February 17, 2018, 12:43:43 pm »
Thank you Juan.
