April 06, 2025, 01:32:48 pm *
Pages: 1 2 3 [4]  All
Author Topic: Burst of noise  (Read 49293 times)
« Reply #45 on: November 15, 2017, 07:33:07 am »
The X2 upgrade patch has sorted out my problem.
Thank you very much.
« Reply #46 on: November 15, 2017, 10:53:35 am »
Which version of Engine 3 should I replace?
X1 or X2?
I have the scary noise here also once in a while and if this is the tweak to cure that then my heart will be thankfull!
« Reply #47 on: November 15, 2017, 12:07:59 pm »
X2. I will remove the X1 upload. Sorry for the confsion !
« Reply #48 on: November 17, 2017, 06:51:31 am »
Hi all,
This should be the final one (download it below).
Now not only the issue is covered for when it happens (as in the X2 version) but also the cause has been found and taken out. This cause has been in there forever (since the last 0.9z version), but was challenged for because of a 80 second time window where things could go wrong which window previously was way shorter (think a few seconds). All related to how playback stopped (implicitly would incur for the wrong situation) and how fast a new Play was issued.
The noise could happen fairly soon when the new Play was issued, but also at the second track of that when the first was shorter than 80 seconds (minus how fast you could re-issue Play).
Thank you all for your help on this one !
* XXEngine3-209-X3.rar (341.73 KB - downloaded 521 times.)
« Reply #49 on: November 22, 2017, 02:22:21 pm »
Sort of a strange situation here. Never had a burst of noise problem with 2.07; however, since I reverted back to 2.07 from 2.09, I've now had the problem 3 times. Two of the three times the burst only lasted a second or two then music played. One time music stopped completely and I had to reboot. That I would get the burst followed by music is likely due to my small SFS with 2.07, which is .02. With 2.09 my SFS was 1.0. At some point I may try 2.09 again but I started hearing a bit of harshness with it that is absent in 2.07. Perhaps some saved file from 2.09 was preserved when I switched back to 2.07 from 2.09?
« Reply #50 on: November 22, 2017, 04:25:43 pm »
Hi Brian - You mean some saved file which now causes the "buts of noise" in 2.07 for you ? nah. I would bet that this is the smaller SFS. I mean, I simply know it has always been there and I also know what I solved in the XXEngin3-X3 version. However, it *is* related to a relation between Stop and Start (Playback) and how one can do something unexpectedly (for the program) which or goes wrong within the second (depending on the SFS size) or goes wrong at the start of the 2nd track (after pressing Play). And then it is also related to the Q3,4,5 settings.
I hope you can make something of this !
« Reply #51 on: November 23, 2017, 03:04:51 am »
Thanks Peter, I play around with some settings.
Brian
« Reply #52 on: November 28, 2017, 02:56:53 pm »
For the first time after the X3 upgrade patch to Engine 3, I got crack detect msg. I have sent you the music file by FileMail.
Hope you can make something out of it.
« Reply #53 on: November 28, 2017, 06:01:37 pm »
Arvind, Yes, this (see below).
Just not right for the period of 0.1 second (so that is theoretically 441 subsequent base samples which are wrong.
It exactly this what the "Crack Detect" trips on.
It is not your rip. It is just in the master of this.
If you play this with the Custom filter, it will pass (I checked). No idea what you will hear for this small period of time.
Theoretically this is a close to 22.05KHz tone without anything else (it is safer to think it is ~11KHz). But it also clips, so this really is not right.
« Last Edit: December 22, 2017, 06:33:52 pm by PeterSt » Logged
charliemb
« Reply #54 on: December 22, 2017, 06:27:03 pm »
Hi Peter
I've applied this over 2.09 with no problems.  Is it okay to apply it over 2.01?
Charlie
Hi all,
July 2019:
« Reply #55 on: December 22, 2017, 06:37:01 pm »
Hi there Charlie,
Sadly, No ! Sorry ...
First one would be 2.07.
