November 23, 2024, 03:17:23 am *
Pages: 1 2 3 4 5 6 7 8 [9] 10 11 12 13  All
Author Topic: 2.09 sound quality  (Read 163254 times)
« Reply #120 on: December 07, 2017, 11:02:54 am »
With the new settings it seems necessary to increase the volume one step and sometimes two to get the best SQ. The difference between the optimal volume level and the next lower level is surprising. Previously the optimum level in my case was -19.5db and now it is -18db and sometimes up to -16.5db
« Reply #121 on: December 11, 2017, 10:18:59 am »
It seems that it's very quiet here. Well, surely Peter is preparing some surprise. Meanwhile I'm still experimenting with the settings to find the best SQ. So far the best I have found is:
Q1=30 Q3=0, Q4=1, Q5=1, xQ1=40
SFS: 10.20 (max. 120)
ClockRes: 15ms
Driver v1.0.4. 4ms
Custom Filter: 705600 Low
briefremarks
« Reply #122 on: December 11, 2017, 10:45:04 pm »
Juan,
I have been experimenting with settings as well, and have essentially settled for the moment on the same settings as you except with Q5=0.  I remember when the Stealth PC first came out, the suggestion was to use Q3/4/5 = 0/1/0; which had worked well for me prior to the G3/Lush upgrade.  Q3/4/5 = 0/1/0 seems to produce more body/realism without any loss of detail or dynamics.
Ramesh
XXHE version 2.11.
« Reply #123 on: December 12, 2017, 08:20:17 am »
Hey ...
Each time I go for something else than Q3,4,5 = 1,1,1 for me the sound is too gray. But mind you, this is all rtelated to the Lush. So with 1,1,1 there's more sparkle and the Lush requires that (for me). Maybe not with each and every other setting, but then I did not find those ...
« Reply #124 on: December 12, 2017, 08:37:03 am »
OK. Yesterday we were explicitly talking about the eerie good SQ we have here now with btw by now and each day a different perception from it. But I imagine that this is because it is all so fragile and on the verge of being completely real. Hence, all what deviates from that makes it unreal and very noticable for that reason. I also have the idea that my system won't do any more with less than an hour of "breaking in" for the day. After that, all can go to infinity. There's just no way things can sound bad after that period of playing.
Q1 = 30x40
Q3,4,5 = 1,1,1
SFS = 9.0 (sorry)
ClockRes = 15
Core 3-5
No OSD Text
Coverart Wallpaper  in use
(NOS1 Driver = 16ms)
About the SFS = 9.0 : well, I just finally set it to that because 8.0 did not satisfy me and 10.x is too much of it (highs). I did not want to have the 9.0 because you can't (yet) but I did it after all. And now I seem to be overly satisfied. Anyway, anything close to 9.0 may not matter - I don't know (did not try).
About the change each day :
For me surely this is about the operating of my ears or maybe mood (not sure about this latter, but we know this matters too and although my mood is almost always good, gradations of it exist).
The last days I very deliberately did nothing about the "hardware" as such, when I found it to be less that the day before. So I have adopted the situation about mood and ears. And indeed, the next day all can be "100%" again. But it is difficult because this breaking in which is required each day is something to "bite through" instead of letting it destroy your mood and arrive in a downwards going circle.
When writing the above I feel like I just described how voodoo operates. And maybe it just all is a state of mind. Well, then I don't care. Happy And you suit yourselves, haha.
I hope we're having fun !
« Reply #125 on: December 13, 2017, 03:48:26 pm »
Juan,
Ramesh
Hi Ramesh, I think we are all close between SFS 8.0 and 10.5, the other settings are similar and it is difficult to know which one sounds better.
It is true what Peter says about the state of mind. Sometimes we find a satisfactory sound and that makes us be in a good mood. The opposite also happens. Personally I appreciate that this hobby is able to have that influence on my mood. This allows me the possibility of recovering if I feel bad.
« Reply #126 on: December 21, 2017, 03:23:19 pm »
I changed my SFS back to 10.20 fairly soon after the second day with 9.00 which made me think the sound was "ugly". I recall that I had moments of thinking the same on the first day of using 9.00. It depends on the music.
After a week of being back on 10.20 I still like it.
I quite explicitly decided that the "too much of it" counts for a few albums which I then will accept, *if* it already isn't about moisture, temperature, draft, ears or mood. IOW, the past week has been fine throughout.
« Reply #127 on: December 29, 2017, 04:01:12 pm »
All,
Yesterday was the 4th day that I played with an SFS of 20.19.
The .19 is a residue from the 10.19 I use prior to that, and I did that deliberately.
In my perception this brings even more highs than the "too much of it" I reported about 10.20, earlier on, but now the highs are not nasty. I actually love this sound. The level of (good) detail is wild.
« Reply #128 on: January 03, 2018, 11:30:08 am »
I thought I had too much bass with previous settings or no bass at all...
SFS of 20.19 works very nicely here as well cleaning up the "too much bass" with the lower SFS settings.
And here too, I hear clearly detail never heard before without nastyness.
« Reply #129 on: January 03, 2018, 07:03:18 pm »
All,
A lot of detail and excellent bass. The only problem with such a high SFS is that sometimes the volume change does not work or it takes a long time.
Edit: Lately the volume level is working fine, restarting XXHighEnd fixed up the problem
briefremarks
« Reply #130 on: January 04, 2018, 08:51:35 am »
I've been listening for a few days with SFS at 20.19 and must say that SQ is really beautiful, as is the music I've been listening to.  Might just leave things as is for now.
XXHE version 2.11.
Arjan
« Reply #131 on: January 07, 2018, 03:11:24 pm »
All,
and now try Arc Prediction...
regards
March, 2024 (2.11)
« Reply #132 on: January 07, 2018, 05:45:21 pm »
All,
regards
With Arch Prediction it seems a more vivid and dynamic sound, it even seems as if the volume has gone up at least one step. Also the bass seems bigger and so the soundstage.
I'll keep listening. Thanks Arjan.
« Reply #133 on: January 07, 2018, 07:53:13 pm »
OK, going to try that too, right now ...
(with the lower SFS numbers I liked it for the better for a while, but this was with 2.08, I think).
wacko
« Reply #134 on: January 08, 2018, 10:02:11 am »
Hey ...
All,
regards
Hmm ... Might it happen that we all like this, then it could be that we are all subject to damaged ears, OR we just don't understand what to listen for any more. Well, something like that.
My experience from yesterday :
For a first hour I kept on noticing how dry and short the sound was compared to my Custom 705600 "Mid" setting which I use for the past 4 weeks or so. So, good.
Then I ran into a first album of which I thought that the metal reverberance sounded like something which is broken.
Once recognizing this sound, I kept on hearing it in everything, but without being sure whether something sounds (oscillating) broken, or whether I need to re-learn to listen.
This was all with more commercial music which should not sound very special. Still it did. So actually I am looking forward to tonight's listening session where I will play my regular test-signal music. It should be way wrong or jaw dropping good.
Maybe my ears had an offset yesterday. Happy
Does anyone recognize something of this ? The sound is suddenly completely different and it slipped through my mind that I wanted to tell you I had new amps and new speakers. And probably a new DAC. Completely unrecognizable, but still in a fashion that I suspect to be able to decide it is not wrong. That takes more days of listening though.
Thanks !
