November 23, 2024, 01:11:54 am *
Author Topic: Activate Windows?????  (Read 8418 times)
hvdh
« on: October 18, 2017, 06:42:33 pm »
After I "upgraded" from Win10 10586 to Win10 14393, I've noticed one small change that I did not expect:
The "Activate Windows" message is (sometimes) still visible during Unattended Play.
It's probably nothing to worry about, and I know I can get rid of it myself by killing Explorer in the Task Manager, but still.
Are you aware of this change in behaviour between 10586 and 14393?
Is it possible that this change is caused by my starting to use Imdisk?
Henk
Win10 14393.0 / music on LAN /  / Q1/-/3/4/5 = 30/-/1/1/1 / xQ1 = 40 / Dev.Buffer = 4096 / ClockRes = 15ms / Memory = Straight Contiguous / Not Include Garbage Collect / SFS = 20.19  (max 60) / not Invert / Phase Alignment Off / Playerprio = Low / ThreadPrio = Realtime / Scheme = Core 3-5 / Not Switch Processors during Playback = Off/  / UnAttended (Just Start) / Always Copy to XX Drive / Stop Desktop-Remaining-WASAPI-W10 Services / Keep LAN - Persist / WallPaper On / OSD On / Running Time Off / Minimize OS / XTweaks : Balanced Load = 42 / Nervous Rate = 100 / Cool when Idle = 1 / Provide Stable Power = 1 / Utilize Cores always = 1 / Time Performance Index = Optimal / Time Stability = Stable / Arc Predict -> Clairixa USB 0.80 meter -> 24/768 Phasure NOS1a DAC With B'ass and Phisolator -> BAlanced interlink -> Apogee Grand loudspeakers, using STAX dma-x2 (midrange ribbon) / Krell FPB600C (bass ribbon)
If it flies, Don't ground it!
« Reply #1 on: October 18, 2017, 07:05:03 pm »
Hi Henk.
All normal.
Attended, I reckon.
hvdh
« Reply #2 on: October 18, 2017, 07:40:28 pm »
Nope.
UNattended...
« Reply #3 on: October 19, 2017, 12:56:33 am »
Yep, that message sits down in the bottom right of my screen as well during unattended playback.
« Reply #4 on: October 19, 2017, 04:22:39 pm »
Well, I can't reason out how that would work.
All I know is, Henk, that I heard you talk about starting Explorer etc. which makes me scratch my head.
And of course if you bring up the GUI (still playing in Unattended mode).
I'd say there isn't even an opportunity for Windows to show that, when in Unattended (there's no canvas for it).
Maybe when you don't use the Wallpaper Coverart ?
hvdh
« Reply #5 on: October 19, 2017, 09:50:13 pm »
I'm afraid this is a Babylonian speak distraction, to say it in dutch:)
I may have mentioned starting explorer in unattended, which isn't very difficult to do, in unattended.
But it has nothing to do with me noticing the "activate windows" message in unattended.
Neither is a problem, it just surprised me to see the "activate windows" message, and I was wondering if you had noticed the same....
By the way: If you want an explorer window in unattended:
- open task manager before you play any music (CTRL-Shift-Esc)
- Start the music
- In Task Manager: File -> Run New Task -> explorer
explore away, It's that simple:)
Gr,
Henk
Edit:
I just realised why peter mentioned me killling Explorer to get rid of this "activate windows" message in unattended.
I never do this. I only kill explorer from the task manager (in MINos) to get rid of this message AFTER I am done with listening to music.
I use Jriver to view movies on the same PC, and the "activate windows" message is a bit annoying when I watch a movie, that's all:)
« Reply #6 on: October 20, 2017, 08:23:10 am »
I know. And it is a "stupid" thing to do, because you start many services and things which should not run and which won't be killed again unless you stop and restart playback ...
PS:
Then activate your OS. swoon
Which will upgrade it as well. swoonswoon
Careful, you ! hehe
Page created in 0.113 seconds with 19 queries.
