November 23, 2024, 02:42:21 am *
Pages: 1 2 3 4 5 6 7 [8] 9 10 11 12 13  All
Author Topic: 2.09 sound quality  (Read 163243 times)
« Reply #105 on: December 01, 2017, 10:36:24 am »
Low filter makes it most acceptable for me
Now that. smirk
Does anyone know how many freakin' combinations this program has ?
Careful, you ! hehe
I remember my times with valves and the madness of trying one or another looking for the best sound. The amount of money spent!  Once that I accepted that the fun of this hobby is in the search, since the perfect sound does not exist, the XXHE finding was a fundamental discovery. The "change of valves" now is for free.
By the way, I'm still happy with 8.00 / Low Filter Happy although 8,80/LF is also a good combination depending on the piece of music.
« Reply #106 on: December 01, 2017, 11:41:54 am »
Thank you Juan.
I will try the Low filter tonight.
« Reply #107 on: December 02, 2017, 02:54:38 pm »
SFS = 8.8 and 705.6 / Low Filter sounded superb here.
An if anything, more bass again.
« Reply #108 on: December 02, 2017, 02:56:59 pm »
Thanks Peter, I can not think of anything to put the odd numbers. Well, if at any time you find out, please tell me
This is/was so on purpose. It is related to memory allocation. But, I wonder whether this is still a problem (over here all keeps working). So the next version allows the odd numbers.
« Reply #109 on: December 02, 2017, 03:37:20 pm »
That's ok Peter, I wait for the next version.
Good that you also found great sound with the Low Filter. However I find that 8.80 gives the impression that the sounds float in an inconcrete way,  it was difficult to locate exactly where they come from in the soundtage. Something similar to when the sound is out of phase. That problem does not exist here with 8.00 / LF. Possibly it depends on that we have different systems. Anyway, it's a big step forward with the latest settings in v2.09,  the use of SFS around 8.00 and the Low Filter.
« Reply #110 on: December 02, 2017, 04:22:48 pm »
Juan, I said 8.8 but I think I meant to say 8.0. I can't even check it any more because I was testing with the odd numbers and it got overritten with a lot of 9's. LOL
I shall try both tonight, if I don't forget.
Regards and thanks,
« Reply #111 on: December 02, 2017, 04:25:03 pm »
 very happy
« Reply #112 on: December 03, 2017, 10:30:57 am »
So ... Yesterday I tried some huge combination buffer settings and thought it was quite fine. But technically not because of unsynchronized activities at the end of a track etc. (instead of the next track beginning, the last buffer of the previous track played again and more anomalies), but anyway it played. This was also my mistake to do, because now I did not like SFS = 8.00 any more. Also not 8.80 (worse I'd say).
Then I went back to my formerly chosen 10 ...
So right in the first second I notice it again. There is something (very) special with 10.00 going on. It is in the sense where I left off a track with 8.80 (paused) and proceeded with it where it left off, with 10.00, I couldn't even recognize it as the same track.
Highs seem to be infinitely more but also of explicit good quality (at some stage I measured and saw I was playing at 94dBSPL with is fairly loud yes).
Don't ask me why this is.
As I reported a few days ago, I already noticed this. But now it was with the 705.6 Low filter (few days ago it was the High(est)).
Rmalits
« Reply #113 on: December 03, 2017, 11:01:08 am »
Hi there,
SFS=8.00 or 8.80 sounds pretty good but demands a mid or low filter. Therefore I am not really convinced about it.
SFS=10 with second highest filter is good too. Adding just 0.24, so SFS=10.24 already sound pretty different, not as good as 10.00
I still wonder why release 2.09 reacts in such a sensible way to small changes of SFS (compared to previous XXHE releases).
Peter, could you give us an explanation for this?
Kind regards
Richard
« Reply #114 on: December 05, 2017, 01:39:21 pm »
Hi All,
Day before yesterday I found that SFS=10.0 could be disturbing in really lesser compressed albums. Think Beatles (no Remaster). Too much highs in related to something missing right under that (lower highs ?) with a still very profounding mid. So say that this shows a gap above the mid.
Then I changed to 10.1 (because of someone proposing that - I forgot who, but thanks) and thought it was an improvement. Then changed to 10.2 and again found that working very well and I left it at that. Not sure whether there really was a difference between 10.1 and 10.2. But 10.0 really was too much of highs.
Yesterday I was happy with this 10.2 throughout.
It occurs to me that this is so much "on limits" that I can very much imagine that this can not work out the same on so differing systems as a whole, which most of us must have.
What keeps on occurring is how good the drums are. So much differentiation between everything (I am not talking cymbals).
« Reply #115 on: December 05, 2017, 02:48:04 pm »
It seems that my system is reacting positively on the changes as well... :-)
Playing louder as well (more forward) but well balanced (less Loudness effect).
Not playing any serioulsly compressed material though (I can't stand the noise so to speak).
« Reply #116 on: December 05, 2017, 07:53:42 pm »
I've been trying for the last two days to see the positive of SFS 10.00 (Peter's psychological influence is always inevitable). Peter expresses it  better than me but what I thought was more or less that the sound seemed very clear but lacking in body. Elegant but too thin. Yes, it seems that SFS 10.20 has that body that is missing at 10.00 but nevertheless lacks still something. Maybe we should look for somewhere, not only in the SFS.
Arjan
« Reply #117 on: December 05, 2017, 10:18:03 pm »
Try Q3 and Q5 on 0.
For me that always at some extra roundness.
Regards, Arjan
March, 2024 (2.11)
« Reply #118 on: December 06, 2017, 09:37:02 pm »
Try Q3 and Q5 on 0.
Regards, Arjan
Thanks Arjan, I've been testing those Q settings and it has been an useful suggestion. With Q3:0, Q5:0 the bass is too big in my system. I made some changes, now I have Q1:30, xQ1:40, Q3:0, Q4:1, Q5:1. SFS:10.16.  Filter:705600 Low. Still big bass but much better. I'll keep listening.
 love this
« Last Edit: December 07, 2017, 05:41:23 pm by juanpmar » Logged
« Reply #119 on: December 07, 2017, 08:46:43 am »
Try Q3 and Q5 on 0.
Arggh, I forgot to test this yesterday.
